LD1,2,3 And 4 Containers
Fri Jan 21, 2000 12:32 am
Hi,
Is there anybody here that could tell me what the dimensions are for the LD1, 2, 3 and 4 containers? Or if you could direct me to the manufacturer to ask the same. I apprerciate it!
Tom
scxmechanic
RE: LD1,2,3 And 4 Containers
Fri Jan 21, 2000 1:00 am
LD-2 Internal Capacity 120 cu ft/3cu m.
Max gross weight 2700lbs/1225K
Dimensions L x W x H = 55" x 41.5" x 62"
139cm. x 105cm. x 157cm
LD-3 Internal Capacity 150 cu ft/4 cu m
Max gross weight 3500lbs/1588K
Dimesions L x W x H = 58" x 57" x 59"
147cm. x 144cm. x 150cm
LD-4 Internal Capacity 194cu ft/5 cu m.
Max gross weight 5400lbs/2450k
Dimensions L x W x H = 98" x 58" x 62"
238cm x 147cm x 160cm
I dont have info on LD-1's But have it on the following...
Main Deck Pallet (aka) IATA Type 2
LD-7
LD-11
LD-8
If you need those not listed, let me know and I will dig them up.
See ya!
Mike
