COEWRNJ
Question About NW And DL At DFW
Fri Jan 30, 2004 8:52 am
I have a friend that is coming to TUS to visit me from DTW. He is flying NW from DTW-DFW and then connecting to Delta connection to TUS. My question is are NW and DL in the same terminal at DFW. He has a 53 minute connection time. Will that be enough.. Thanks for the help..
nonrevman
RE: Question About NW And DL At DFW
Fri Jan 30, 2004 8:54 am
Yes, NW and DL are both in terminal E. If flights are all on schedule, then the connection will be no problem. It might be a little bit of a walk between gates, but there will be plenty of time.
nwa man
Fri Jan 30, 2004 8:55 am
Yes they are... DL operates out of E10-E38, and NW leaves from E4-E6. A 20 minute walk at most between the farthest DL gate and the NW gates.
N-Dub
Create your own luck.
AA737-823
Fri Jan 30, 2004 2:28 pm
I will third that comment- he'll be fine. Expecially if he takes the traam. Or does it run the other way? Well, even walking he'd be fine.
R
deltaffindfw
Fri Jan 30, 2004 2:40 pm
You don't use the TrAAin - that is only in the American terminals. You must walk.
COEWRNJ
Fri Jan 30, 2004 2:51 pm
Thanks everyone for the help, much appreciated.. Just for my own reference does CO operate out of E too?
Dave
nwa man
Fri Jan 30, 2004 4:43 pm
Yes... CO just moved to E, and flies out of gates E7-E9. There's also an excellent, new PC at DFW, which I would highly recommend.
N-Dub
