YV136C
Ted Using A319's? Something Weird Here!
Fri Feb 27, 2004 2:11 pm
Hi,
I was looking for flights from FLL to SJC in July and the cheapest turns out to be Ted-United connecting in DEN. But both Ted flights (# 1401 FLL-DEN and #1400 DEN-FLL) appear as being operated by A319-321 (???)!! I'll bet no one has seen A319-300 before, huh? What is this, a prank?
By the way this shows up on Expedia....weird! On United.com it shows as being flown on a A32S....
Luis
YV136C
Proud to work for Embraer FLL!
DeltaGuy
RE: Ted Using A319's? Something Weird Here!
Fri Feb 27, 2004 2:13 pm
Blame Expedia.......TED and UAL for that matter don't have anything but A320's.
Fun stuff......99% of the general public wouldn't have known the difference.
DeltaGuy
AJ
Fri Feb 27, 2004 2:17 pm
United does have A319s, but they're -100 series!
Photo © Carlos A. Morillo Doria
sllevin
Fri Feb 27, 2004 2:45 pm
Let us know when you are out here...I work across the street from SJC -- if you've got a 300mm lens you can get some very clean shots of the north ramp.
Steve
TWA902fly
Fri Feb 27, 2004 2:47 pm
judging by what you wrote...
A319-321 i would assume anything between A319 to A321 which is the whole A320 family ex A318...
TWA902
life wasn't worth the balance, or the crumpled paper it was written on
YV136C
Fri Feb 27, 2004 2:52 pm
Steve,
Let you know when I drop by, my brother lives very near SJC (Willow Glen, is it?) but he's not into aviation that much.
TWA902,
that assumption would be acceptable if Ted flew anything else that wasn't A320's. UA flies A319's and A320's but no A321's......
Luis
YV136C
B757capt
Fri Feb 27, 2004 3:09 pm
A319-321 translates to "Airbus 319 equipment or similar type to Airbus 320 or similar type to Airbus 321." - from the sabre reservations system
The views written by this user are in no manner the views of my employer and should not be thought as such.
YV136C
Fri Feb 27, 2004 11:19 pm
B757,
thanks for the explanation but that sure sounds confusing!
Luis
YV136C
InnocuousFox
Sat Feb 28, 2004 12:52 am
I fly a lot of Airbii on United. In fact, going to SJC again this year (Game Developers Conference) in late March. There is a great park south of the field where you get a lot of overflys!
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
FutureFO
Sun Feb 29, 2004 10:02 pm
On occaision some booking sites will show the a/c type 32S. But the websites that show the type for UA/Ted would show the a/c type specifically especially when you book your seats on a seat map.
Sean from MCO
I Don't know where I am anymore
FlySSC
Sun Feb 29, 2004 11:58 pm
AJ,
unlike the A320 & A321 , I believe that ALL the A319 in service are -100...
YV136C
Mon Mar 01, 2004 2:54 am
Future FO,
the A32S designation appears on United.com, not just any booking site. What does the "S" stand for anyway?
FlySSC,
correct, all A319's are -100 series.
Luis
nwa man
Mon Mar 01, 2004 3:14 am
I believe A32S refers to an A320 with Ted's seating configuration - that is, 60 Economy Plus seats and 96 regular coach seats.
N-Dub
Create your own luck.
star_world
Mon Mar 01, 2004 3:24 am
No it doesn't, I believe 'S' just means 'series' - I've seen this on many airline reservation systems in the past, it's used when the a/c type can be any of the A32x series.
Art at ISP
Mon Mar 01, 2004 3:36 am
United is using 32S as the aircraft code for the A320's operating for Ted (single class). Since the OAG's code 32S refers to the Airbus 320 Series, which can range from the 319 to the 321, it is likely that this other service is indicating that the aircraft can range from one to the other, or 319-321. I doubt that Expedia knows that 32S has unique meaning with United since if not mistaken Expedia works off Sabre, not Apollo.
Just my thoughts......
