Cory6188
EWR Runways
Sun Feb 15, 2004 5:52 am
Does EWR ever change the configuration of their runways. I fly out of EWR often, and it seems as if 4L is only used for takeoff, 4R is only used for landing, and 11-29 is never used for anything. Why is this?
theflcowboy
RE: EWR Runways
Sun Feb 15, 2004 5:54 am
Keep in mind, the runways in use at EWR are based on the actives at LGA and JFK. It might be that 11-29 doesn't allow for an arrival or departure during certain wind conditions because it might bring planes through the flight path at the other 2 airports.
MD
A318, A320, A332, A333, B1900, B722, B732, B733, B734, B735, B737, B738, B772, CR1, CR2, CR7, CR9, MD80, MD81, MD82, MD8
JAL777
RE: EWR Runways
Sun Feb 15, 2004 5:55 am
They use all the runways and often.
DC3CV3407AC727
RE: EWR Runways
Sun Feb 15, 2004 5:56 am
actually 11/29 is used on really windy days for landings,when the crosswind is just too much for the 4/22s. it is only 6800 ft long,and is good for loaded takeoff s for 727 size aircraft at best.
the rumble of round engines is like music to me,likewise the thunder of thr JT8D
deltairlines
RE: EWR Runways
Sun Feb 15, 2004 6:15 am
I have seen 11 used quite a bit toward the end of July. I have family out in the Summit area, right under the approach for 11. Some days, I just sit out in their back yard and watch Continental 737s come in every couple minutes.
Jeff
lga1011
RE: EWR Runways
Sun Feb 15, 2004 7:06 am
Cory6188 - The reason why 4R is uses for take-off and 4L for landing is not just for ERW, every airport that has parallel runways uses that method. So if you turn around then 22L would be used for take-off and 22R for landing, its always the runway closer to the terminals is the one for take-offs.
N323ER
RE: EWR Runways
Sun Feb 15, 2004 7:14 am
An Airport uses certain runways becuase of wind not because of other airport in the surronding area. If EWR is landing and departing on 4L/4R then LGA and JFK will more than likely have the same wind conditions and if i am not mistaken both JFK and LGA have runways 4's
RYAN AIRTRAN(BWIOPS)
RYAN SCAIFE
Cory6188
RE: EWR Runways
Sun Feb 15, 2004 7:36 am
The only reason that I could think of for 4L being used for takeoffs is because it is 11,000' long and 4R, at 9,900', is used for landings because airplanes don't need as much space to land. However, I know I may be totally wrong.
N323ER
RE: EWR Runways
Sun Feb 15, 2004 7:39 am
4L is for t/o because it is closer to the terminal. But they are times when the widebodies request land on the left side
RYAN SCAIFE
tjwgrr
RE: EWR Runways
Sun Feb 15, 2004 9:30 pm
The inner parallel 4L/22R is used for takeoffs otherwise all traffic in queue for departure would need to cross the approach end of the active parallel. EWR often has 15-20 aircraft in queue for takeoff.
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
cicadajet
RE: EWR Runways
Sun Feb 15, 2004 10:26 pm
Is 1/29 one of the original runways for EWR? If so, I believe TWA 707s (bound for New Mexico?) used to use it for departure on occasion amongst others... can't recall any wide-bodies doing it though.
flybhx764
RE: EWR Runways
Sun Feb 15, 2004 11:37 pm
When I flew in one from BHX to EWR on the 752, we were put on gridlock, had to circle in the sky for an hour till the landing time, however, instead of waiting an hour, it only took 15 mins because we landed on 11. Thought i was gonna miss my connection but luckily never.
DCA-ROCguy
RE: EWR Runways
Mon Feb 16, 2004 12:53 am
Once in January 1987 I watched a Delta DC-8-71 take off from 29, I was surprised to see a heavy depart from that short, DCA-length runway. The 8 leapt airborne pretty quickly so it couldn't have been too heavily loaded. I was aboard a Piedmont 737-300 that took off from 29 that same morning.
Jim
Need a new airline paint scheme? Better call Saul! (Bass that is)
andrej
RE: EWR Runways
Mon Feb 16, 2004 2:27 am
Hello all,
RWY's 4L and 22R are used for take off. For 22R they ususally depart from "Whisky" Intercpetion, so they do not have to cross RWY29/11
These RWY's are longer and also, departing planes do not have to cross active RWY.
Regarding 29/11. When 22L is used for arrivals, many regional jets ask to arrive on RWY 29. THis is due shortened taxi time. COA RJ park alongside Terminal C.
When RWY4R is used, RWY11 is used as well. It is nice when one drives on Route 1/9 and you see ERJ to land infront of you!!
Andrej
pecoua
RE: EWR Runways
Mon Feb 16, 2004 3:15 am
I was a Flight Attendant for PEOPLExpress and I remember on a few windy days we would take off towards the west on either 11/29 (whichever it was) on a 747-200 to SFO and LGW. So the runway has to obviously be long enough...I do remember a very long engine spool-up before brake release though...the Captain would always tell us of this special takeoff since it was a bit different.
