MAH4546
AA To Start Same Plane MIA-NRT Service
Sun Jan 18, 2004 9:47 am
Not huge news, but, for the first time, American Airlines will offer daily service between Miami and Tokyo, Japan with no change of plane. The aircraft will stop in Los Angeles.
AA 169 MIA 0800-1002 LAX 1230-1600+1 AA), Japan">NRT
AA 170 AA), Japan">NRT 1615-1015 LAX 1330-2131 MIA
Operates daily with 777-200ER.
Service starts 4 April 2003. American Airlines has offered "direct" Miami-Tokyo service before, first via Seattle and currently via O'Hare, but with change of plane and sometimes terminal, it was anything but direct.
a.
cayman
RE: AA To Start Same Plane MIA-NRT Service
Sun Jan 18, 2004 9:57 am
What is the flying time on that...including the stopover? Would NRT pax be allowed to de-board in LAX?
Otherwise, that would be an unbearably long flight, even in Bus or 1st class....
Interesting though...
FLY777UAL
Sun Jan 18, 2004 10:01 am
NRT passengers, like all US-bound international passengers, must deplane at their first point of entry into the United States.
F L Y 7 7 7 U A L
scottysair
Sun Jan 18, 2004 10:02 am
Why didn't not get chance with nonstop from MIA-NRT? You mean that direct for the 1-stop in LAX and no plane change either. It is still competition of other airlines goes to NRT flight.
BA
Sun Jan 18, 2004 10:24 am
Unfortunately that's the problem with international one-stop flights that stop in the US.
UA had the same issue with DEN-EWR-LHR. You have to deplane in EWR and go through customs, then board the plane again. It's quite a hassle, my sister had to do it.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
aa777flyer
Mon Jan 19, 2004 2:02 am
The schedule was loaded in SABRE last night. Although it is the SAME flight number all the way through, and a 777 all the way through, there will still be a change of aircraft at LAX. The MIALAX will be flown with a 777A (16F 35J 190Y) and the LAXNRT will be flown with a 777P (18F 42J 163Y). So still a have to change in LAX.
The TSA was created to make the post office look efficient!
bobnwa
Mon Jan 19, 2004 2:07 am
BA,
Are you sure the passenger traveling DEN-EWR-LHR has to de-plane to go thru customs? Passengers leaving the US do not go thru US customs. They are probably going thru passport control.
aa777flyer
Mon Jan 19, 2004 2:10 am
bobnwa-
Probably what BA meant was that passengers must deplane in EWR, as the airplane must go through an international security check. No one, not even the crew working the trip can be on the airplane while this is being done.
BestWestern
Mon Jan 19, 2004 2:38 am
International 1 stop services into America are terrible - Delta tried it with a LGW BOS LAX - involved deplaning - immigration - baggage pick-up - Customs, baggage drop - change of terminal - security re-board same plane. Same plane makes no difference.
Greetings from Hong Kong.... a subsidiary of China Inc.
wedgetail737
Mon Jan 19, 2004 10:32 am
A lot of airlines do the 1-stop flying within the US. Delta did it from MCO-NRT, ATL-NGO.
Do passengers have the deplane on QF's LAX-JFK and LAX-ORD flights??? Did they do that with the NZ's HNL-DFW flights (when it happened)?
ConcordeBoy
Mon Jan 19, 2004 10:36 am
Yes.
all international pax (with the exception of pre-screened) must clear customs/immigration at the first point of entry into the USA
MAH4546
Mon Jan 19, 2004 11:05 am
Before September 2001, it was not like that. One reason SAA ended the FLL stop on CPT-ATL was because of the fact that it was too much of a hassle deplaning everybody at Ft. Lauderdale. SAA has been one of the biggest pushers towards ending these rules so that they could resume FLL service, but no luck so far.
a.
BA
Mon Jan 19, 2004 11:15 am
Bobnwa,
Sorry, what I meant to say is my sister flew DEN-EWR-LHR then flew back and while flying back she went through Customs in EWR.
I do not think she deplaned while leaving the US, I will ask her.
aa61hvy
Mon Jan 19, 2004 12:00 pm
I flew LHR-EWR-DFW, you deplane go through customs...
Go big or go home
