MD-90
Aircraft Ranked By Airspeed, Who's The Fastest?
Fri Jan 09, 2004 1:51 pm
All data taken from the 2001/2002 edition of The International Directory of Civil Aircraft, which a.net uses for its own aircraft data section. All of the numbers, are, of course, in knots, which does vary and isn't actually as good of an indicator as the maximum mach operating speed, but that was available for only a few aircraft. The knots figure should be a good way to compare aircraft, even though altitude and temperature both affect airspeed expressed in knots.
I draw 2 conclusions:
a). Older jets are faster than newer jets due to gas costs.
b). As a plane is stretched, it gets slower.
Flat out max speed:
549 - 727-100/200
545 - 707-120B and 707-320B and 720B
540 - 747SP
538 - 747-300
530 - 747-200B
530 - DC-10-30
509 - 737-100/200
395 - Piaggio P.180 Avanti
Max/high-speed cruise:
540 - 707-120B
530 - 720B
527 - 727-100 and Tu-154
526 - L-1011 (long fuselage)
525 - 707-320B
521 - DC-8-60
518 - L-1011-500
515 - 727-200
513 - Tu-154M
510 - MD-11
507 - 747-300/400
504 - DC-8-50
500 - 737-200 and DC-9-50 and MD-81/82/83/87/88
495 - A300B2-200/400
494 - A340-200/300
493 - 757-200 and 767-200
492 - 737-400/500
491 - 737-300
490 - DC-9-30 and DC-10-30
488 - A321-100 and DC-9-10
487 - A319/A320
486 - 767-300
485 - DC-9-40
484 - A300-600R and A310
479 - DC-8-70
475 - A330-200/300/500
470 - ERJ 170/190
464 - CRJ700 and 900
459 - CRJ100 and 200
456 - Fokker 100
455 - F.28 Fellowship
450 - ERJ 135/145
445 - Sud Caravelle 10B
421 - A300-600ST Beluga
405 - 328JET
368 - Saab 2000
352 - L-188C Electra
350 - Dash 8 Q400
348 - Piaggio P.180 Avanti
335 - 328-110
300 - EMB-120ER Brasilia (313 kts with uprated engines)
288 - Beech 1900D
267 - Beech 1900C
Normal/Typical cruise: (a category in the book for some aircraft):
490 - 777-200
482 - 777-300
461 - 767-400ER
442 - CRJ700 and 900
438 - 717-200
437 - MD-90
424 - CRJ100 and 200
Long range/econ cruise:
495 - 727-100
490 - 747-200B, 747-400 (and 747-300 long range cruise)
486 - Tu-154 (486 is econ, 460 is for long range)
485 - 747-300
484 - 707-120B and 720B
483 - L-1011-500
478 - 707-320B and DC-9-10
475 - A340-200/300
473 - MD-11
472 - A300-600R
467 - 727-200
464 - A330-200/300/500
463 - L-1011 (long fuselage)
461 - 767-200
460 - 737-100 and 757-200 and 767-300
459 - A310 and DC-8-70
457 - A300B2-200/400
454 - A319/A320
453 - Fokker 100
447 - A321-100
443 - DC-9-40/50
440 - MD-81/82/83/88
439 - 737-400
438 - MD-87
430 - 737-200/500 and DC-9-30
429 - 737-300
366 - F.28 Fellowship
325 - L-188C Electra
321 - Saab 2000
(Some Russian aircraft had a range of speeds, example 460-485 kts, so I didn?t include them, and a few of the newer craft only had Mach numbers, like the A380 at 0.88 max and 0.85 for long range)
goboeing
RE: Aircraft Ranked By Airspeed, Who's The Fastest?
Fri Jan 09, 2004 1:58 pm
I think the 747 should be at the top of the Normal/Typical Cruise section. I understand it goes at either .85 or .86, and the 777 is .84.
Nick
maiznblu_757
Fri Jan 09, 2004 2:02 pm
What about bizjets?
Speed In Knots True Airspeed
[Edited 2004-01-09 06:03:21]
Delta777-XXX
Fri Jan 09, 2004 3:34 pm
I didn't realize the 727 was so fast!
Hank
MD-90
Fri Jan 09, 2004 3:46 pm
Well, the list was getting really long so I omitted the bizjets for clarity. Besides, these forums are always so heavy iron centric that even a Global Express is hard pressed to attract much interest. But Maiznblu_757, I think your chart records airspeed at a certain altitude, which is why it only shows the Citation X going 475 knots. Ohhh it can go fasterrrr... Big grin
MD-90
Fri Jan 09, 2004 11:30 pm
This so deserves to be bumped.
garnetpalmetto
Fri Jan 09, 2004 11:55 pm
Pfft. Mach 0.85. Try "Mach 3+"
South Carolina - too small to be its own country, too big to be a mental asylum.
