NW747-400
DL Connection At JFK
Thu Feb 26, 2004 11:25 am
Hey all - I bought a ticket a few weeks ago to go home for spring break and it wasn't until I went to choose my seats on Delta.com that I realized I had booked an itinerary that requires a plane change at JFK rather than CVG or the usual ATL.
Anyway, I have an hour to change from a 757 to a Dornier 328 Jet, and I am just wondering what the connection will be like from the main DL terminal to the DL Connection terminal.
Thanks for any info!
rockyracoon
RE: DL Connection At JFK
Thu Feb 26, 2004 11:37 am
Unless I'm mistaking, there aren't seperate DL terminals at JFK.
peace
Airports: CVG PIT MWO PHL PIT PHX ORD DCA MIA TPA MCO ATL DTW DFW SJC LAX DEN SLC LAS HNL LIH OGG YVR MUC ICN NRT PVG SHA SZX MNL PPS CRK BKK DMK KBV EOH MDE CLO CTG SMR BOG ACD MEX CUN MID
NW747-400
Thu Feb 26, 2004 11:39 am
There are sort of seperate terminals, connected only by a walkway closer to the ticket counters.
flyguy1
Thu Feb 26, 2004 11:46 am
I think it depends on the gate your flight arrives at, departs from. You may find both in the same terminal, or the flights could depart from seperate terminals. In any case, their is a walkway between terminals, making it easy to move from one, to the other.
727, L1011, MD80, A300, 777-200, 737-300, 737-700, 747-400, 757-200, 737-800, A320. E190, E135, 767-200, CRJ9
B4REAL
Thu Feb 26, 2004 11:50 am
They have separate terminals, each with their own concourse, but you can get to/from each no problem. And, travelling on a DoJo, your ground time is short (boarding/deplaing/luggage, etc.), so you should be fine.
navairjax
Thu Feb 26, 2004 12:06 pm
DL operates out of the interconnected terminals 2 and 3 at JFK. It is essentially considered a single terminal as terminal 2 gate numbers are a continuation of the numbers beginning in terminal 3.
