artsyman
Continental IAH-AMS 2 X Daily
Thu Jan 08, 2004 7:13 am
Well, these things come out of nowhere, but here's the data
Flight 58 Will leave IAH at 3.40pm, operated by a 762
Flight 46 Will leave IAH at 7.20pm, operated by a 764
I do not know the starting date as I have been too lazy to look it up, but I had to check a flight for a friend today, and it is in the system for the end of June.
J
scottysair
RE: Continental IAH-AMS 2 X Daily
Thu Jan 08, 2004 7:25 am
Hi,
I am not quite sure about exactly what is date will make added 2x flight out of IAH and this is quite doing very well on their way to AMS. Is hat flight was always full on the way, right? I'm glad to hear about CO make add second flight to AMS.
Regards!
Scott W.
PW100
Thu Jan 08, 2004 7:38 am
So thats 14x weekly CO and 11x weekly KLM on IAH-AMS for the summer?
That's quite some capacity growth there, considering KLM will do a daily 744, and CO most likely at least a daily 772!
PW100
ishky15
Thu Jan 08, 2004 7:41 am
glad to hear that houston-amsterdam is doing so well. i'm assuming that the success of this flight is a result of the large amount of connections being made at both hubs onto other destinations. however, i would have expected newark to receive double daily service before houston. i guess houston does have more links to onward destinations, though, and the new york-amsterdam/europe market is already heavily filled anyway.
is this the rumored new longhaul from houston for summer '04, or can we expect to hear something else from continental within the next few months?
Lear777
Thu Jan 08, 2004 8:18 am
This new flight is a little strange. It will only operate IAH-AMS on SUN/THU, then back on FRI/MON. 767-200. Oddly, it will arrive and depart within a half hour of the daily KLM 744. CO will now have nine weekly AMS-IAH, along with KL.
KLM's second flight operates FRI/SUN, so on Fridays we'll have four flights from AMS, and on Sundays four flights to.
Is this a competitive response to KLM's extra service, or actual needed capacity? The timing (just weeks after KLM increases) is a little suspect.
Either way, pleased to see AMS-IAH go 18X weekly. I'd love to see both KL and CO's additional services go daily for four times daily service...how's that for alliance growth?
Brian
Go Astros!
gigneil
Thu Jan 08, 2004 8:47 am
As the thread starter mentioned, one flight will be a 762 and the other a 764.
N
MAH4546
Thu Jan 08, 2004 9:41 am
As pointed out earlier, this does not make for 2x daily IAH-AMS on CO. CO will operate 9x weekly, with second frequencies on ThSu.
a.
sllevin
Thu Jan 08, 2004 9:54 am
IAH-AMS with a 764 sounds like a receipe for very unhappy customers. It's absolutely max range for the 764 (a tick more than EWR-HNL), and to get that distance means running right down "jetstream alley." Trying to get north of Iceland would push the routing close to 5200sm, which could leave a lot of flights stopping at CLE -- with passengers missing connections (unlike EWR-HNL, where, for the most part, it just gets folks in late, but they don't have onward connections).
That said, I hope it does work out...it'd be a grea accomplishment for a much-maligned aircraft type.
Steve
artsyman
Thu Jan 08, 2004 10:09 am
IAH-AMS is currently a 764, and they are not ending up in CLE on the way back these days, so I don't see why they would be then.
J
ORD747CLE
Thu Jan 08, 2004 10:46 am
There is no way there will be a stop over in CLE! Passengers today won't stand for a stop over in CLE for fuel!!
Ord747Cle
777gk
Thu Jan 08, 2004 11:09 am
IAH-AMS has only been operated with 764 periodically. Best bet is that it will go 777 in the summer, as it has in the past, to mitigate any need for stopovers due to limited performance in those humid IAH summers. Still, I have not heard of the 764 having any trouble completing this route when scheduled, and often runs with full loads in either direction.
sllevin
Thu Jan 08, 2004 11:20 am
My bad -- I thought it was being operated with the 767-200 currently. Just goes to show that smaller reserves are needed when the last 2500 miles isn't over water!
Steve
SR 103
Thu Jan 08, 2004 11:40 am
Thanks for the info, good to know. Do you think there is a chance that the 764 flight would become a 772, the way it did this past summer? Or are there no spare 772's out there right now?
SR 103
ssides
Thu Jan 08, 2004 12:24 pm
I would think so too, except for one big factor: Shell. Shell's US headquarters are in Houston, and their two major European operations are in London and Amsterdam. Shell is well-known for sending its employees on extensive business trips throughout the year. At first I thought Shell might have given some sort of guarantee to CO (much like Glaxo's contract with AA for RDU-LGW flights), but then I realized that this Dutch company probably has some kind of agreement with KLM. Nevertheless, Shell played a role, directly or indirectly, in getting this second flight to IAH.
"Lose" is not spelled with two o's!!!!
Thu Jan 08, 2004 12:49 pm
Interesting... CO doesn't have enough B762 or B777 to operate the flights they have scheduled under those equipment.
