aguilo
A343 Range Versus A346 Range
Sat Apr 03, 2004 4:45 pm
Is there really a big difference in range between the A343 and the A346?
I recently flew LHR to CPT on Virgin Atlantic and was surprised that they were using a A343 on the route. Also surprised that the A343 had the range for such a long (12 hour) flight, especially on the even longer return.
SAA flies ATL nonstop to CPT with an A346, but then on the south to north return the flight has to make 2 stops before arriving in ATL. Does anyone know if this is a necessary fuelstop because even the mighty A346 doesn't have the range for the longer south to north return (yes, I know the A345 has a longer range than the A346) or are the stops more of a "business necessity" to pickup extra passengers, but not necessarily more fuel?
Thanks in advance for the input!
Q330
RE: A343 Range Versus A346 Range
Sat Apr 03, 2004 5:39 pm
The A343 has a range of about 7200nm (7400nm for the -300E) as opposed to 7500nm for the A346. Not a huge difference.
-Q
Long live the A330!
aviationwiz
Sat Apr 03, 2004 5:43 pm
It depends on what day you were to fly with SAA. Sometimes they have non-stops from ATL-JNB, otherwise it's non-stop from ATL-CPT. Some days they have JNB-SID-ATL, other days they have CPT-SID-ATL. The only stop needed on the way up is SID. On the JFK route they do either JFK-JNB non-stop, or JFK-DKR-JNB (DKR to pick up pax.) on the way up, it is always a stop in DKR because that is needed as a fuel stop (and it makes a nice pick-up, drop-off for pax.)
In SID, all they have rights to do is re-fuel, in DKR, they have rights to load and unload pax. as well.
SID=Illoh Do Sal
Proudly from the Home of the Red Tail.
SailorOrion
Sat Apr 03, 2004 5:44 pm
Range at maximum passenger payload (no cargo):
A330-200: 6650nm @ 253pax
A330-300: 5600nm @ 295pax (I think the "X" variant has some more)
A340-200: 8000nm @ 239pax
A340-300: 7300nm @ 295pax
A340-500: 8650nm @ 313pax
A340-600: 7500nm @ 380pax
SailorOrion
aguilo
Sat Apr 03, 2004 6:56 pm
Thanks everyone for the info - very helpful.
Does anyone know how I could find out what the distances between LHR to CPT (just curious for this one) and ATL to CPT are? I'd like to find out by how short the A343/346 fall in not being able to make the return trip to the US from Cape Town nonstop.
Also, I assume that reason that South to North and East to West trips are longer has to do with things such as the rotation of the earth, winds etc. But in the case of a flight from deep in the souther hemisphere like CPT up to the northern hemisphere like London or the US, what is the specific reason that these flights take longer to get back than the opposite trip heading down does?
Any thoughts?
vikkyvik
Sat Apr 03, 2004 7:06 pm
http://gc.kls2.com/
There ya go. The trips also have to do with the jetstream (high altitude winds) which flows from west to east. Hence BOS-LAX is around 45 minutes longer than LAX-BOS.
~Vik
aguilo
Sat Apr 03, 2004 7:23 pm
Thanks for that great resource VikkyVic and for the stats SailorOrion
Sure seems like on the ATL to CPT route that SAA flies with an A346 they sure are cutting it pretty close! (A346 range according to the Sailor is 7500nm and the ATL to CPT route is 7046nm - not much reserve left on that flight it seems)
Good thing CPT is small enough an airport to have probably never had a traffic delay, because the ATL flight doesn't seem like it could wait very long before it would have to come down.
GuyBetsy1
Sat Apr 03, 2004 7:27 pm
Some airlines actually decrease their A346 capacity so that it has better range. eg Cathay Pacific's A346 only carry 286 passengers against Airbus recommendation of 380!
SailorOrion
Sat Apr 03, 2004 8:21 pm
Still Air Distance under normal conditions is around 7700nm, so you need to leave some "stuff" at home.
