wannabe
Airports With Operations On Intersecting Runways
Fri Mar 05, 2004 3:29 am
Other than LGA, what other airports are there that have a traffic volume of similar size and use intersecting runways in the way LGA does? There is nothing like the feeling you get as you roll down RWY 31 while watching an inbound flight to RWY 22 clearing the approach lights on it's way in. The ATC crew must take ballet lessons for the work they do.
crjdispatchkid
RE: Airports With Operations On Intersecting Runways
Fri Mar 05, 2004 3:33 am
ORD will generally use 27R and 22R for arrivals. 22R will LAHSO (Land and short of) 27R. I'm not sure if they use either for departures though, they might just use the south side of the airport for departures (27L, 22L)
Thanks...C-Ya...Bye
flygmolinafmly
Fri Mar 05, 2004 3:41 am
Charlotte-Douglas (CLT) has intersecting runways. When runway 18L and 18R are in use for example, they use runway 23 which interesects runway 18L. The will do takeoffs on runway 18L and do landings on 23 while runway 18R does both takeoffs and landings. Very good system that have. Any more?
Gabriel Molina
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and there you will long to return.
wilco
Fri Mar 05, 2004 3:45 am
Regular ops at SFO (how often is that?!?!) would have parallel departures on 1L and 1R with parallel arrivals on 28R 28L.
"Ever seen a grown man naked?"
Fri Mar 05, 2004 3:54 am
ARN had, until recently, ops on both 01/19 and 08/26 simultaneously. They don't quite meet, but the 01 and 26 points are pretty close to one another, so for ATC purposes I believe they are intersecting.
In the morning, it would most often be departures on 08 and arrivals on 01. Since 08 starts slightly east of 01, no problems there. However, in the evening, it would frequently be arrivals on 26 and departures on 19, which of course could slow things down since arrivals need space to go around. To further complicate things, heavies sometimes asked for 01/19 since it is longer.
Since 2003, there are three runways: 01L/19R, 01R/19L and 08/26 so this problem has been solved. Also the new runway is better for the NIMBYs.
this pic shows the layout 01L/19R runs on the left of the pic, 18/26 across the pic, 01R/19L is barely visible on the right (only the end).
Photo © Staffan Hardie
sbarylick
Fri Mar 05, 2004 4:06 am
Boston-LAHSO constantly-
Examples-
Take-offs on 9
Landings on 4R, Heavies Taking off on 4R
Take-offs and Landings on 4L-commuters
and 73's, 75's 320's etc.
Landings on 22L
Take-offs on 22 L and R
Landings on 27
Take-offs on 27 between landings on the 22's
desertjets
Fri Mar 05, 2004 4:44 am
BWI is another that uses intersecting runways simulataneously.
Some combo of 33L/15R and 10/28 will be used for almost all commericial traffic, with GA and turboprops using 33R/15L.
MIA777
Fri Mar 05, 2004 5:11 am
MIA's runway 12/30 and 9R/27L (soon to be just 9/27) intersect at the end of each of the runways. I doubt that there is any chance of collision because 9R/27L is +/-13,000 feet but the controllers are still somewhat cautious...
MIA777
N323ER
Fri Mar 05, 2004 5:25 am
KBWI runs intersection operations every day. When t/o on RWY 10 they are landing on 33L when t/o on 28 lanfing on 15R when t/o on 33L landing on 10 etc
RYAN AIRTRAN(BWIOPS)
RYAN SCAIFE
ConcordeBoy
Fri Mar 05, 2004 5:30 am
MSY's Rwy10's pavement and direction intersect with Rwy1/19 (though, not the designated runway itself)... the former being by far the primary arrivals runway.
Lubicon
Fri Mar 05, 2004 7:07 am
Calgary YYC also does.
16-34 is the main N-S runway and they will use 10-28 as well.
potomac
Fri Mar 05, 2004 7:26 am
actually, to correct/add to N323er, BWI typically lands 33L and departs 28, or lands 10 departs 15R.
DCA also has the intersecting ops, with most jets landing and departing 1/19, and turboprops landing and departing 15/33, 22/4 (in good weather)
goingboeing
Fri Mar 05, 2004 7:34 am
MCI will occassionaly allow takeoffs from runway 9/27. Nothing regular though - most options are on runways 1/19.
USAFHummer
Fri Mar 05, 2004 7:37 am
PHL does this as well...takeoffs on 27L, landings on 27R, and landings on 17 or 35 (which intersects (9L/27R)for commuter and small mainline aircraft (717 and 732 are the largest Ive seen use 17/35 for arrivals)
Greg
FlySSC
Fri Mar 05, 2004 9:39 am
In Europe, Barcelona-BCN airport operates on 2 intersecting runways...
AMS has also intersecting runways...
Paris-Orly has also a 02/20 Rwy that "cut" 08/26, though the 02/20 is now very rarely used...
rthrbeflying86
Fri Mar 05, 2004 9:49 am
Lately at PHL, 737's and A32X's have been landing regularly on 35 (even with calm winds). It seems like a lot of plane for a 5600' strip, but I guess it avoids 27L arrivals. Runway 35 intersects 27R (mainly arrivals) but not 27L (departures). They had been shifting some landings over to the left side, but not so much anymore. No one wants to taxi that long back from the east end of 27L, nor do departures want to wait for the landings.
Dan
I'd rather be flying.
