Tiger119
Delta 737-832 At IND
Wed Apr 14, 2004 1:56 pm
Someone on A.Net will either have the answer or know where to get the answer. This evening (Tuesday, 4-13-2004) I saw a Delta 737-832 N378DA
Photo © Bruce Leibowitz
sitting at IND, parked in area that is normally for charter flights or diversions. It appeared they had a GPU hooked up, the beacons were turned on and it appeared passengers were sitting on board. Does anyone know if it was a diversion? The only Delta aircraft I ever see at IND are 737-232s and MD-88s (not including RJs). I thought it might have been an NBA charter (Pacers WILL beat the Chicago Bulls Wednesday night) but there was a Champion Air 727 sitting right next to the DL 738 that The Bulls probably chartered.
Flying is the second greatest thrill known to mankind, landing is the first!
DeltaMIA
RE: Delta 737-832 At IND
Wed Apr 14, 2004 2:08 pm
DL1162 SEACVG.
Diverted due to ATC equipment failure at CVG. The equipment wasn't down for very long however this aircraft didn't have a lot of holding fuel.
It's a big building with patients, but that's not important right now.
Tiger119
Wed Apr 14, 2004 2:13 pm
If they had an ATC problem, I'm surprised there weren't more diverts to IND. Why didn't Delta put winglets on their B738s?
B4REAL
Wed Apr 14, 2004 8:03 pm
Someone correct me if I am wrong...
The wiinglets optimize fuel consumption on the 737 for longer flights (SEA-CVG would count however) (flights of over 1000 miles efficiency gain of around 3.5/4.0 % as well as some payload performance gains), and DL doesn't always use them for long flights (East coast shuttle ops) - and they really want consistency in their 738 fleet .
B4
B4REAL, spelled like it sounds
