BCAInfoSys
Flying MD-90 And MD-80 On Consecutive Days
Sat Jan 17, 2004 2:49 am
Alright guys.. here goes: on March 5th, I'm flying a DL MD-90 from SLC to SEA. Then the next day, I'm turning around and flying an AA MD-80 (Super 80) from SEA to ORD on my way to LHR.
I thought that since I'm flying the 2 aircraft on consecutive days, it would give me a chance to compare the 2 and find their differences. What should I be looking for? What external differences? Internal (Cabin) differences?
Once I get back from the UK in March, I'll be sure to give you a trip report. It should be an interesting one as it involves FOUR airlines and at least that many aircraft types!  Big thumbs up
(DL MD-90: SLC-SEA, AA MD-80: SEA-ORD, AA 777-200: ORD-LHR, RyanAir 737: STN-SXF, EasyJet 737: LGW-Belfast.)
(Note: assume the same airlines and aircraft types in reverse for the return, except for the return on DL SEA-SLC, which will be a 738.)
Militant Agnostic - I don't know and you don't either.
InnocuousFox
RE: Flying MD-90 And MD-80 On Consecutive Days
Sat Jan 17, 2004 2:54 am
"What should I be looking for?"
Uh... one is longer than the other.
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
BCAInfoSys
Sat Jan 17, 2004 2:56 am
LOL.. thx for pointing out the obvious Fox. Are there any other differences I should watch for?
InnocuousFox
Sat Jan 17, 2004 3:04 am
Yeah... one of them has more seats than the other. I can't remember which.
Leskova
Sat Jan 17, 2004 3:09 am
A strange difference, at least on SK, was that one has a 2-3 config, while the other has a 3-2 config - and, being the newer one of both, the MD90 has more modern (and quieter) engines.
Other than that, I couldn't tell any difference...
Frank
Smile - it confuses people!
MerC
Sat Jan 17, 2004 3:11 am
The MD-90 have larger engines compared to the MD-80 series.
It's Scandinavian
akjetBlue
Sat Jan 17, 2004 3:12 am
the 90's eng9nes are massive compared to the 80
Save a horse! Ride a Cowboy!
AAR90
Sat Jan 17, 2004 3:38 am
Internally there is very little difference except what the individual airline(s) chose to install. Externally MD90 differences are: (a) 50% larger engine size, (b) vertical tail extension, (c) two air scoops on fuselage right side [nose gear and wing root] for electrical system cooling. Other than being quieter you probably won't notice much difference.
LMP737
Sat Jan 17, 2004 3:40 am
The MD-90 is five feet longer than the MD-80. The plug is forward of the wing.
FoxBravo
Sat Jan 17, 2004 3:44 am
Some differences you are likely to notice as a passenger: quieter engines, slightly longer, and newer cabin, with drop-down LCD screens.
I had a similar comparison opportunity a few years ago when I flew FUK-KIX on a JAS MD-90, then back on an MD-81 a couple of days later. The -81 sure seemed old and tired!
Common sense is not so common. -Voltaire
Econojetter
Sat Jan 17, 2004 3:53 am
Another external difference is that on the MD-90 the overwing exits are separated by two windows, instead of just one on MD-80s. Have a nice trip.
learjet25
Sat Jan 17, 2004 5:08 am
Performance wise, keep in mind that you will be on the MD-90 from and elevation of 4,000+ feet and the MD-80 will be departing near sea level. The 90 will probably do just as well from the higher elevation as the -80 from sea level. Keep that in mind when you think about your takeoff run and initial climb.
deltaffindfw
Sat Jan 17, 2004 5:21 am
The best thing about the DL MD-90 is the IFE - not found on the 80s.
BUFjets
Sat Jan 17, 2004 6:20 am
Make note of the leg room difference between the DL MD-90 and the AA MD-80. With AA's MRTC, I expect the leg room to be better. Also, AA has newer seats with adjustable headrests. AA MD-80's are my favorite domestic US aircraft.
