ly334
B767-400 Vica Versa B777
Tue Feb 03, 2004 11:05 pm
Hi everyone,
I was just wondering and asking myself where is the real difference between the B764 and the B777 ?
I am not talking about the look, inside cabin etc...
What I mean is the technical differences so as technologies, engines, features, etc...
Except the numbers of the model (B767/B777) where are the changes?
Any answers or ideas ?
ly334
All my toughts are in aviation!!!
Transtar
RE: B767-400 Vica Versa B777
Wed Feb 04, 2004 12:08 am
Major differences. While the 767-400 has a number of engineering upgrades to reduce costs over previous versions, the 777 is an entirely different generation of technology. The basic 767 wing was designed in the mid to late 1970s. The 777's was designed in the late 1980's, early 1990s, and is significantly more efficient. The 777 was completely CAD (computer) designed.
ManchesterMAN
Wed Feb 04, 2004 1:47 am
The 777 is Fly-by-wire the 764 is not. One obvious technological difference.
Flown: A300,A319,A320,A321,A330,A340.A380,717,727,737,747,757,767,777,DC9,DC10,MD11,MD80,F100,F50,ERJ,E190,CRJ,BAe146,Da
ly334
Wed Feb 04, 2004 7:25 pm
OK thanks, now I already know some differences.
Any others?
ly334
MYT332
Wed Feb 04, 2004 8:05 pm
Im sure this is like comparing the A300 to the A330, anyway the engines.
B764:
P&W PW4062 63,300lbs
GE CF6-80C2B8F 63,500lbs
B777:
P&W 4098 97,900lbs
RR Trent 892 90,000lbs
GE 90-94B 93,700lbs
All new engines
One Life, Live it.
united
Wed Feb 04, 2004 9:08 pm
The 767-400
range: 5645 naut. mi (10450 km)
MTOW: 450,000 lbs (204,120 kg)
wingspan: 170 ft 4 in (51.9 M)
length: 201 ft 4 in (61.4 M)
typical speed: .80 Mach
777-200LR
range: 9120 naut. mi (16,983 km)
MTOW: 545,000 lbs. (247,210 kg)
wingspan: 199 ft 11 in (60.9 M)
length: 209 ft 1 in (63.7 M)
typical speed: .84 mach
hope this helps
http://www.boeing.com
The opinions expressed here are mine and not necessarily those of Delta Air Lines.
NLINK
RE: DL And CO The Only Two Operators Of The 767-40
Wed Feb 04, 2004 11:00 pm
The 767-400
List price 126.5 to 138.5 million
777-200 non ER
range: 5210 naut. mi (9,649 km)
list price 153.5 to 171.0 million
ConcordeBoy
Thu Feb 05, 2004 2:18 am
777-200LR
The 772LR's, soon to be world's longest ranged commercial aircraft, range will actually be 9280nm (which outperforms the A345 by 610mi  Big thumbs up); and its MTOW will be FARRRR above 545k lbs my friend....
...or heck, above any twinjet ever made, should a customer demand it  Smile
Adria
Thu Feb 05, 2004 2:31 am
I wonder what happens if those (only) two huge 777 engines fail while flying over the pacific. Then you get the worlds biggest glider
MYT332
Thu Feb 05, 2004 3:03 am
Im all for Airbus, but an A330-200 did that over the atlantic not so far back  Sad
One Life, Live it.
dw747400
Thu Feb 05, 2004 3:09 am
Adria,
World's biggest glider was a 747 with quad engine failure...
CFI--Certfied Freakin Idiot
ConcordeBoy
Thu Feb 05, 2004 4:24 am
...perhaps it should be added because the aircraft ran out of fuel due to ineptitude on behalf of its pilot, and especially, its maintenance crew-- something that would have rendered even an 8-engined B52 into a glider  Insane
MYT332
Thu Feb 05, 2004 4:41 am
It ran out of fuel because it had a fuel leak and the pilots tried to pump fuel from the left tanks into the right. The fuel never made it and went overboard instead, i already know.
If they hadn't have done that wouldn't they still have had one engine?
Regardless it was still a big glider which granted could happen to any aircraft.
One Life, Live it.
ConcordeBoy
Thu Feb 05, 2004 4:47 am
...ever stopped to think *why*? Might have something to do with the maintenance crew placing an L1011 fuel cap/gauge on the A330  Laugh out loud
AA777
Thu Feb 05, 2004 6:15 am
"...ineptitude on behalf of its pilot...."
I would call Captian Pichet (spelling?) a hero. It wasnt his fault that there was a maintenance screw up. He saved hundreds of lives, there is no ineptitude in that. (Mind you, he technically may have made a mistake by transfering fuel into the leaking wing, but he didnt KNOW there was a leak. It was standard procedure to do what he did. AND, even if he hadnt, its likely that they still would have ran out of fuel anyways.) He is certainly a hero in my book, and everyone who was on that flight will agree with me. That I know.
-AA777
DeltaMD11
Thu Feb 05, 2004 11:07 am
"I wonder what happens if those (only) two huge 777 engines fail while flying over the pacific. Then you get the worlds biggest glider" <====what is the likelihood that this would happen? Chances are slim to none. What happens to an A300, A310, A330, 757, 767 if their engines fail in the middle of the Atlantic?  Smile  Big grin
Too often we ... enjoy the comfort of opinion without the discomfort of thought. - John Fitzgerald Kennedy
Thrust
Thu Feb 05, 2004 11:14 am
The Boeing 777 has a much wider cabin, much more powerful and bigger engines, much longer range if an -ER model, is about 9 feet longer, has six-wheel main landing gear trucks. Also, the 777 has a much more 747-like size to it than the 764ER. Also, the 777 has a perfectly circular cross section, whereas the 764ER retains the traditional Boeing "double-bubble" shaped fuselage. In conclusion, while the same aircraft, and while the 777's design was based off the 767, they are two completely different aircraft. Need I say more? The looks, plans, technical specs clearly show a different fairy tale of two different aircraft, brothers borne at the same time by their mother, Boeing Big grin
Fly one thing; Fly it well
