cmckeithen
How Does A Plane Certify To Fly Etops?
Tue Jan 27, 2004 4:27 am
How does a plane certify to fly ETOPS?
DIJKKIJK
RE: How Does A Plane Certify To Fly Etops?
Tue Jan 27, 2004 4:49 am
ETOPS stands for Extended (range) Twin (engine) Operations. So I guess the criteria are
1. The plane must have no more than two engines.
2. It must be able to carry enough fuel to fly the distance.
I should think someone will be able to give you a more technical answer.
 Big thumbs up
Never argue with idiots. They will bring you down to their level, and beat you with experience.
flygmolinafmly
Tue Jan 27, 2004 4:59 am
I do not know much more than DIJKKIJK about this topic but here is a good site with the answer:
http://www.boeing.com/commercial/aeromagazine/aero_07/etops.html
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return.
N79969
Tue Jan 27, 2004 5:07 am
In the US, the requirements for ETOPS (for airplanes and air carriers) can be found at the following website:
http://www2.airweb.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/2638EAF8B89680A8862569BA00751C8C?OpenDocument