Hope this helps.
STT757
RE: EWR Runways
Tue Feb 17, 2004 1:01 am
EWR's runway 11/29 gets used on a daily basis, however they get more use out of it on windy days.
I've seen 747s, A340s, 777s landing on 11/29.
They also use it for departures, again mostly on windy days.
cha747
RE: EWR Runways
Tue Feb 17, 2004 1:15 am
Is 11/29 the runway that is perpendicular to the New Jersey Turnpike? On several occassions, my wife and I have been driving and from a distance, it looks like the planes that are passing over the turnpike are about to hit one of the onramps. Of course, it's an optical illusion and the plane lands safely....but those planes are pretty low...when you're driving south on the turnpike and you see a plane approaching dead at you from the left, it tends to make you...well...tighten a sphincter or two.
You land a million planes safely, then you have one little mid-air and you never hear the end of it - Pushing Tin
cadet93
RE: EWR Runways
Tue Feb 17, 2004 1:27 am
I was on the way to the airport on Saturday and looked up and saw a 767 approaching. It went wide and turned and landed on 11/29. It is a real nice sight to be driving and see the large planes cross over the turnpike and land.
Newark was using that runway a lot last year as they resurfaced one of the major runways.
STT757
RE: EWR Runways
Tue Feb 17, 2004 1:29 am
Check out the height of the lamp posts on the Turnpike near exit 14, the are little stubs to avoid striking aircraft.
STT757
RE: EWR Runways
Tue Feb 17, 2004 7:46 am
"Report Questions Region's Air Traffic Safety
Feb 15, 2004 9:17 pm US/Eastern
HACKENSACK, N.J. (AP) Funding cuts, understaffing and changes that would increase the number planes in the sky could compromise air traffic safety at New Jersey's airports, according to a published report.
Already, there were 19 incidents last year in which planes flew too close to one another in the skies above the New York metropolitan region, which includes Newark and Teterboro airports. There were 20 such incidents in 2001 and 24 in 2002, according to a report in The Record of Bergen County.
Federal Aviation Administration officials said the incidence of what it calls "loss of separation" is low when compared to the total number of aircraft operations handled by the regional monitoring centers -- about 2 million per year.
"When you put it in context to the total number of operations, statistically it represents a very small number," FAA Eastern Region spokesman Jim Peters told The Record.
Russ Halleran, an air traffic controller at Newark Airport, held a different viewpoint.
"The flying public is not aware," he said. "It is not a safe thing. We are not here blowing smoke. The FAA says everything is OK. Everything is not OK. We are kind of in a state of chaos at the moment."
Many air traffic control towers are understaffed and relying on overtime to do the job. At Newark, the tower is designed to have 40 controllers available but has only 34.
President George W. Bush has proposed cutting 13 percent from the Federal Aviation Administration's budget for upgrading air traffic control equipment. A new tower opened at Newark last year, but towers at La Guardia and Teterboro airports need to be rebuilt. Construction at La Guardia is scheduled to begin later this year, but could be affected if the reduced budget is approved.
The FAA is also proposing next year to tighten the spacing between in-air jets in order to get more planes in the sky and cut down on departure delays. Planes flying between 29,000 feet and 41,000 feet would need to have a vertical distance of 1,000 feet between them instead of the current 2,000 feet.
Pilots and controllers said the tighter spacing won't have a great effect at cruising altitude, but could make for more congestion on approaches and landings. FAA officials said they would hold traffic at the higher altitudes if there wasn't enough space below.
Halleran was skeptical that the new regulations could increase the number of planes landing in Newark, which currently can handle about 120 per hour.
"A lot of these airplanes at Newark are rolling down the runway and that next guy is right up your rear end," he said. "They are not going to be able to get threefold more airplanes into Newark. That's not going to happen."
http://www.wcbs880.com
Cory6188
RE: EWR Runways
Tue Feb 17, 2004 7:53 am
There was an article on the front page about the New York area's crowded skies from Sunday's The Record for any of you who get the paper.
nycfuturepilot
RE: EWR Runways
Tue Feb 17, 2004 8:10 am
I flew out of EWR about a month ago on a very busy day and 22R was being used for take offs and landings and 22L and 11 were being used for landings but 11 had much less traffic than 22L and 22R.
-NYC
Father, Son, HOYA spirit
kbuf737
RE: EWR Runways
Tue Feb 17, 2004 8:23 am
Heavy's do use 11/29 at EWR. Crosswinds have to be quite intense I believe.
Photo © Carlos Borda
- 747 on 11/29! Hit those Brakes!
- Hehe Funny!
The tower? Rapunzel!!!!!!
timz
RE: EWR Runways
Wed Feb 18, 2004 10:08 am
It's almost common for heavies to land on 29-- but do they ever land on 11?
Props depart 29, and occasionally jets-- but does anyone ever depart 11?
