catholic2006
What is the difference between the B737-300, -400 etc
Tue Mar 16, 2004 2:51 am
Okay, can someone help me understand this...??
What is the difference between the Boeing 737-300 and the 737-500???
What do those numbers mean (300, 500, 700, etc.)???
Why is the 737-300 longer than the 737-500, when the 737-400 is longer than the 737-300??? This is so confusing. But could be interesting tho. Let me know.
-Chris
Ne vous inquietez pas. Je ne vous hais pas . . . . encore, mais faites attention !
jhooper
Tue Mar 16, 2004 2:54 am
-200, -300, -800, etc. is just the series designator. The -200 series, for example, are older generation models, while the -800 series is a Next Generation model.
Last year 1,944 New Yorkers saw something and said something.
catholic2006
Tue Mar 16, 2004 2:58 am
Ohhhh, okay!
thank you.
so it really doesn't have anything to do with size?
J/w cuz i always found that interesting why plane models are like that.
thank you very much!!
-Chris
Boeing757/767
Tue Mar 16, 2004 3:01 am
It has to do when it came out, really.
the -100 was the original 737. Then came the venerable -200. The -300 was next, followed by a stretched -400 and a shrunken -500.
Free-thinking, left-leaning secularist
Tue Mar 16, 2004 3:14 am
The 737s are generally classified in three generations:
"Original". First flight 1967.
737-100 (baseline)
737-200 (stretch)
"Classic" with the new engines. First flight 1984.
737-300 (baseline)
737-400 (stretch)
737-500 (shrink)
"Next Generation" with new wing, even newer engines, new avionics... First flight 1997.
737-600 (shrink)
737-700 (baseline)
737-800 (stretch)
737-900 (streeetch)
737-900ER (proposed 900 with longer range).
Size does matter  Big grin when it comes to the series designator, but the 737 has been around for so long and through so many permutations that look and feel similar that it easily gets confusing. The reason that the Classic shrink (500) has a higher sequence number than the 300 and 400 is, IIRC, that it was not originally envisioned as part of the program.
For much more detail, checky here: http://www.airliners.net/info/
phollingsworth
Tue Mar 16, 2004 3:16 am
Well, sometimes it has to do with size, and other times not.
the -200 is longer than the -100, the -300 is longer than the -200, and the -400 is longer than the -300. Of course time of launch is the real determent. the -500 is basically a -200 replacement. The -6/7/800 were created with in short order of each other, so it was sensible to label them in size order. The -600 is the NG version of the -500, the -700 corresponds to the -300. The -800 is larger than the -400. The -900 came even later and is the longest of all. Boeing has typically numbered their airplanes in the order in which the program was started, i.e the 757 was started before the 767 even though the 767 went into service first. This may change with the 7E7 which depending on the version that comes out first may have a -300 and then a -200, or some such.
Tue Mar 16, 2004 3:23 am
And to further add to the confusion...
Although you rarely see it outside enthusiast environments like A.net, the last two digits (00) are used for customer code (Boeing) and for engine type/airframe subvariant (Airbus). For example, Lufthansa is "30" at Boeing, so their 747-400s are actually 747-430s.
Confused yet?  Smile/happy/getting dizzy
Tue Mar 16, 2004 3:45 am
Dont feel bad - I heard this - about 747s
xxx
747-100 is small (as small as 747SP, did not say)
747-200 is bigger
747-400 is biggest
xxx
757 is bigger than 747 (bigger number)
767 is bigger than 757
777 is bigger than 767...
xxx
Manufacturers: please use "bigger numbers" for "bigger airplanes".
That is the general public I.Q. -
xxx
So Mr. Airbus, please note - 300, 310, 320, 330, 340, 380...
The 300 is small, then 310 bigger, and 320 even bigger, etc...
xxx
So nice that it comes from people that know that -
100 is less than 200, which is less than 300...
And "they" even have to use their fingers, when over three...
On my tombstone, write "he was frustrated with mankind's stupidity"
xxx
Happy contrails  Smile
(s) Skipper
Tue Mar 16, 2004 3:55 am
Skipper, did you make it your mission to make me laugh uproariously today. If so, you're doing a good job Big grin
Maybe the SP did not sell too well because it was hard to classify in the mind of your 'General Public'. "What, no number?"
DfwRevolution
Tue Mar 16, 2004 4:28 am
I can see how this is confusing, especially for the 737. The number means both fuselage length, generation type, and customer. I'll try to consolidate what everyone has said into one summary.
