jhooper
Longest Flight: L.A. To Singapore
Thu Feb 05, 2004 6:20 am
CNN is reporting that the longest scheduled flight took off tuesday from L.A. and flew to Singapore. The flight takes 18 1/2 hours.
What airline operates this flight and what A/C do they use?
Last year 1,944 New Yorkers saw something and said something.
AFC_Ajax00
RE: Longest Flight: L.A. To Singapore
Thu Feb 05, 2004 6:21 am
Singapore Airlines on an Airbus A340-500
Once you have tasted flight, you will walk the earth with your eyes turned skyward; for there you long to return
Espion007
Thu Feb 05, 2004 7:32 am
with less than 200 people on board
Snakes on a Plane!
jayspilot
Thu Feb 05, 2004 7:44 am
that must be one high yield route considering the plane has less then 200 passengers and must have a crew of almost 20 including 2 flight crews and is buring 18.5 hrs of jet fuel in 4 engines.
killerbabe
Thu Feb 05, 2004 8:12 am
It is that new ( ?) flight from SQ and the A340-500B are used......
I am wandering how long the flight will continue. It is to long for me and a stop on the route ( Tokyo or Taipei) is a great and better alernative...
SInGAPORE_AIR
Thu Feb 05, 2004 8:21 am
The inaugural flight SQ019 from Los Angeles to Singapore took a flying duration of 17 hours and 38 minutes isntead of the scheduled 18 hours 40 minutes.  Big thumbs up
ConcordeBoy
Thu Feb 05, 2004 8:23 am
The plane could support more... but they have to plan for the flight to New York/Liberty using the same aircraft as well.
AMSMAN
Thu Feb 05, 2004 10:29 am
Would be great to get a diagram on the flight plan??
Anyone??
Aer Lingus, Proud to be Irish.
9v-svc
Thu Feb 05, 2004 11:30 am
The A345-500 SQ19/20 reached to it's destination earlier as expected. That's a good start.
 Smile
Airliners is the wings of my life.
coronado
Thu Feb 05, 2004 1:29 pm
Why would you want to spend 24 hours fliying just so you can walk around like a zombie at Narita for an hour and a half or so. What does that do to improve your health. Especially when the Econ seats thru Narita offer you a 31/32 inch pitch. I would much rather get it over with in 18 hours non stop if I can enjoy a 37 inch pitch and a wider seat.
Way to go SQ. How about bidding for LA -Joburg non stop!!
The Original Coronado: First CV jet flights RG CV 990 July 1965; DL CV 880 July 1965; Spantax CV990 Feb 1973
GuyBetsy1
Fri Feb 06, 2004 8:17 pm
For a brief outlook on the diagram, go to http://www.singaporeair.com and click on the diagram : "Making the world a smaller place" featuring the Airbus A345 Leadership. You will then be directed to another window where you will see the approximate flight paths of SIN-LAX, LAX-SIN and SIN-NYC-SIN.
[Edited 2004-02-06 12:21:37]
FlySSC
Fri Feb 06, 2004 8:35 pm
SQ plans to launch later this year an even longer nonstop flight : EWR-SIN, also with its A345 LeaderShip.
The plane has a 2 class config. with 64 Business (Raffles Class) and only 117 premium Economy (2-3-2 layout).
solnabo
Sat Feb 07, 2004 12:23 am
Wouldnt you like to talk with some of the pax on that flight??
I would! like:- "how did you cope for 14-15(?) hours in a aliminiumtube???
-Did you sleep or mingled with the others" and so on Smile/happy/getting dizzy
Michael//SE
Airbus SAS - Love them both
MD80Nut
Sat Feb 07, 2004 12:41 am
If it takes 24 hours or so to do a one-stop from L.A. to Singapore, then being able to cut that to 18 hours or so is definitely worth it. Especially if you're flying economy, you get a 25% shorter travel time AND wider seats with more leg room and a leg rest. Sounds good to me!
cheers, Ralph
Fly Douglas Jets DC-8 / DC-9 / DC-10 / MD80 / MD11 / MD90 / 717
