VIAF
Fifth Pod?
Sat Jan 24, 2004 6:34 pm
In the 80`s we saw sometimes(mostly 747) with a fifth pod under the wing!
Was this only for carrying or also for tests?If this was only for carrying why they put it not into the cargo hold ?Why we don`t see this no longer?
Photo © Martin Oertle
Photo © Michael Hojbjerg
Any information?
flyinghighboy
RE: Fifth Pod?
Sat Jan 24, 2004 7:33 pm
It does still happen, there is a photo of a QF 747 carrying a 5th engine. However i could be wrong.
It was to ferry the engine to another location on a pax plane. Of course this had an effect on the perforamce but not that much i think.
sevenair
RE: Fifth Pod?
Sat Jan 24, 2004 7:47 pm
Its not that common today,
the air india flight which was bombed off Ireland in the late 1980's was carrying one, which is where I found out abt fifth pods, cant say ive seen one in real life
StarFlyer
RE: Fifth Pod?
Sat Jan 24, 2004 8:41 pm
Here's that photo that was mentioned before...
Photo © Steve Ruttley
Yours truly - StarFlyer
theflcowboy
RE: Fifth Pod?
Sun Jan 25, 2004 12:27 am
I wouldn't say its a daily occurance, but it't not uncommon to see that. I've seen a UA DC-10 with that a while ago. They don't put it in the hold because most of the time, they have all the luggage and mail down there.
I haven't seen them left open like that though. Usually they have a dome over the intake to keep FOB out of it.
MD
A318, A320, A332, A333, B1900, B722, B732, B733, B734, B735, B737, B738, B772, CR1, CR2, CR7, CR9, MD80, MD81, MD82, MD8
Espion007
RE: Fifth Pod?
Sun Jan 25, 2004 1:09 am
is that fifth pod actually used as a fifth engine in flight?And how do they hook it up onto the bottom of the wing?
Snakes on a Plane!
LHR340
RE: Fifth Pod?
Sun Jan 25, 2004 1:13 am
I highly doubt that it is used, it probably spins around due to the force of the wind but that's about all.
LHR340
A340 LoVeR! EC-GQK - LHR The Bussiest International Airport & 3rd Bussiest In The World!
theflcowboy
RE: Fifth Pod?
Sun Jan 25, 2004 1:18 am
They do not use the 5th engine as a functioning one in flight.
There is an assembly that attatches to the wing spar if im not mistaken.
Bolts and duct tape...Lots of duct tape.
MD
n757kw
RE: Fifth Pod?
Sun Jan 25, 2004 1:27 am
The fifth engine is not used in flight. It is used to ferry an engine to another aircraft. The engines (widebody aircraft) will not fit in the lower deck cargo hold due to size. They will fit on the maindeck of Combi or Freighter.
Now many narrow body engines are transported via lower deck hold. KE in ATL would get Air Tran DC-9 engines from New Zealand after overhaul work.
I have seen 747 and DC-10 engines transported to SIN in the maindeck of a B747 freighter. Now a 777 will fit but has be loaded more to center of the aircraft due to size.
N757KW
"What we've got here, is failure to communicate." from Cool Hand Luke
vc10
RE: Fifth Pod?
Sun Jan 25, 2004 1:49 am
In the early 1970's when the original 747s ere having so much trouble with their engines, I remember a 747 stuck in Sydney awaiting a replacement engine. Aircraft witha spare engine in a 5th pod were dispatched from London, but the first one had to use the spare engine itself before it reached Sydney. Luckly things have improved since then. The spare engine is bolted to a hard point, which is built into the wing during manufacture, and many aircraft had them including the B707 and the VC-10 and I am sure there are many others. Things have changed since the days of a picture of a Locheed Constellation [Pan Am ]whose No 4 engine fell off in flight, but landed safely. The damage was considered too severe to be handled by an outstation so the remaining portion of the powerplant was removed back to the wing and faired in. The aircraft then flew on 3 engines from the east coast of the USA back to the west coast for repairs. Needless to say only the minimum crew were on board
Regards little vc10
air2gxs
RE: Fifth Pod?
Sun Jan 25, 2004 1:51 am
The reason you don't see 5th pod as often is the prevelance of wide body frieghters flying around the world.
Also 5th pod was an option and not standard on the jumbo.
Birdwatching
RE: Fifth Pod?
Sun Jan 25, 2004 2:03 am
Here are some more pictures. on the first one, you can see very well how it is installed.
Photo © AirNikon
Photo © Jörg Tegen
Photo © Nicolas Kersting
Photo © Konstantin von Wedelstaedt
All the things you probably hate about travelling are warm reminders that I'm home
Spacepope
RE: Fifth Pod?
Sun Jan 25, 2004 2:19 am
Many early jetliners had the capability to transport a spare engine when needed. This includes the DC-8, DC-10, L-1011, 707 and 747.
Here's a Gulf Air L-1011
Photo © Christos Psarras
And a CP DC-8
Photo © Gary Vincent
707s
Photo © Kjell nilsson
Photo © Alastair T. Gardiner
Can't find a DC-10 pic, but the pod was mounted between engine #1 and the fuselage.
T.J.