Take this Southwest 737... Boeing 737-7H4
  • Boeing 737-7H4 indicates that the aircraft is a Boeing 737
  • Boeing 737-7H4 indicates this 737 is a -700 model
  • Boeing 737-7H4 indicates the customer is Southwest Airlines
  • Okay, so there have been 9 models of the 737 over time-
    First Generation 1965-1987
    Boeing 737-100, 110 passengers, 30 ordered
    Boeing 737-200, 119-130 passengers, 991 ordered
    Second Generation 1981-1999
    Boeing 737-300, 149 passengers, 1113 ordered
    Boeing 737-400, 168 passengers, 486 ordered
    Boeing 737-500, 138 passengers, 389 ordered
    Third Generation 1993-Today
    Boeing 737-600, 138 passengers, 71 ordered
    Boeing 737-700, 149 passengers, 940 ordered
    Boeing 737-800, 168 passengers, 1109 ordered
    Boeing 737-900, 177 passengers, 57 ordered
    Improvements from generation to generation include upgraded engines, upgraded avionics, wing improvements, ext. More about that can be found on Boeing's website.
    The last two numbers of letters of the aircraft type confuse the most people, but doing a photo search will show you that the ending has to do with customer not a major type difference.
    Hope that helps
    catholic2006
    Tue Mar 16, 2004 4:43 am
    OHHHHHHH!!!!
    (I've seen the light!!!) lol
    See, that was what I was just about to ask....'WHAT DOES THE 5H4 MEAN??"
    Okay, now this is much easier for me to understand. I was always wondering why Southwest had H4 at the end of their model numbers and why Lufthansa had 747-430 at the end. I was like "does a certain airline have a model which is bigger than all others?"
    This is soooo cool!!!! Thank you to all of you who have contributed to answering. I now clearly understand and am no longer confused!!!
    THANX A TON!!!
    -Chris
    amhilde
    Tue Mar 16, 2004 5:04 am
    So was the -900 the one that is so long that it looks like a pencil almost? I remember seeing an AS once that was wow, really long.
    Hang on tightly, Let go lightly
    RE: OKay, I Just Have To Know......why?
    Tue Mar 16, 2004 6:12 am
    Don't forget that Airbus number differently. As they should. They're European  Big grin
    At the risk of making a very long post, here is a nice list for you. Airbus first (alphabetical, don't read anything into it). I probably stole it off some old post.
    AIRBUS
    1st digit : version
    2nd digit : engine manufacturer :
    0 = General Electric
    1 = CFM International
    2 = Pratt and Whitney
    3 = IAE (International Aero Engines)
    4 = Rolls Royce
    6 = Alliance (for the A380)
    3rd digit : engine type (depends on the aircraft model) :
    A300
    -101 = CF6-50C
    -103/203 = CF6-50C2
    -120/220 = JT9D-59A
    -601 = CF6-80C2A1
    -603 = CF6-80C2A3
    -605 = CF6-80C2A5
    -608 = CF6-80C2A8
    -620 = JT9D-7R4H1
    -622 = PW4158
    A310
    -203 = CF6-80A3
    -204/304 = CF6-80C2A2
    -222/322 = JT9D-7R4E1
    -308 = CF6-80C2A8
    -324 = 4152
    -325 = 4156A
    A318
    -111 = CFM56-5B8/P
    -112 = CFM56-5B9/P
    -121 = PW6122
    -122 = PW6124
    A319
    -111 = CFM56-5B5/P
    -112 = CFM56-5B6/P
    -113 = CFM56-5A4
    -114 = CFM56-5A5
    -115 = CFM56-5B7/P
    -131 = IAE V2522-A5
    -132 = IAE V2524-A5
    -133 = IAE V2527M-A5
    A320
    -111/211 = CFM56-5A1
    -131/231 = IAEV2500-A1
    -212 = CFM56-5A3
    -214 = CFM56-5B4/P
    -232 = IAEV2527-A5
    -233 = IAEV2527E-A5
    A321
    -111 = CFM56-5B1
    -112 = CFM56-5B2
    -131 = IAEV2530-A5
    -211 = CFM56-5B3/P
    -231 = IAEV2533-A5
    -232 = IAEV2530-A5
    A330
    -202 = CF6-80E1A4
    -203 = CF6-80E1A3
    -223/323 = PW4168A
    -243/343 = Trent 772-B60
    -301 = CF6-80E1A2
    -321 = PW4164
    -322 = PW4168
    -341 = Trent 768-60
    -342 = Trent 772-60
    A340
    -211/311 = CFM56-5C2
    -212/312 = CFM56-5C3
    -213/313 = CFM56-5C4
    -541 = Trent 553-61
    -642 = Trent 556-61
    A380
    -841 = Trent 970
    -861 = GP 7270
    Note that this nomenclature does NOT apply to early versions of the A300 (versions B1, B2-1C, B2K-3C and SA)">B4-2C), all powered by GE CF6-50C2R.