GuyBetsy1: That's not necessarily because of the range, it might be due to other factors (for example size of F or C class), LH's B744 have around 340-390 passenges (there are 3 configs) and that's not because of the range.
SailorOrion
gigneil
Sun Apr 04, 2004 1:54 am
CPT-LHR, JNB-LHR are even well within the range of the 767-300ER.
The A340-300 is a reasonably long range aircraft... 7300nm is a far way.
N
ConcordeBoy
Sun Apr 04, 2004 3:08 am
No A342 in commercial service has anywhere near this amount of range.
yul332LX
Sun Apr 04, 2004 4:42 am
The A342 DOES have a range of 8000nm but no airlines currently operate the A342 on routes that require that kind of range.
E volavo, volavo felice più in alto del sole, e ancora più su mentre il mondo pian piano spariva lontano laggiù ...
ConcordeBoy
Sun Apr 04, 2004 4:58 am
Wrong.
Only a single aircraft built featured that range (formerly designated A340-8000... later A340-213X), and it never entered commercial service.
Some were later given similar upgrades, but still do not feature anywhere near that range.
airxliban
Sun Apr 04, 2004 5:30 am
i believe royal jordanian has one of those A340-8000s though i do not believe that it is in commercial configuration.
aviationwiz
Sun Apr 04, 2004 5:51 am
Aguilo,
You are correct, because the amount of fuel that the flight uses, and the fact that they can't waste too much fuel on the ground in line, they generally give the SAA flights priority as to take-off's. I remember one night at JFK, we must have cut in front of a dozen planes (most larger 747, 767's, 777's) because we needed all the fuel we could get for the flight. The longest non-stop flight ever is ATL-JNB (which SAA currently operates on some days, the other days are ATL-CPT)
Thrust
Sun Apr 04, 2004 6:03 am
Wow, this is one of the few times that bigger is better....usually stretching a jet cuts its range short. Then again, the A346 has much different engines than the A343...so maybe this completely wipes out that disadvantage.
Fly one thing; Fly it well
aviationwiz
Sun Apr 04, 2004 6:08 am
Thrust,
For this route, SAA needs a combination of carrying a lot of pax. and long range, as the route is always full.
yul332LX
Sun Apr 04, 2004 6:14 am
Wrong again depending on what you consider “anywhere near that range.”
Remember, we're talking about a configuration of 239 pax and no cargo.
andz
Sun Apr 04, 2004 6:47 am
Those same winds that Vikkyvik mentioned are the main reason that JNB-SYD is under 12 hours and SYD-JNB is over 14 hours.
JNB is 5,500ft asl and there are always penalties in takeoff weight, and therefore fuel load and range, even for a long range aircraft like the A340. Europe has always easily been in range but the US is a little further away.
On the engine issue, SAA 346s have Rolls-Royce engines and the 343s have CFMs (uprated on the 300e version that SAA operate).
buckfifty
Sun Apr 04, 2004 7:17 am
The 346 also carries 30% more fuel, around 153 tons.
That's not really the main reason why there are less seats. The CX A346's actually carries 288 passengers, with 68 of them in premium seating (8 first, 60 business). It's more or less what the airline considers to be the optimum mixed seating for the destinations it is supposed to serve. However, less pax does help the cargo carrying capability.
Tom_EDDF
Sun Apr 04, 2004 7:27 am
By the way: Do you know the exact thrust rating for the CFM56-5C/P used on the -300E? I've repeatedly heard people referring to it as an uprated version, but on their web site, CFM still mentions 34klbs as the highest possible rating on the -5C. With the -5C4 already rated at 34000 - what's the uprating then all about???
gigneil
Sun Apr 04, 2004 10:00 am
Nobody knows for sure.
People THINK that they've been uprated to 36,000 lbs thrust, but again, nobody knows for sure.
The CFM website doesn't include information on the specific engine.
N
