rohan737
Winglets On CO 737 NG & 757's
Thu Mar 25, 2004 1:57 pm
Heard a rumor today that Continental Airlines is going to install winglets on the 737 NG & 757-300's to improve their efficieny. I thought that winglets were not an option on 757's. Anyone else heard this rumor about CO and the winglet installation.
RE: Winglets On CO 737 NG & 757's
Thu Mar 25, 2004 2:07 pm
Unless they got someone else to design and build them I don't think they will be on the 757. I'm fairly certain we didn't design them for the 757. Of course, I've been wrong before.
CAL
Thu Mar 25, 2004 2:10 pm
Well i wish they would, I think that it would help with the fuel costs and performance, it also looks great. Just look at teh Copa 737NG's. As for the 757 dont think so, but it would be cool.
Photo © Javier F. Bobadilla - IBERIAN SPOTTERS
Photo © Felipe Escalona
CAL........Continental Airlines....... Work Hard, Fly Right
CAL
Thu Mar 25, 2004 2:16 pm
Oh! I was also wondering if anyone knew if the Winglets requiered any extra training for the pilots??? Thanks for whoever can help out with this ?
Sinlock
Thu Mar 25, 2004 2:20 pm
All talk of winglets on the 757 died when Boeing ended the BBJ3 study, back in late 1998.
Goldentail
Thu Mar 25, 2004 4:02 pm
Winglets on any of CO aircraft is pure rumor.
"The Proud Bird -w- The Golden Tail"
QantasA332
Thu Mar 25, 2004 4:12 pm
I think that [winglets] would help with the fuel costs and performance.
They most certainly would...but please don't get me started on winglets!  Laugh out loud
I was also wondering if anyone knew if the winglets require any extra training for the pilots.
They don't require extra training because they don't significantly alter the flying characteristics of the aircraft, or anything concerning piloting.
QantasA332
Boeing Nut
Thu Mar 25, 2004 8:56 pm
BW for the 757 isn't a bad idea with all the 75's goin' translatlantic these days.
Btblue
Thu Mar 25, 2004 9:10 pm
Don't aviation partners offer winglets? I know I read somewhere they were producing them for the 747 (a taller more efficient winglet) and 737 classic.
Found this:
http://www.forrelease.com/D20030609/sfm137.P2.06092003172206.09149.html
Boeing Nut
Thu Mar 25, 2004 9:41 pm
Hmm, tried to direct link that address, didn't work.
Anyways, looks as though everything in the Boeing line exept the DC-10/MD-11 is being studied. Or even applied as this 733 with winglets shows.
Photo © Philippe Noret
Spike
Thu Mar 25, 2004 9:46 pm
What gests me is why it took Airbus and particularly Boeing soooo long to work out that winglets make a plane fly further. Everyone used to incorporate them in paper aeroplanes at school! I think they are now the airliner equivalent of the old 'go faster stripes' of Essex fame.
voodoo
Thu Mar 25, 2004 10:08 pm
 Smile Ok so it says `...Express'... but still :  Smile
Photo © Juan Carlos Guerra Aviation Photography of Mexico
` Yeaah! Baade 152! Trabi of the Sky! '
KLM777
Thu Mar 25, 2004 10:24 pm
Winglets are not always more efficient. The advantage of them is that the induced drag is being reduced. Induced drag are the vortexes because of air flowing from underneath the wing (high pressure) around the wingtips to the upper side of the wing (low pressure). Winglets prevent most of this airflow.
Now the disadvantage is that they weigh a couple hundreds of kilos. And not only that, this weight is at the most uneconomical spot of the aircraft: the edge of the wings. This requires the structure as a whole, and particular the wing and wing attachment to the fuselage, to be reinforced to cope with the bending moment.
Whether to add winglets to the aircraft is a tradeoff between the advantages and the disadvantages. Some wings are efficient enough without winglets, adding winglets could still increase efficiency, but the weight of the winglets and extra structure would outweigh this increase in efficiency.