Bekol
Sat Jan 10, 2004 12:03 am
Hi,
I have read that the B747SP can reach up to Mach 0.92 (forgot the sources).. But I don't know if it's max cruise speed or normal cruise speed.. Also, md-11 are also very fast, flying at M0.86 at normal.. I am use it's faster than B747-400 (M0.84-85) as I flew on one before in the cockpit and the captain told me that the MD-11 (of swissair) was flying above us at a faster speed. I love the airbus as well but A330/A340 normal cruise speeds are just about M0.78-0.82)
Bekol
pilot kaz
Sat Jan 10, 2004 12:05 am
wow great pic and thanks for the info
lijnden
Sat Jan 10, 2004 2:04 am
I am missing the Convair 990. I still think this plane holds the highest cruise speed (990 km/h) of all airliners.
Can somebody check this fact?
Be kind to animals! Next trip: ORF-ORD-NRT-IAD-ORF
dw747400
Sat Jan 10, 2004 2:13 am
As you said in the first post, knots are a fairly poor indicator of speed. And some of those numbers do not seem right. For example, the 777-300 is actually faster than the 777-200 (.85 compared to .84).
CFI--Certfied Freakin Idiot
nonrvsmdmf
Sat Jan 10, 2004 2:19 am
The corp aircraft is missing:
Gulfstream GV -optimum crz M85
Gulfstream GVSP-opt crz M85 but 3.2% more fuel efficient than
the reg GV.
The Citation X max crz is M88 or more.
I did not forget...I just misplaced the thought...
MD-90
Sat Jan 10, 2004 8:07 am
I thought that the 777 numbers were a little strange as well.
The Convairs aren't in the database because no one flies them commercially anymore.
And for the record, the book does say that the Concorde does its thing at 1154 knots.
411A
Sat Jan 10, 2004 1:30 pm
Lijnden,
You are correct about the CV990.
Vmo...M.97, 581 knots.
Max high speed cruise, M.94, 560 knots.
A very fast design.
Thrust
Sun Jan 11, 2004 4:54 am
Look in the earlier Boeing jets, like the 707, the 727, the 737-200, and the 747. Also, the Douglas DC-8 too. The 707 and the DC-8 cruised at Mach 1, The 737-200, the 727, and the 747 all flew faster than 570 miles per hour. The 747 and the 737-200 cruise at 575 mph. The 727 cruises somewhere from 570-575. The newer jetliners like the 757 and 767 cruise at 530 mph typically, as well as the CFM-56 powered 737s. The 777, however, while slower than the 747, 727, 737-200, and 707 and DC-8, has actually altered one of your claims, MD-90. The 777 cruises at 555 mph, almost reclaiming the speed of the 757 and 767's predecessors. Stretching an aircraft I imagine would make it slower, because it increases the weight of the plane. Maybe the Boeing 7E7 will be even faster than the 777.
Fly one thing; Fly it well
DIJKKIJK
Sun Jan 11, 2004 6:02 am
I actually read somewhere in this forum that the VC-10 is one of the fastest
Never argue with idiots. They will bring you down to their level, and beat you with experience.
Olympus69
Sun Jan 11, 2004 8:03 am
DIJKKIJK
It was fairly fast - 505 kts max cruise, 478 kts economical cruise (for the Super VC10).
Thrust,
Says who?
The trouble with all these numbers is that you can't convert from Mach numbers to knots, since the conversion varies with altitude - which is not given.
dw747400
Sun Jan 11, 2004 10:01 am
Thrust,
None of the airliners you mentioned are supersonic, nor are your relative speeds correct. Below are typical cruise speeds for the aircraft you mentioned. Not sure of the mach numbers for the 707, 727, and DC-8, but I'd bet money the 747 is faster.
747-200: .84
747-400: .855
777-200: .84
777-300: .85
767-300: .80
757-200: .80
737-700: .785
737-300: .74
N766UA
Sun Jan 11, 2004 10:07 am
737-700s routinely cruise at .81. It is more common to see them above .8 rather than around .77-.78, that's where the MD-80s and older 737s cruise.
dw747400
Sun Jan 11, 2004 11:44 am
I can't vouch for a specific airlines operating policy, but Boeing states clearly, both on their website and through a number of other sources, that the 737NGs cruise at .785. Older models cruise at .74 to .75.
I've also had this verified by pilots at US Airways and Southwest.
BigMac
Sun Jan 11, 2004 1:00 pm
I guess the speed info that is shown on the in-flight info is way off. Was on a 777 just a few days ago and the info said 60X mph. Hahaha...
To fly, or not to fly: that is the question
dc863
Sun Jan 11, 2004 1:18 pm
The Trident was able to travel 600kts.
martinairyyz
Sun Jan 11, 2004 1:22 pm
Can any of the planes mentioned above break the sound barrier?
Chelsea Football Club supporter.
CPDC10-30
Sun Jan 11, 2004 1:29 pm
I know that a DC-8 that eventually went to Canadian Pacific was dived to Mach 1.02 during tests. I don't know about any others.
Keep in mind that the display on the IFE is probably groundspeed, which can be very different from the actual airspeed due to wind conditions
usnseallt82
Sun Jan 11, 2004 3:59 pm
No offense to anyone so far...but my lovely CE-150 pulls a nice 120 kts. on full RPM in a nice tailwind!  Smile/happy/getting dizzy
Cheers!
Crye me a river
