Richard28
BA 777 Lavatory Configuration
Fri Jan 02, 2004 10:56 pm
I saw the BA 777 config at seatguru http://www.seatguru.com/british/B777.shtml , and was shocked to see that World Traveller , and World Traveller plus sections only have two toilets!
That's 2 toilets for 167 pax, or 1 WC per 83.5 pax
The older BA 747's (which I have flown on) have a much more reasonable 7 toilets in WT and WT+ sections catering for 354 pax (1 WC per 35.4 pax)
their main competition does not fare so badly either:
VS B744 1 WC per 56.3 pax (6 WC, 338 PAX)
VS A343 1 WC per 43.0 pax (5 WC, 215 PAX)
VS A346 1 WC per 65.3 pax (4 WC, 261 PAX)
Why does the BA 777 have so few toilets, the queue's must be a nightmare - let alone should one break down!!
Any one have any experience of the BA 777 config?
V1-Rotate
RE: BA 777 Lavatory Configuration
Fri Jan 02, 2004 11:15 pm
Richard,
That seat map is incorrect.To be fair,even BA's own website is partially wrong on toilet location.
There are either 3 or 4 toilets in that middle section between WT and WT+ dependant on whether bunks are fitted or not.(the access to bunks takes the place of the centre right hand toilet.There are a further 2 toilets,one each side,at the very rear of the a/c.
So,either 5 or 6 is the correct amount.
TR
Fri Jan 02, 2004 11:16 pm
The layout of seatguru is not correct as the BA 777s in this configuration has an additional 3 lavatories at the rear of the aircraft. One situated in front of Left side rear door and one on each side right behind the rear doors. So a total of 5 lavatories is available to World Traveller Plus and World Traveller passengers.
The correct layout can be seen here:
http://www.britishairways.com/travel/seatwt/public/en_dk
Thomas
edina
Fri Jan 02, 2004 11:25 pm
V1-Rotate is quite right......... the config shown on that link shows the wrong galley layouts for that seating config. The a/c shown is an A Market in terms of galleys, but a B Market in terms of seating, so the site is totally confused :-~
3/4 Class B Market aircraft have 5 toilets as standard in W & M cabins 2 at doors 3 and 3 at doors 4. 2 Class B Market a/c have 2 at door 2, 4 at door3 & 2 at door4. The few A market 777s that are left have 4 toilets but have a lower number of W & M seats.
Worked on - Caravelle Mercure A300 A320 F27 SD3-60 BAe146 747-100/200/400 DC10-30 767 777 737-400 757 A319 A321