    For the A300-600, the nomenclatures SA)">B4 (passenger), C4 (combi) and F4 (freighter) are still used.
    You will also see the following codes :
    CJ = Corporate Jet (A319)
    E = Extended range (A319CJ, A330 and A340)
    ET = Extended twin (ETOPS, for the A310 only)
    F = Freighter
    R = Extended range (A300-600)
    ST = Super transporter (only A300-600ST "Beluga")
    BOEING
    01 Piedmont
    02 Northern Consolidated / Wien Air Alaska
    03 Caribair
    04 Britannia Airways
    05 Braathens SAFE
    06 K.L.M - Royal Dutch Airlines
    07 Luftwaffe / West German Air Force
    08 Icelandair
    09 China Airlines
    10 Wien Colsolidated / Wien Air Alaska
    11 Wardair
    12 M.S.A / Singapore Airlines
    13 Ariana - Afghan Airlines
    14 Pacific Southwest Airlines (PSA)
    15 Lake Central
    16 LAN Chile
    17 CP Air / Canadian International
    18 B.E.A
    19 NZ National Airways Corp / Air New Zealand
    20 Boeing
    21 Pan American World Airways
    22 United Air Lines
    23 American Airlines
    24 Continental Airlines
    25 Eastern Airlines
    27 Braniff Airways
    28 Air France
    29 SABENA
    30 Lufthansa
    31 T.W.A
    32 Delta Air Lines
    33 Air Canada
    34 Transair Sweden
    35 National Airlines
    36 B.O.A.C / British Airways
    37 Air India
    38 Qantas
    39 Cubana
    40 Pakistan International Airlines
    41 Varig
    42 Nordair
    43 Alitalia
    44 South African Airways
    45 Seaboard World Airlines
    46 Japan Air Lines
    47 Western Air Lines
    48 Aer Lingus
    49 Flying Tiger Line
    50 Trek Airways
    51 Northwest Airlines
    53 United States Air Force
    54 Mohawk Airlines
    55 Executive Jet Aviation
    56 Iberia
    57 Swissair
    58 El Al
    59 Avianca
    60 Ethopian Airlines
    61 F.A.A
    62 Pacific Northern
    63 Ghana Airways (ntu) / Faucett
    64 Mexicana
    65 British Eagle
    66 United Arab Airlines / Egyptair
    67 Cathay Pacific Airways
    68 Saudia / Saudi Arabian Airlines
    69 Kuwait Airways
    70 Iraqi Airways
    71 Trans International / Transamerica
    72 Airlift International
    73 World Airways
    74 Iraqi Airways (ntu) / Libyan Arba (ntu)
    75 Pacific Western Airlines
    76 Trans Australian
    77 Ansett Airlines
    78 B.W.I.A
    79 Saturn Airlines
    80 Bankers Trust (TWA)
    81 All Nippon Airways
    82 T.A.P - Air Portugal
    83 S.A.S
    84 Olympic Airways
    85 American Flyers
    86 Iran Air
    87 Aerolineas Argentinas
    89 Toa Domestic / Japan Air System
    90 Alaska Airlines
    91 Frontier Airlines
    92 Air Asia / Air America
    93 Pacific Air Lines / Air California
    94 Syrian Arab Airlines / Syrianair
    95 Northeast Airlines
    96 Quebecair
    97 Aloha Airlines
    98 Air Zaire
    99 British Caledonian
    1A Martinair Holland
    1B China Southern Airlines
    1C Government of Romania
    1H Emirates
    1K Airtours International Airways Ltd.
    1L China Xinjiang Airlines
    1M Oman Air
    1Q Tombo Aviation Inc.
