airjampanam
BA #1502 Returns To JFK
Fri Jan 16, 2004 11:38 pm
Does anyone know why a 5:58pm flight from JFK to MAN would return to JFK at 11:23PM in an emergency situation last night?
Hydraulic problem is the reported cause.
I would have thought this flight would have been well over the Atlantic and JFK NOT the airport available in am emergency.
The flight is normally just over 6 hours?
Can someone shed some light?
I did a search but got no hits.
Suing is the new Lotto... if u wanna win u gotta sue!
Demoose
RE: BA #1502 Returns To JFK
Sat Jan 17, 2004 1:26 am
The aircraft was a 767-300, G-BNWH - the aircraft which almost always operates the MAN-JFK route.
Only info I found is this:
The Associated Press
January 16, 2004, 1:28 AM EST
A British Airways flight on its way from New York City to Manchester returned to Kennedy Airport after experiencing hydraulics problems, authorities said.
British Airways Flight 1502 landed safely shortly before 11 p.m. Thursday, according to Tiffany Townsend, a spokeswoman for the Port Authority of New York and New Jersey, which manages the region's airports.
Townsend said about 129 passengers were aboard the plane. No one was injured, she said.
Messages left for British Airways were not immediately returned.
I'm sure some more info will surface pretty soon - strange that it returned to JFK so long into the flight - maybe they wanted to minimise passenger disruption.
Take a ride...fly across the sky
gkirk
Sat Jan 17, 2004 1:30 am
Ah, G-TECH behaving itself again  Insane
Maybe David_itl knows this, but how many problems did G-BNWH have last year?
BCAInfoSys
Sat Jan 17, 2004 1:39 am
A 767-300 with only 129 passengers? That's very discouraging for BA. Are all their loads between JFK & MAN this light?
Militant Agnostic - I don't know and you don't either.
Demoose
Sat Jan 17, 2004 1:48 am
Here's what info is on Amadeus about the flight, seems that it was diverting, then opted to continue, but did actually end up diverting back to JFK?
Make what you will of this:
BA1502-
ESTIMATED TIME OF DEPARTURE 18:00
17:58 LEFT THE GATE
18:21 TOOK OFF
OTHER INFORMATION FLIGHT DIVERTED- CONTACT BRITISH
AIRWAYS FOR FURTHER INFORMATION
OTHER INFORMATION FLT NOW NOT DIVERTING - CONTINUING
20:40 ESTIMATED TIME OF ARRIVAL
22:50 AIRCRAFT LANDED
23:23 ARRIVED
01:30 NEXT INFO WILL BE AT
DIV MAN JFK
AIRCRAFT DEFECTS
PASSENGERS ON BOARD 129
ordpark
Sat Jan 17, 2004 1:56 am
If it had been a true emergency, the crew would have surely set down at the closest airport. Sometimes a crew will elect to return to the point of departure for the convenience of the psgrs and availability of MM. I'm only speculating but I think that may be the scenario here...
airjampanam
Sat Jan 17, 2004 2:00 am
Thank you everyone that posted a response!
I just thought maybe the press got their facts wrong again.
A return 4 hours into the flight?
OK.. Well the mystery remains.
The MAN direct from JFK is once daily, maybe. I'm sure the load factor fluctuates.
Looked fairly light last night.
