jsnww81
Singapore Changi Expansion/Construction?
Wed Mar 10, 2004 12:11 am
I'm curious about the expansion of Changi Airport in Singapore... in several of the airport overviews, you can see a HUGE reclamation project underway, adjacent to Runway 2R-20L, along with the outline of a third parallel runway under construction.
I know that Changi is building Terminal 3 in the central terminal area, but what is the status of this land reclamation and third runway? It appears to be very widely spaced from the other two runways - are there long-range plans to eventually add a second major terminal complex in between the new runway and the original airport?
Thanks for any information you can provide!
hailstone
RE: Singapore Changi Expansion/Construction?
Wed Mar 10, 2004 12:17 am
the runway on reclaimed land you refer to is operational since quite a while, but not for changi airport - it is used for support to changi naval base, which was built along that plot of reclaimed land.
the new fire station along 2R/20L has also been built about 18 months back is adjacent to the airport perimeter road.
no idea if additional terminals will be built in between, though
