JNCVH
New HONDA/GE HF-118 JET
Sat Mar 06, 2004 2:47 pm
Would any one have any pictures of the new Honda/GE 4-8 pax jet that is being tested at the Piedmont Triad Airport in North Carolina? Very interested in what this jet may look like.
JVH
N243NW
RE: New HONDA/GE HF-118 JET
Sat Mar 06, 2004 3:11 pm
Hi there,
I hit the jackpot here. Big thumbs up From Honda's website, pictures, specifications, and even a cool flight test video!
Flight Tests of Honda Experimental Business Jet Begin
Tokyo, December 16, 2003 --- Honda Motor Co., Ltd. announced today that the HondaJet, its new experimental compact business jet equipped with Honda-developed HF118 jet engines, successfully completed initial flight tests this month at Piedmont Triad Airport in North Carolina, US.
Compared with conventional jets, this experimental aircraft offers superior fuel efficiency and remarkable cabin space. The engines are optimally positioned on the upper surface of the main wing in a unique configuration that reduces drag at high speeds and increases cruising efficiency. This layout also eliminates the need for structural engine mounts in the fuselage, creating over 30% more cabin space than in a conventional aircraft.
The fuselage is a compact and lightweight co-cured carbon composite structure, yet realizes the largest cabin in its class. The main wing, which features aluminum skin panels formed from single sheets of aluminum that provide a smoother surface than conventional wing configurations, along with Honda's proprietary turbulence-reducing laminar airfoil, work together to significantly improve aerodynamic performance. Additional drag-reducing technologies include the fuselage nose, which is designed to generate laminar flow. These features, in combination with Honda's fuel-efficient HF118 Turbofan Engine, achieve fuel efficiency over 40% higher than conventional aircraft.
This experimental aircraft is also fitted with a state-of-the-art glass cockpit with an integrated avionics system, as well as an autopilot function, anti-icing equipment, and other systems. The jet is scheduled to undergo approximately 200 hours of flight-testing to demonstrate and verify the operability and performance characteristics of its various systems.
Honda began research into compact business jets in 1986, using engines provided by other manufacturers. The HF118 Turbofan Engine-equipped HondaJet experimental compact jet is the first Honda-developed aircraft to be outfitted with a Honda engine, a significant milestone for the company and the industry.
Here's the site: http://world.honda.com/news/2003/c031216_2.html
Cheers!
-N243NW Big grin
JNCVH
Sat Mar 06, 2004 4:33 pm
Bonus
I appreciate this. This is exactly what I am looking for.
jvh
MD-90
Sat Mar 06, 2004 5:27 pm
View the evolution.
Honda's (and Mississippi State's) first jet:
dragon-wings
Sat Mar 06, 2004 5:37 pm
Looks like a cross between the Premier 1 and the Hawker 800 (and the wings of a learjet 45)
Don't give up don't ever give up - Jim Valvano