    1R Virgin Atlantic Airways
    1S Deutsche BA
    1U BJ / EDRB) (closed), Germany">BBJ Customer
    2A Hawaiian Airlines
    2C Air UK Leisure
    2J Arab Leasing
    2K Turkmenistan Airlines / Akhal
    2L Azerbaijan Airlines
    2Q Ukraine International Airlines
    2R Pegasus Airlines
    2T BJ / EDRB) (closed), Germany">BBJ Customer
    2U JABJ / Picton II Ltd. (BJ / EDRB) (closed), Germany">BBJ Customer)
    3A Ansett Worldwide (AWWAS) / Nordstress Ltd.
    3B Air Mauritius
    SA)">3C Euralair International
    3N American Trans Air
    3P Uzbekistan Airways
    3Q Boeing (BJ / EDRB) (closed), Germany">BBJ Customer)
    3R Western Pacific Airlines
    3S Pembroke Capital
    3T Real Estate Exchange Inc. (BJ / EDRB) (closed), Germany">BBJ Customer)
    3U Chartwell Aircraft Company (BJ / EDRB) (closed), Germany">BBJ Customer)
    3V Easyjet Airline Co Ltd.
    4A United Parcel Service - UPS
    4K Air Nippon
    4N China United Airlines
    4P Hainan Airlines
    4Q Mid East Jet
    4S SA)">GB Airways
    4T GECAS (BJ / EDRB) (closed), Germany">BBJ Customer)
    4U Air Shamrock (BJ / EDRB) (closed), Germany">BBJ Customer)
    4V BJ / EDRB) (closed), Germany">BBJ Customer
    SA)">5A Presidential Airways
    SA)">5B Germania
    5C Xiamen Airlines
    5D LOT - Polish Airlines
    5E EVA Air
    5F GATX Capital Corp
    5H Itochu AirLease Corp.
    5N Shandong Airlines
    SA)">5P Air Europa
    5R Jet Airways (India)
    5S CSA - Czech Airlines
    5T First Union Commercial Corp. (BJ / EDRB) (closed), Germany">BBJ Customer)
    5U Dobro Ltd. (BJ / EDRB) (closed), Germany">BBJ Customer)
    5V General Electric Corporation (BJ / EDRB) (closed), Germany">BBJ)
    6B Cal Air / Novair International Airways
    6D Shanghai Airlines
    6E VIVA Air
    6J Air Berlin
    6K Vietnam Airlines Corporation
    6M Virgin Express
    6N GE Capital Aviation (GECAS)
    6Q Boullion Aircraft Holding
    6R Wuhan Airlines
    7A Far Eastern Air Transport
    7B Air Holland
    SA)">7C Japanesse Self Defence Force
    7D Air Seychelles
    7G Malev - Hungarian Airlines
    7K Zhongyuan Airlines
    7Q Novel Leasing Company
    7U Atlas Air
    8A Air 2000 Limited
    8B Istanbul Airlines
    8E Asiana Airlines
    8J Tarom
    8N Chilean Air Force
    8S China Xinjiang Airlines
    9A ARAVCO
    9D Linjeflyg
    9H Leisure International
    9J Shorouk Air
    SA)">9K Shenzen Airlines
    SA)">9L Air China
    9M Air Austral
    SA)">9N Mid East Jet
    9P China Eastern Airlines
    9R Pro Air
    9T BJ / EDRB) (closed), Germany">BBJ Customer
    9U Wilmot Trust company (BJ / EDRB) (closed), Germany">BBJ Customer)
    A0 Lloyd Aereo Boliiviano
    A1 VASP
    A3 Pluna
    A4 Air California
    A6 Essex International / LTV Capital
    A7 Trans Caribbean
    A8 Indian Airlines
    A9 Transair Canada
    B1 DETA Mozambique / LAM
    B2 Air Madagascar
    B3 U.T.A
    SA)">B4 M.E.A
    B5 Korean Air
    SA)">B6 Royal Air Maroc
    B7 Allegheny / USAir / US Airways
    C0 GATX / Boothe
    C3 Cruzeiro do Sul
    C9 Luxair
    D1 Universal Airlines
    D3 ALIA - Royal Jordanian Airlines
    D4 Ozark Airlines
    D6 Air Algerie
    D7 Thai Airways International
    E0 Dubai Air Wing (BJ / EDRB) (closed), Germany">BBJ Customer)
    E0 Dubai Air Wing
    E1 Eastern Provincial
    E3 LADECO
    E7 Arkia
    F1 Air New Zealand (ntu)
    SA)">F2 THY - Turkish Airlines
    F5 Government of Portugal / Portuguese Air Force
    F6 Philippine Airlines
    F8 Royal Nepal Airways
    SA)">F9 Nigeria Airways
    G1 Government of Saudi Arabia
    SA)">G4 United States Air Force
    G5 L.T.S / L.T.U.
