b737-200
Slovak Airlines Fokker 100?
Fri Mar 26, 2004 4:09 am
Hi! Does Slovak Airlines has a Fokker 100 now? If you look at the timetable on the homepage they have F100 flights,but in the fleet description I only find B733! Thanks for the info! Best regards,Clemens!
Jano
RE: Slovak Airlines Fokker 100?
Fri Mar 26, 2004 4:54 am
According to guys at , Slovak Airlines should be getting an F100 at the end of May, a B737 next week.
Slovak Airlines are also said to get a B767-300ER at the end of May.
The Widget Air Line :)
b737-200
Fri Mar 26, 2004 5:03 am
Thanks for the info! Do you know which series 737 and where they plan to use the 767? Best regards,Clemens!
alespesl
Fri Mar 26, 2004 5:10 am
They will be getting B737-33A at the beginning of April and also at the end of April they will get Fokker 100.
This info came from their website.
They are starting new regular service from BTS to BRU, BTS-TLV and BTS-LGW.
Jano
Fri Mar 26, 2004 5:13 am
It should have been "According to guys at http://www.slovak-airports.net"
But, as is the case with Slovak Airlines, I believe when I see  Smile
AWD123
Fri Mar 26, 2004 5:41 am
Slovak Airlines will also use the B767 on the daily BHX-BTS-ATQ route which is currently being operated by a FlyJet B757.
AWD123
Jano
Fri Mar 26, 2004 5:43 am
The rumor is thay will introduce service to YYZ with this new B763ER.
astrojet
Fri Mar 26, 2004 6:14 am
Anyone knows where the F100 is coming from?