(to update an earlier post)
This is Continental's current Summer 2004 (as taken from their online timetable) widebody flying w/my rough estimate of approximate aircraft usage for each route (based upon the flight times - note that some flights, like the GRU and TLV, may require more/less):
Boeing 767-400ER -- 13/16
EWR/BRU (one aircraft)
EWR/DUB (one aircraft)
EWR/CO / LIRF), Italy">CO / LIRF), Italy">FCO (one aircraft)
EWR/FRA (one aircraft)
EWR/GLA (one aircraft)
EWR/HNL (one aircraft)
2xGUM/NRT (one aircraft)
HNL/GUM (one aircraft)
IAH/AMS (one aircraft)
2xIAH/HNL (two aircraft)
IAH/OGG (one aircraft)
LAX/HNL (one aircraft)
Boeing 767-200ER -- 9/10 + IAH/AMS on SU/TH
EWR-CDG (one aircraft)
EWR-GRU (1.5 aircraft)
EWR-GVA (one aircraft)
2xEWR-LAX (two aircraft)
EWR-MXP (one aircraft)
EWR-ZRH (one aircraft)
IAH/AMS - SU/TH (one aircraft)
IAH/GRU-GIG (1.5 aircraft)
Boeing 777-200ER -- 18.5/18
EWR-AMS (one aircraft)
EWR-HKG (three aircraft)
2xEWR-LGW (two aircraft)
EWR-MAD (one aircraft)
EWR-MAN (one aircraft)
EWR-NRT (two aircraft)
EWR-TLV (2.5 aircraft)
IAH/CDG (one aircraft)
2xIAH/LGW (two aircraft)
IAH/NRT (two aircraft)
(B752 flying to Europe: EWR to BHX, EDI, LIS and SNN)
Also note that there is a single B762, B764 and B777 in each direction between EWR/IAH -- these are repositioning flights... no more widebodies elsewhere (e.g. SFO, CO / KMCO), USA - Florida">CO / KMCO), USA - Florida">MCO, SJU, SDQ, etc.)
artsyman
Thu Jan 08, 2004 5:05 pm
Patent you can add 2 x EWR-CDG to your summer list as well as 2 x EWR-TLV to your list. You can also add IAH-MAD to your summer list.
J
Thu Jan 08, 2004 5:22 pm
Actually I updated the EWR-TLV aircraft numbers (and before anyone asks, the new flight quicky turns at TLV, so CO can rotate it with a single aircraft wheras the existing flight sits on the ground for half a day, requiring the rotation of a second aircraft)... the listing is organized by aircraft, so the EWR-CDG flights are split under the 762 and 777. I don't see an IAH-MAD nonstop uploaded into the timetables yet.
My point was to illustrate that CO doesn't have the equipment to operate the flights per scheduled equipment status quo... they have the equipment but some shuffling will be done... my bet for one of the changes is the termination of the EWR-LAX 762 flights, eliminating domestic widebody sevice for the summer (excluding repositioning flights between IAH/EWR).
artsyman
Thu Jan 08, 2004 5:39 pm
Patent, IAH-MAD for sometime in late spring, early summer. I have heard out of both Gordons mouth and also out of Kelners mouth, so while I will believe it when I see it, when it is those two saying it, and the company has started sending out notices about company sponsored spanish classes available, I tend to believe it.
J
Thu Jan 08, 2004 6:03 pm
Artsyman,
I should clarify what I meant: I posted the current widebody schedule for CO's summer 2004 schedule... obviously it needs some work (I mean they have the equipment to operate all the flights they want to, but they don't have enough B777 to operate all the scheduled B777 flights) -- maybe it'll be fixed when CO adds IAH-MAD  Smile.
artsyman
Thu Jan 08, 2004 6:20 pm
Patent, I totally understood what you were doing, I was just adding information for your project. Maybe because you and I argue so much, you just assumed that I was !!!...
J
Thu Jan 08, 2004 6:31 pm
LOL, that's probably true!
A hot rumor (or has it been confirmed?) says CO will reduce the F cabin on select 752 for lesiure destinations + all of the 753. Are the 753 over-water equipped? I'm wondering if LAX-HNL may be 753-bound...
artsyman
Thu Jan 08, 2004 6:56 pm
As of this week, the 753 is going to be 12 and 210 config. Thats 210 passengers in coach on a narrow body aircraft !!, they obviously feel that it can do the trick on the leisure routes. The 753 for Continental is really aimed at the sub 4 hour flights. So while I could never rule out HNL runs, I do not see it happening.
J
Randy4920
Thu Jan 08, 2004 8:17 pm
I heard CO is making a big announcement on Monday. Do you know what it is Artsy? Also.... Like asked before but not answered is LOS happening? Does this cover the big secret city CO is announcing this year?
sllevin
Thu Jan 08, 2004 10:36 pm
CO should just pull F completely from the 753's and call them "Continental Funliners" -- The upgrade situation is never going to make anyone happy at 12/210, so why not market them as full-Y flights?