    G7 America West Airlines
    H2 I.T.T
    H3 Tunis Air
    H4 Southwest Airlines
    H5 Mey Air
    H6 Malaysian Airlines
    H7 Cameroon Airlines
    H9 J.A.T - Jugoslav Airlines
    J0 Air Jamaica
    J1 Dominicana
    J4 Sterling Airways
    J6 C.A.A.C / Air China
    J7 National Aircraft Leasing
    J8 Sudan Airways
    J9 Iranian Air Force
    K1 Tarom / Romanian Government
    K2 Transavia / KLM
    K3 Aviogenex
    K5 Hapag Lloyd
    K6 SAHSA
    K9 Bavaria Flug
    L4 American Capital Aviation
    L5 Libyan Arab Airlines
    L6 Aviation Services & Support
    L7 Air Nauru
    SA)">L8 Government of Yugoslavia
    L9 Maersk Air
    M0 ARIA - Aeroflot Russian International Airlines
    M1 Pelita Air Service
    M2 TAAG - Angola Airlines
    SA)">M6 Royal Brunei
    M7 Hughes Air West
    M8 Trans European Airways
    M9 Zambia Airways
    N0 Air Zimbabwe
    N1 Government of Venezuela
    N3 Government of Brazil
    N6 Government of Nigeria
    SA)">N7 Government of Egypt
    N8 Yemen Airways
    N9 Government of Niger / Air Niger
    P1 Goverment of Qatar
    P3 HRH Talal bin Abdul Aziz (BJ / EDRB) (closed), Germany">BBJ Customer)
    P5 Thai Airways
    SA)">P6 Gulf Air
    P8 Bahrain Amiri Flight
    Q2 Air Gabon
    Q3 Southwest Air Lines / Japan TransOcean
    Q4 Transbrasil
    SA)">Q5 Government of Liberia / Air Liberia
    Q6 LACSA
    Q8 I.L.F.C
    Q9 Itel Corp.
    R1 Government of Cameroon
    R4 Alyemda
    R6 Air Guinee
    R7 Cargolux Airline International
    R8 Air Tanzania
    S1 TACA International Airlines
    S2 Federal Express
    S3 Air Europe / Sunrock Capital Corp.?
    S4 Air Afrique
    SA)">S5 Eldorado Aviation
    S7 North Central Airlines / Republic Airlines
    S9 Maritime Investment
    T0 Texas Air Corp / Continental Airlines
    T2 Dome Petroleum
    T3 Evergreen
    T4 Air Florida
    T5 Orion Airways
    T7 Monarch Airlines
    T8 Polaris Leasing
    SA) and AB Varmlandsflyg (Sweden)">T9 Boeing
    U3 Garuda Indonesia
    U4 OSL Villa Holidays
    U5 Government of Jordan
    U8 Kenya Airways
    U9 Polynesian Airlines
    V2 TAME
    V3 COPA Airlines
    V5 Bahamasair
    V6 Petrolair Systems SA
    V8 Air Executive / Busy Bee
    W0 China Yunnan Airlines
    W2 Aerotour
    W6 Government of Morocco
    W8 NOGA Import
    X2 Air Pacific
    X3 Air Charter International
    X4 Supair
    X6 Markair
    X8 Wistair Corp
    X9 Indonesian Air Force
    Y0 G.P.A Group
    Y4 Rafic B Hariri (Saudi customer)
    Y5 Air Malta
    Y9 Air Malawi
    Z0 China Southwest
    Z5 United Arab Emirates Royal Flight
    Z6 Royal Thai Air Force
    Z8 South Korean Air Force
    Z9 Lauda Air
    AB AB Airlines
    AD Eastwind Airlines
    AH BJ / EDRB) (closed), Germany">BBJ Customer
    AJ BJ / EDRB) (closed), Germany">BBJ Customer
    AK Privitair (BJ / EDRB) (closed), Germany">BBJ Customer)
    AN Saudi OGER (BJ / EDRB) (closed), Germany">BBJ Customer)
    AR Taiwan Air Force
    AS Ryanair
    AV Newsflight II Inc. (BJ / EDRB) (closed), Germany">BBJ Customer)
    AW BJ / EDRB) (closed), Germany">BBJ Customer
    AX ARAMCO
    BC Boeing NetJets (BJ / EDRB) (closed), Germany">BBJ Customer)
    BD AirTran Airways Inc.