Take for example the wing of the 777. It is long and at the end it's relatively small (high aspect ratio [span*span/standard mean chord]), therefore reducing induced drag to a minimum. Winglets are not advantageous here. I'm not 100% sure about the 757, but I think I think it has a relatively high aspect ratio too. Apart from that, the aircraft is not build to carry winglets (would be possible though I guess).
Kind regards,
Jeroen
Every landing is a controlled crash
voodoo
Thu Mar 25, 2004 10:41 pm
KLM777:
Well, Boeing is raking their wingtips where they aren't wingletting them. Be interesting if raked tips will one day become a retrofit on the 777.
flyingdoctorwu
Fri Mar 26, 2004 2:47 am
How about the TU-204- the 757ski
Click Here
to view the photo
Christopher Wu
ckfred
Fri Mar 26, 2004 3:41 am
Replacing the wingtip with a winglet on a 737NG is not horribly difficult, at least according to a Boeing publication that I read several years ago.
If the price of jet fuel remains high, I think almost every operator of the 737NG will look at the retrofit kits. Even Southwest is now taking delivery of 737NGs with winglets, and they to buy planes with fewer options that the legacy carriers.
I haven't heard of a Boeing-designed winglet to retrofit to the 757, but I know that Pan Am has installed winglets on its 727s. So, it wouldn't surprise me if someone did it within the next few years.
Alitalia744
Fri Mar 26, 2004 4:09 am
Aviationpartners Boeing is working on potential winglets for 757 and 767 aircraft FYI - read the latest Airliners...
-g
Some see lines, others see between the lines.
QantasA332
Fri Mar 26, 2004 6:43 am
KLM777,
I'm nitpicking a little, but preventing wingtip vortices from making it all the way around the tips of the wings isn't the only thing that winglets do. Rather than explaining it yet again, check out my reply (# 6) to this other thread here. I know, I always refer back to that post, but I can't be bothered to type it all again.
You're right that tradeoffs must be made when considering incorporating winglets into an aircraft design. The weight is the main negative, and so various things must be factored in to see if it's really worth adding them. Raked wingtips and increased AR (aspect ratio) also help reduce induced drag, and in some cases those methods are better to use, in some cases they're not.
QantasA332
EDIT: I cleaned up the formatting...
[Edited 2004-03-25 22:47:41]
Thrust
Fri Mar 26, 2004 6:47 am
Why doesn't Delta put winglets on their 738s? Though they are low on cash...it would save money on fuel. And CO, given as many 737NGs as they have, would benefit greatly by adding winglets...hate to break to ya, but the 757 never had winglets, and never will for two reasons: 1, someone already said Boeing ended their studies of this in 1998, and 2, the 757 is no longer being produced after 2004, have all the remaining 757s to be built been built? Does anyone know?
Fly one thing; Fly it well
iahcsr
Fri Mar 26, 2004 9:41 am
The main reason that kept CO from adding winglets to it's 738s right from the getgo was the manufacturer's pricing for their product. The cost/benefit numbers just weren't right at the time. Now however ....... Well, we will just have to wait and see.
QantasA332
Fri Mar 26, 2004 12:43 pm
I just found the following from here, under "news." It simply confirms that Aviation Partners Boeing are certainly looking into 757/767 winglets. Enjoy...
Launch Customer Opportunity for Boeing 757-200 and 767-300ER Blended Winglet Fleet Upgrade
Who will be the first to fly Aviation Partners Boeing Performance Enhancing Systems?..."We're looking for a customer to partner with in the certification and launch of 757-200 and 767-300ER Blended Winglet Programs," says Aviation Partners Boeing CEO Mike Marino..."[Blended winglet] technology is particularly well suited to 757 and 767 series applications." Aviation Partners Boeing forecasts a potential Blended Winglet upgrade market for some 850 Pratt & Whitney and Rolls-Royce powered 757-200 and over 400 767-300ERs in both passenger and freight configuration.
QantasA332
Goldentail
Fri Apr 02, 2004 6:11 pm
Voodoo......
The post was asking about winglets on B737NG or on B757, not about RJ's at Expressjet.
Sorry...my answer stands firm. No winglets for mainline CO jets are planned.
