ORDnDFW777
Best And Worst Airports For Connections
Fri Feb 13, 2004 11:43 am
I have a good idea of the ones you like and dislike (probably both of my airports).
boeingman
RE: Best And Worst Airports For Connections
Fri Feb 13, 2004 11:47 am
i think the worste airport, to connect inis JFk in new york. all the terminals are seperate. so u would have 2 take a shuttle or something. and maybe frankfurt(germany)thats a bad one. the best airporrt i think to connect in is SFO, or LAX. denver is a good one.
flyingnanook
Fri Feb 13, 2004 12:15 pm
I've never connected in LAX but I've spent a good deal of my life flying in or out of there and I think it would royally suck to connect there if you had to change terminals, especially if you were to go from T3 to T6. (or any terminals on opposite sides).
SEA also is no fun to connect in especially when changing terminals in a manner that you have to pass through security (such as terminal C to B), especially with all the construction going on. The security lines there are longer than I've seen elsewhere lately.
As for one I like, this may sound weird but I have a soft spot in my heart for ORD. I have good memories transitting from the main United terminal to the United Express terminal (sorry I don't remember the terminal letters/numbers) and having to take the underground walkway with the neon lights on the ceiling. For all I know that is gone now since I haven't done that since the early 90's. But I like the memories of it.
Semper ubi sub ubi.
AlekToronto
Fri Feb 13, 2004 12:27 pm
my 2cents in my travel experiences:
Best:
Amsterdam
Zurich
Munich
Copenhagen
Incheon
Hong Kong
Singapore
Dubai
Vancouver
Worst:
London Heathrow
Paris DeGaulle
Los Angeles
JFK
Miami
Sao Paulo
Toronto
NIKV69
Fri Feb 13, 2004 12:28 pm
JFK is bad, I like connecting in Cleveland with CO, nice and easy to find everything..
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
Chi-town
Fri Feb 13, 2004 12:30 pm
MCI is terrible for connections!!!!! I flew MDW-MCI-ABQ-TUS on WN and I had to connect in MCI.
GuyBetsy1
Fri Feb 13, 2004 12:35 pm
Any airport that requires you to exit each terminal and go through security all over again in order to get into another one, is a good example of what a BAD airport is. Then most US airports would count as being bad for connections! JFK definitely takes the cake.
Airports that house everything everything under one roof (a giant one even), is good. HEATHROW may be a little behind the times in transfer methods, but you can still get in and around each terminal with relative ease. Some good European ones are ZURICH, AMSTERDAM, MUNICH, COPENHAGEN and yes, even FRANKFURT.
The Asian airports are what good and well planned airports should be. Namely , SINGAPORE, KUALA LUMPUR, HONGKONG (though it can be confusing given that arrivals and departures are on different levels), BANGKOK (ditto), TAIPEI. The only airport worth mentioning in Australia is MELBOURNE. All other Australian airports have seperate International and Domestic terminals. MELBOURNE is the only airport which has both in one buidling.
SHUPirate1
Fri Feb 13, 2004 12:46 pm
FlyingNanook-I love connecting through ORD (the UA terminal, T1...never connected T1-T2 or within T3 on AA)...it's very straightforward, the connection between the B and C concourses is right in the middle of everything, and, yes, the laser light show in the underground concourse is still there...that said, spending a significant amount of time in the terminal (I spent 8 hours going LGA-ORD-IAH on 12/26, and 6 hours IAH-ORD-LGA on 12/31, due to VDB's) could drive you nuts, although I think you could say that about any airport...
Burma's constitutional referendum options: A. Yes, B. Go to Insein Prison!
B4REAL
Fri Feb 13, 2004 12:49 pm
Good:
CVG
DEN
MAD
GRU
CDG (If on AF family)
SLC
HNL
Bad:
ATL (too big)
ORD (Intl to Domestic - can take long)
DFW (if change terminal - okay if same terminal)
IAH (walk... walk,.... walk....)
Delta767300ER
Fri Feb 13, 2004 12:54 pm
I prefer connecting in ATL for my flights! The layout of ATL w/ its 6 concourses paralell to each other makes it extremely easy! The concourses are linked bu moving sidewalks underground and an underground train. In 2002 I was connecting in ATL to CVG and I had to change concourses and had about 30 minutes to do so and I arrived at my gate without any problems.
-Delta767300ER
ltbewr
Fri Feb 13, 2004 1:03 pm
Although EWR is my 'home' airport, so I don't have to transfer between flights and carriers there, for a multi-terminal building airport has to be among the better ones due to the monorail system that gives quick and frequent service connecting all 3 buildings,although have to go through security check to go to the gates. The new McNamara/Northwest terminal at DTW is very nice too, for transfers within NW, CO and other partner airlines in that terminal with a tram system operating with frequent and quick service from one end of the concourse to the other, and all within the secured gates areas. LRH can be crazy too. I recall transferring in 1995 from a EI flight from Dublin and staying within secured areas to connect to a BA flight to EWR, went through a maze of passageways, and a bus all within the secure areas to move between terminals.
syncmaster
Fri Feb 13, 2004 1:18 pm
From the places i've connected before (not very many) I have this...