    BF Funair Corp. (BJ / EDRB) (closed), Germany">BBJ Customer)
    BG Flightlease AG
    BH BJ / EDRB) (closed), Germany">BBJ Customer
    BJ Atlas Air (BJ / EDRB) (closed), Germany">BBJ Customer)
    BK CIT Leasing Corp.
    BQ GECAS
    BS North American Airlines
    BX Midway Airlines
    CB Hawaiian Airlines
    CG GKW Aviation LLC (BJ / EDRB) (closed), Germany">BBJ Customer)
    CJ BJ / EDRB) (closed), Germany">BBJ One Inc. (BJ / EDRB) (closed), Germany">BBJ Customer)
    CM Aerolineas de Baleares Aebal
    CN Privatair (BJ / EDRB) (closed), Germany">BBJ Customer)
    CP Ford Motor Company (BJ / EDRB) (closed), Germany">BBJ Customer)
    CQ JMC Airlines Limited
    CT Westjet
    CU Tutor-Saliba corp. (BJ / EDRB) (closed), Germany">BBJ Customer)
    CX GATX - Flightlease
    DF BJ / EDRB) (closed), Germany">BBJ Customer
    DM BJ / EDRB) (closed), Germany">BBJ Customer
    DO BJ / EDRB) (closed), Germany">BBJ Customer
    DP BJ / EDRB) (closed), Germany">BBJ Customer
    DR Multiflight (BBJ2 Customer)
    DT BJ / EDRB) (closed), Germany">BBJ Customer
    DV Lowa Ltd. (BBJ2 Customer)
    DW BJ / EDRB) (closed), Germany">BBJ Customer
    DX Kazakhstan Airlines
    EA Azteca Airlines
    EC Dubai Air Wing (BBJ2 Customer)
    ED BJ / EDRB) (closed), Germany">BBJ Customer
    EF BBJ2 Customer
    EG Samsung Aerospace (BJ / EDRB) (closed), Germany">BBJ Customer)
    EJ Grupo Omnilife S.A. de C.V. (BJ / EDRB) (closed), Germany">BBJ Customer)
    EL Swiflite Aircraft Corporation (BJ / EDRB) (closed), Germany">BBJ Customer)
    EM BJ / EDRB) (closed), Germany">BBJ Customer
    EQ BBJ2 Customer
    ES Royal Australian Air Force (BJ / EDRB) (closed), Germany">BBJ Customer)
    ET BJ / EDRB) (closed), Germany">BBJ Customer
    EV BBJ2 Customer
    EX BBJ2 Customer
    FB BJ / EDRB) (closed), Germany">BBJ Customer
    FD BJ / EDRB) (closed), Germany">BBJ Customer
    FE Virgin Blue
    [Edited 2004-03-15 22:25:59]
    Cory6188
    Tue Mar 16, 2004 6:21 am
    Amhilde, I am in agreement with you that the 739 is long.
    However, if you want to see a plane that is really a pencil, check out the 753. The effects are especially exaggerated because it is a narrowbody. I have flown on a CO 753 from EWR-PBI - the aisle just goes on, and on, and on, and on. It takes the F/A's a good thirty seconds to walk from the back to the front at a fast pace.
    Photo © Daniel Wojdylo
    Tue Mar 16, 2004 6:24 am
    Getting off topic of course but my colleague said he was flying "one of those... ehm... tubes" from Stockholm to Dublin. Turns out he was flying what I see as the ultimate flying pencil, the ERJ-145.
    Cory6188
    RE: What Is The Difference Between The B737-300, -400 Etc
    Tue Mar 16, 2004 6:28 am
    On a side note, it took two F/A's with a drink cart almost the entire 2 hour flight to do one beverage service down the length of the plane.
    yultopei
    Tue Mar 16, 2004 6:33 am
    GREAT TOPIC!!!!
    very interesting point, you do my day.
    I like to learn about aviation,
    Thank's to all members writing post
     Smile
    PEI in Colombia!!!. [Canon T2i]
