AMERICAN757
Is it ok to put laptops through the scanner at security?
Mon Feb 09, 2004 3:17 pm
Ok I am bringing my laptop to detroit with me. Is it ok to put it through those scanner things at security and all. I dont need my laptop ghosted again, and want to make sure its safe. This is probably a dumb question but I just want to be safe. Thanks for any help.
HNLFlyBoy
Mon Feb 09, 2004 3:22 pm
AA757,
I travel between the Islands here in Hawaii quite frequently, almost always with my laptop and nothing has happened to it. They usually do a secondary scan of it once it comes out of the main scanner. The only dumb question is the unasked one. It should be fine.
QantasA332
Mon Feb 09, 2004 3:24 pm
Do you think TSA would really make people put their laptops through the scanner knowing that they (the laptops) would be destroyed? Actually, that answer is not as obvious as it seems, looking at it again...  Big grin
Anyway, no, your laptop won't be harmed...I've put mine through many-a-time and it's running beautifully!
qantasA332
AMERICAN757
Mon Feb 09, 2004 3:33 pm
ok, I was just checking, cause I never really payed attention to the whole laptop process. I just got my comp back on thurs and dont really want to have it in the shop again.
Ryan h
Mon Feb 09, 2004 4:36 pm
On a recent trip to sydney I put mine through the x ray machine with no problems
flyingnanook
Mon Feb 09, 2004 5:04 pm
Your laptop will not be harmed. If you want to be extra careful, take your hard drive out of it, keep it in a static free bag, and ask the TSA to hand inspect it. The only danger with laptops in scanners is the hard drive and it should be safe through one while it is still in the computer. Out of the computer and it will be toast if sent through the scanner. At least that's what my laptop manual says.
Semper ubi sub ubi.
usa4624
RE: Is It Ok To Put Laptops Through The Scanner At Security?
Tue Feb 10, 2004 3:13 am
My biggest concern is somebody will steal my laptop. It's quite obvious I have it because it's on a tote all by itself.
I have been on several trips where I have been separated from it while going through security and/or have been distracted by TSA so I could not keep an eye on it.
hawaiian717
Tue Feb 10, 2004 12:54 pm
I have traveled several times with my laptop. You will be required to take the laptop out of it's tote and put it though by itself (usually they put it in a plastic tub). I wouldn't recommend trying to take the hard drive out of the laptop, laptops are pretty tightly packed inside and are more difficult to work in than a desktop computer. From what I once read, the biggest danger to the hard drive in the x-ray machine is actually the motor that drives the belt. I haven't had any problems, but if you're really worried you might want to leave backups of important stuff at home. That's actually not a bad idea to do anyway...
David / MRY
UAL-Fan
Tue Feb 10, 2004 1:17 pm
I was told once that the hard drive is actually surrounded by some sort of shielding to protect it. Mine has been through several hundred times and I'm using it right now. It always works fine.
freshlove1
Tue Feb 10, 2004 1:34 pm
The only thing you have to worry about is TSA throwing them around, I see it on a daily basis and I cant believe how they have absolutely no respect for peoples items. Yes I realize that they may need to look a bit closely at them, but don't drop them back down on the table when your done. I once had a friend have his computer checked by TSA and the girl dropped it back down on the table and he said to her "could you please be a little more careful with it" her response was "if there is something wrong with it and it doesn't work you can file a complaint by calling this number" and she gave him some official TSA complaint number. It worked but its just the point of them not caring.
