jblake1
WN & 737-800/900
Thu Jan 08, 2004 4:02 am
As Southwest increases the number non-stop of cross-country routes does anyone feel they might consider purchasing the -800 or -900 series 737?
Thanks, Jason
Greg
RE: WN & 737-800/900
Thu Jan 08, 2004 4:10 am
They said no...not enough set differential revenue to offset the costs of add'l flight attendants needed per FAA...
ssides
Thu Jan 08, 2004 4:11 am
It's doubtful, but who knows.
The -700 can pretty much handle WN's loads at this point. In fact, the rumor is that they're looking for something smaller rather than larger. I don't buy the rumors that say WN is looking at the Embraer 170 and 190, but they're out there.
The -800 and -900, from what I understand, were pretty much designed to be used by "major" carriers. They're big enough to offer a large coach section while maintaining first-class amenities. I don't know the numbers off-hand, but I would bet that an -800 or -900 with no first class could hold close to 200 pax. I don't think WN has any routes that would justify these numbers; WN would rather increase frequencies than buy a bigger plane for most.
Again, I haven't had time to check out Boeing's web site for this, but I also believe that the range of the -700 is longer than the -800 or -900. If this is true, WN would probably rather just stick with the -700.
"Lose" is not spelled with two o's!!!!
drerx7
Thu Jan 08, 2004 4:34 am
Actually, Southwest's order for -700s does include the option to switch to -800s as well.
Third Coast born, means I'm Texas raised
EA CO AS
Thu Jan 08, 2004 4:53 am
They're still limited to 189 total on the 739 because there aren't enough exits to legally exceed that number. The proposed -900X would have an additional exit to permit a higher passenger count.
jblake1
Thu Jan 08, 2004 5:17 am
Thanks for the insight guys!
