brunswick737
Honda's New Experimental Business Jet
Sat Dec 20, 2003 3:27 pm
dont know if this was here so....http://world.honda.com/news/2003/c031216_2.html
Tokyo, December 16, 2003 --- Honda Motor Co., Ltd. announced today that the HondaJet, its new experimental compact business jet equipped with Honda-developed HF118 jet engines, successfully completed initial flight tests this month at Piedmont Triad Airport in North Carolina, US.
Compared with conventional jets, this experimental aircraft offers superior fuel efficiency and remarkable cabin space. The engines are optimally positioned on the upper surface of the main wing in a unique configuration that reduces drag at high speeds and increases cruising efficiency. This layout also eliminates the need for structural engine mounts in the fuselage, creating over 30% more cabin space than in a conventional aircraft.
The fuselage is a compact and lightweight co-cured carbon composite structure, yet realizes the largest cabin in its class. The main wing, which features aluminum skin panels formed from single sheets of aluminum that provide a smoother surface than conventional wing configurations, along with Honda's proprietary turbulence-reducing laminar airfoil, work together to significantly improve aerodynamic performance. Additional drag-reducing technologies include the fuselage nose, which is designed to generate laminar flow. These features, in combination with Honda's fuel-efficient HF118 Turbofan Engine, achieve fuel efficiency over 40% higher than conventional aircraft.
This experimental aircraft is also fitted with a state-of-the-art glass cockpit with an integrated avionics system, as well as an autopilot function, anti-icing equipment, and other systems. The jet is scheduled to undergo approximately 200 hours of flight-testing to demonstrate and verify the operability and performance characteristics of its various systems.
Honda began research into compact business jets in 1986, using engines provided by other manufacturers. The HF118 Turbofan Engine-equipped HondaJet experimental compact jet is the first Honda-developed aircraft to be outfitted with a Honda engine, a significant milestone for the company and the industry.
found it out on some car forum website
penguinflies
RE: Honda's New Experimental Business Jet
Sun Dec 21, 2003 3:02 am
In reality, if this jet was to go into production, it could beat cessna, eclispe and safire to the market. Only Adams is in flight testing to be certified in 2004/05.
Ikarus
Sun Dec 21, 2003 5:30 am
Definitely a cool little plane. VFW614-style engine placement, Raytheon-style all-composite plane.
Impressive. Let's hope it does not just stay an experimental thingy.
