Fuel tank locaton
Mon Jan 04, 1999 3:59 am
Can someone please tell me where the fuel tanks are located on the 757 & 767?
RE: Fuel tank locaton
Mon Jan 04, 1999 4:54 am
In there wings.
Iain
Mon Jan 04, 1999 5:21 am
Well not just in the wings. The 767 ER models also carry fuel in the wing center section.
Mon Jan 04, 1999 5:59 am
Thanks guys! The reason I asked was I downloaded a "Delta" 757-200 in their new livery and it had a center fuel tank, main right and left tanks and no aux. tanks. None of the other 57 or 67 I had downloaded had center fuel tanks and I was just curious.
will
Mon Jan 04, 1999 12:13 pm
G'day.
MD-11 is right in saying that there is a centre tank, the only thing to add is that all B767 that l know have a centre tank. The size of the centre tank varies to from , i.e 200 to 200ER or 300ER for that matter. Also the makeup off the centre tank is different to each model. On the the 200 the centre tank is the first three rib placement of the wing structure, and is conected by 3 crossover tubes. On the 200ER, the same three rib stations of the wing structure still apply, but now half of the centre wing structure is a tank with only two cross over tubes. But on the 300ER, the bulk of the centre wing structure is all fuel tank as well as the small part of the inner wing. All B767's each left and right wing tanks each hold 18500KG of fuel, but the centre as you can see varies alot. The 200 holds 13800KG, the 200ER holds 24800KG, and the 300ER holds 36550KG.
Hope this was some help.
See yah.
Will...
airbear
RE: what about the hor. stablizer
Mon Jan 04, 1999 1:12 pm
do any of the extended range versions carry fuel in the horizontal stabilizer?
will
Mon Jan 04, 1999 2:23 pm
G'day airbear.
From what l have seen, it's just air in there. :-) l don't know what Boeing have up there sleeve when it comes to the B767-400 though.
See yah..
Will...
HE
Mon Jan 04, 1999 3:51 pm
Why don't they put Helium in there to lighten the load.
Iain
Mon Jan 04, 1999 10:07 pm
Lets hope they learned from the MD11 that fuel does not belong in the stablizer.
BryanG
hor. stab. tanks
Tue Jan 05, 1999 1:43 am
The 747-400 has tanks in the horizontal stabilzers. I don't know how many gallons each of the tanks contains, but it isn't a substantial amount. Filling those tanks will increase the range by about 500 miles. The 744 was the first mosel to have stabilizer tanks; the classic models did not.
RE: hor. stab. tanks
Mon Mar 08, 1999 7:24 am
400's hold 22,000lbs in the HST.