Best (in no particular order):
1. ORD
2. DEN
3. CVG
4. ATL
Worst:
1. IAH
NWAFA
Fri Feb 13, 2004 1:20 pm
BEST:
DTW
DEN
SLC
WORST:
IAH
JFK
ORD
DFW
THANK YOU FOR FLYING NORTHWEST AIRLINES, WE TRULY APPRECIATE YOUR BUSINESS!
757KSLC
Fri Feb 13, 2004 6:58 pm
Best: (in no particular order)
SFO
ATL
DEN
PHX
CVG (Having to "take a shuttle to a different terminal" never sounds good, but CVG just makes it so quick and convenient)
Worst: (in no particular order)
LAX (only if changing terminals)
TPA (also only if changing terminals)
LAS (The never ending sound of slots will drive you INSANE after an hour!)
garnetpalmetto
Sat Feb 14, 2004 1:44 am
Best that I've been through:
PIT
ATL
Worst:
JFK
IAD
South Carolina - too small to be its own country, too big to be a mental asylum.
Boeing757/767
Sat Feb 14, 2004 1:48 am
DTW is the best I've experienced.
Free-thinking, left-leaning secularist
amhilde
Sat Feb 14, 2004 1:49 am
LAX isnt THAT bad to connect at- and the chances of one having to haul ass across the terminal arent that high- though I have had to do it before. But at least you can TELL where the other terminal is and can almost see it- some airports you have to read the map about 4 times to figure out what you are doing.
SEA was HORRIBLE last year because you do have to go in and out of security. I had to leave security just to get to a cash machine!
VIE is a little weird- I was transferring to an eastern Europe flight and came in off of a big jet on the top of the airport, then had to proceed through customs or whatever that was and then go down some back stairs somewhere to the "going to eastern europe" lounges- felt like I was at a GA airport with the ugly chairs and this big room with windows right on the tarmac with a bunch of people smoking and a naive religious group from the States making a fuss about the smoke ( I looked at the average ass size, then at the planes on the tarmac, back to ass size, back to planes, and wondered at exactly HOW they were going to fit this group on to one tiny little aircraft going to Bucharest, not to mention marvelling at the global transportation system that allows me to travel 8000 miles from my home only to be stuck in yet another small space with Hix from the Stix). Then a bus comes up and drives you over to your tiny little aircraft which is one in two long rows... basically there is no escaping from the "Going to Eastern Europe" room, and there is a minimal bathroom and a soda machine!
Best:
CPH
LAX
PHX ( even though I think its not a fun airport, its still pretty easy)
More worst:
DFW ( cmon, weve ALL done the DFW run!)
LHR ( can get a little difficult if you have to transfer terminals)
Hang on tightly, Let go lightly
JGPH1A
Worst:
LHR - by MILES
JFK
BOS
MIA
LAX
DFW
Better:
SIN
CDG (not between T1 and T2 though)
ZRH
PIT
CLT
LGW
STL
Best
AMS
FRA (although sometimes the walk can be long !)
MEL
ATL
CVG
Young and beautiful and thin and gorgeous AND BANNED ! Cya at airspaceonline.com, losers
rducky
Sat Feb 14, 2004 1:55 am
Having just finished a flight from MCO-MIA-CLT on AA, I must say MIA is not an airport I would look forward to connect through, I will avoid it because of the construction that is ongoing, but I will add as soon as it is finished that will be my airport to visit. I've seen pictures of the final product it will be gorgeous. As for the best airport used for connecting in my opinion it would be CLE.
Rducky
Up Up and Away
LHR340
Sat Feb 14, 2004 1:58 am
I've only connected through MAD and I think its easy! But you have to walk a lot!
LHR340
A340 LoVeR! EC-GQK - LHR The Bussiest International Airport & 3rd Bussiest In The World!
CKT789
Sat Feb 14, 2004 2:00 am
AMS by a long shot, just so easy and relaxed.
LGW is OK, although I don't see why I have to have my baggage screened again after coming off the plane and going to the departure lounge?
amrapCLE
Sat Feb 14, 2004 2:10 am
Best:
MUC
BNA
SLC
AMS
Worst:
MIA
FCO
ATL
col
Sat Feb 14, 2004 2:31 am
Europe
Best
MAN
AMS
Worst
LHR
FRA
USA
Best
PIT
DTW
Worst
JFK
LAX
Asia
Best
SIN
HKG
Worst
NRT
SHA
juanchie
Sat Feb 14, 2004 2:56 am
I would have to say ATL and CVG are two good airports to connect through. ATL Is extremely easy to get around except when the subway is down when you have to walk a good mile and a half. I had a connection a few months back in CVG and my second flight left 10 min after I arrived and I still made it. Its a nice airport and easy to maneuver.
God, forgive me for who I am, and help me be the man I want to be.
