Sjoerd
50 Minutes Enough In AMS?
Tue Feb 03, 2004 9:59 am
In two weeks I'm flying KLM from BRU to AMM with a stop in AMS of only 50 minutes, is that enough ? I've had bad experiences with these things. Thanks.
[Edited 2004-02-03 02:06:39]
Flanders + Wallonnia + Brussels = the UNITED STATES of BELGIUM
KaiGywer
Crew
RE: 50 Minutes Enough In AMS?
Tue Feb 03, 2004 10:30 am
That is cutting it short, but is doable. Depends on where AMM is, I don't recognize the city code. If it's a small plane to a big plane or vice versa, it might be a hike, or even worse if the BRU-AMS part is operated by KLC. Your bags will be tagged SHOCON, and hopefully, read hopefully, you'll get them in AMM.
sllevin
AMS is a fairly large airport, but not so bad you can't get from one point to another in 20 minutes. It always seems longer when you are walking it, though  Smile
Steve
Sjoerd
Tue Feb 03, 2004 10:41 am
AMM = Amman capital of Jordan, they fly a B737 there.
KaiGywer
Crew
Tue Feb 03, 2004 1:23 pm
In that case I doubt it'll be much of a trek at all, since BRU-AMS is most likely operated by a 737, and since AMM is as well, they'll probably be in the same terminal. Plenty of time to enjoy a Heineken  Smile
Jano
Tue Feb 03, 2004 2:51 pm
AMS is a nice airports. In 50 mins, one can go from B to G at least 2 times...
Normally, it takes me about 15-18 mins to go from one of them B70s gates to let say E19. But, I walk fast Big grin
Here is the AMS airport map
http://www.nwa.com/travel/trave/airports/AMS.shtml
The Widget Air Line :)
