UNITED777300
FI 753's
Fri Apr 16, 2004 10:04 am
Does anyone know where FI sends/typically uses their 757-300('s)?
/// U N I T E D: It's Time to Fly.
asgeirs
RE: FI 753's
Fri Apr 16, 2004 10:08 am
Hi United777300
As far as I know they mostly use it for the Copenhagen (KEF-CPH) and London (KEF-LHR) flights.
Reykjavik Aviation Photography - Just bring the aircraft to us and we'll photograph them! :-)
cbphoto
RE: FI 753's
Fri Apr 16, 2004 10:09 am
I believe they use them on inter-European flights. I know they fly them to London, and a few other high density routes in Europe. Hopefully someone will be able to give you a more specific answer. Hope it helps a bit though!!
ETOPS: Engines Turning or Passengers Swimming
flyguy1
RE: FI 753's
Fri Apr 16, 2004 10:16 am
I have seen them at JFK a few times also.
727, L1011, MD80, A300, 777-200, 737-300, 737-700, 747-400, 757-200, 737-800, A320. E190, E135, 767-200, CRJ9
ScottishLaddie
RE: FI 753's
Fri Apr 16, 2004 10:19 am
Just the one, TF-FIX I believe. I flew on it when it was brand new back in March 2002, on KEF-GLA. I don't think it appears to often there though.
As has already been said, LHR and CPH are it's main routes I'd also say.
planemannyc
RE: FI 753's
Fri Apr 16, 2004 11:25 pm
Yep, Icelandair uses it's only 757-300 (TF-FIX) mostly on KEF-CPH and KEF-LHR runs. I took the bird from CPH to KEF in May 2003. Really long cabin. Was quite a full flight as well.
Best,
Wasim / Planemannyc
TFJamie
RE: FI 753's
Fri Apr 16, 2004 11:40 pm
Yes it is alternated between the high-density routes of KEF-LHR and KEF-CPH in the morning. Where it goes in the afternoon is more difficult to say. It has been used on high-density charters. The evening flights to LHR and KEF are almost always operated by the 752s.
TF-FIX hasn't been photographed on a.net at any US airport so it's difficult to say if it can be seen there but most likely it's used to add capacity on highly booked flights to america if the need rises. Does anyone recall seeing one at, BOS, BWI, MCO, MSP etc?
Hope this helps but I would love more info.