Fortunately I'm not in FLL anymore so I shouldn't be seeing them much anymore  Smile
There's sometimes advantages to living at a 737 station  Smile Heck, even the 737-500 will now have better upgrade opportunities than the 757-300!
Steve
artsyman
Thu Jan 08, 2004 10:45 pm
I see it as a smart move. They will get much more revenue out of that aircraft type. They will obviously get the increase in revenue from the added seats in coach, and with only 12 F seats, the people that really want them will pay for them rather than waiting for an upgrade that may not come.
scottysair
Thu Jan 08, 2004 11:36 pm
Sllevin,
Right, I'm not in FLL anymore and so we are moving to PHX already. It is very wonderful place to live. So what are you think about of you guys about me?
sllevin
Fri Jan 09, 2004 3:56 am
And others will say...well, hard to redeem miles....hard to score EUA...let me take my money elsewhere. And if I'm going to pay to sit up front, I can do some on an airline where the FF benefits are better.
Even Delta is admitting that you can't just squeeze the captive audience effectively. Why does CO think it will be any different for them?
Steve
MAH4546
Fri Jan 09, 2004 5:31 am
I have no idea regarding CO's plans for MAD-IAH, but I don't believe the US and Spain have Open Skies and Continental has yet to file anything with DOT.
a.
artsyman
Fri Jan 09, 2004 6:34 am
I can do some on an airline where the FFbenefits are better.
From a domestic travel and unlimited upgrade point of view, there is not a better FF program. Continentals Onepass while taking some flak from time to time is bloody excellent if you are mainly a domestic flyer.
J
sllevin
Fri Jan 09, 2004 7:39 am
Which part of losing 12 F seats, and "if they really want it they'll pay for it" fits into "better?"
 Smile
Steve
A340Spotter
Fri Jan 09, 2004 7:47 am
Randy4920,
"Like asked before but not answered is LOS happening?"
Probably at some time in the future. And I have heard from a very reliable source it would be IAH-EWR-LOS if it does go which disappointed both of us!
JD
"Irregardless, it's a Cat III airplane, we don't need an alternate!"
ConcordeBoy
Fri Jan 09, 2004 7:52 am
Ya mean like this?  Laugh out loud
artsyman
Fri Jan 09, 2004 8:21 am
Oddly enough Concordeboy, didn't I hear out of your keyboard that you thought Continentals Onepass was by far the best Domestic ff program ?
J
ConcordeBoy
Fri Jan 09, 2004 8:59 am
...since you wont quit farting on me until I admit it, here goes:
Ahem...
Yes, CO does have the best
domestic
FFP out there"
777gk
Fri Jan 09, 2004 9:14 am
Will confirm that the 757-300s are indeed going to 12/210- from a friend of mine down in IAH this is the configuration they figured to maximize revenue. Several flights that are the 753's bread and butter are not heavily Elite-laden, so we either find ourselves with only a few EUA passengers sitting in front and most seats empty, or a bunch of operational upgrades filling out the at a loss. Don't worry though, on routes that we do tend to get high loads in FC (EWR-PBI immediately comes to mind), we will retain the 24/159 configuration along with a few 16/156 BF ships.
Fri Jan 09, 2004 7:48 pm
With apologies and respect to artysman, 777gk and every other CO employee: FlyerTalk's jiburi, not me, authored this but I thought it was so damn funny I just had to share:
Continental's low fare carrier, "Con" unmasked
Houston, January 9/PRNewswire-FirstCall/--Continental Airlines (NYSE:CAL) today unveiled Con, in the form of an 757-300, as the first aircraft in the company's new low-fare fleet. Con's debut in its new Newark and Houston hub officially put a "face" to the much-reputed Continental name.
"Today we are further differentiating Continental as a carrier that delivers a quality travel experience for people who want more than they get from a cut-rate carrier." said Chairman and CEO Gordon Bethune. "Customers who pay low fares account for insignificant part of our revenue, and we want to show our appreciation for their business by giving them less for their money. We have already reduced the mileage earned toward the Elite status for our low fare travelers, and are now in the process of removing 12 first class seats from our 757-300 aircrafts. Our expanded coach class cabins have always been key reasons for our best customers to
choose Continental."
Con offers a compelling alternative to the current crop of the low-fare carriers. As a full-fledged member of the Continental family, Con will offer complete connectivity and semless travel on all Continental offerings -- Continental mainline, Contiental Express and Continental's marketing partners.
Con will begin flying customers in January 2004, and by February, all of Continental's 757-300 will be reconfigured to 12 First Class seats and 210 coach seats. There will be 25 daily Con flights offering service from Newark and Houston to Orlando, Fort Lauderdale, Tampa, and to select west coast markets.
Con pricing structure is simple, with just 19 fare types.
Tickets go on sale today online at continental.com and all of Continental's regular distrubition channels. News release and other information about Continental can be found at the company's web site at www.continental.com.
