SHUPirate1
What If: Boeing 767 Question
Fri Mar 26, 2004 5:37 am
What if, instead of configuring the Boeing 767 2-3-2, the airlines had originally configured the plane with a 4-4 configuration. Obviously passengers would have been driven nuts by the configuration, but on some of those short-haul high-demand domestic routes, for example, wouldn't it make more sense to have the extra column of seats? Obviously, I am not asking about passenger comfort here...
Burma's constitutional referendum options: A. Yes, B. Go to Insein Prison!
Cory6188
RE: What If: Boeing 767 Question
Fri Mar 26, 2004 5:40 am
That's even worse than the 2-5-2 found on DC-10s, MD-11s, and some 777s. People can't stand to be in the middle seat of 5 with 2 on each side; how do you think people would react to 3 people next to you? Also, one aisle would not be enough to handle all those people - it's tough on a 752 as it is.
yvrtoyyz
Fri Mar 26, 2004 5:42 am
What you have suggested may have yielded most passenger miles and higher revenue for the airline, but I doubt that the FAA would have granted permission due to emergency evacuation concerns and feasibility.
-YVRtoYYZ
SHUPirate1
Fri Mar 26, 2004 5:43 am
Cory-I wasn't asking from the passengers perspective...any sane soul would HATE being a passenger in a 767 with a 4-4 layout. I was asking, though, if it would make the economics better for the plane, almost to the point where it would make a 7E7 with two aisles redundant...
dutchjet
Fri Mar 26, 2004 5:45 am
The 767 introduced "wide-body" comfort to many routes that were too big for the 1st generation jumbo jets, and the 2-3-2 seating was offered since it offered the maximum level of comfort. A 4-4 layout would have gone against every idea in the 767 development plan - the 767 was the twin aisle airliner and the 757 was the single aisle airliner in the 180-250 seat market.
I also think that a 4-4 single aisle 767 would not have been certified, the time it would take to evacuate the aircraft in the event of an emergency would take far too long...in a 4-4 layout, we are talking about almost 300 people through one aisle.
sk945
Fri Mar 26, 2004 5:46 am
SHUPirate1,
In that case it would be better to do a 2-4-2 config. as Britannia (and perhaps some others) have in there B762 and B763.
Its terrible, but on short routes it might work.
jtdieffen
It would probably impede evacuation procedures. Since there would only be one aisle, passengers would not be able to get out as fast. From a crew perspective, it might work, since you could do it with fewer staff...but that means more passengers per F/A.
Final judgement: probably wouldn't work, or be worth it if it did work.
Regards! JDief
Boeing Nut
Fri Mar 26, 2004 5:47 am
Doubt it would have ever happened. Two words; evactuation timing. With only one isle, I don't think that the 90 second rule would have been met. A 2-4-2 arrangement is availble on the 767 anyways.
SHUPirate1
Fri Mar 26, 2004 5:54 am
Sk945, Boeing nut-2-4-2 on a 767? No thanks...I'll walk...I'd walk with a 4-4 also, but at least the seats would be humane, as long as I didn't have to get up from a window seat...
[Edited 2004-03-25 21:55:05]
dutchjet
Fri Mar 26, 2004 6:04 am
Yep, 2-4-2 on a 767 - this configuration is popular with british tour operators operating holiday flights.
Think of this, a 2-4-2 configured 767 on a 26 hour flight:
London-sharjah-singapore-Sydney
Britannia operated this flight for several years, and the flights were just about always 100% capacity!
sk945
Fri Mar 26, 2004 6:07 am
Well, I have tried a 14,5 hour flight from ARN-HKT with stop in Sharjah with Britannias B763 and I would say that's one of the worst flight experience I ever have had.
brons2
Fri Mar 26, 2004 6:17 am
Cripes, count me out. I don't even think I'd fit in the seats. (6'7"-250 or 200cm, 105KG for you metric folks). British people must be smaller than Germans and Scandinavians, that's for sure.
Firings, if well done, are good for employee morale.
ramerinianair
Fri Mar 26, 2004 6:30 am
Everybody always complains about the middle seat of 2-5-2. It's not that bad! If you want to get out it's like the 3-3-3 on the sides(not the middle 3). The good part is that when you do get up you barther the right side the first time and then the left side so you don't feel bad and can move throughout the cabin freely whenever you want. Also, if you are traveling by yourself, It's absolutely stupid to be there, but if you are part of 3 or more it's great(Well I like it anyway)!
-S.R.
W N = my Worst Nightmare!!!!!
roseflyer
Fri Mar 26, 2004 7:06 am
The only plausible configurations are 2-3-2 and 2-4-2. Theoretically it would be ok to have 4-4, but in order to meet the FAA requirement of evacuating the entire airplane in 90 seconds or less using 1/2 the exits, there would need to be many more exit doors, and the space lost to these would counter act the benefit of having 8 abreast seating. The 757 was difficult enough being that it is a long narrowbody with as many as 12 exits in it, I can't imagine a 767, and what the structural integrity and weight of all those exits would do.
Fri Mar 26, 2004 8:26 am
4-4 on a 767, ha i am still waiting for 2-2-2-2 on a 777
richardw
Fri Mar 26, 2004 6:50 pm
2-2-2-2 on a B777, with no central overhead bins, is unlikely.
