su184
VC10- Early Long Ranger
Fri Apr 30, 2004 10:32 pm
I was wondering why the VC10 didn't succeed as the B707 and DC8 did in the early jet days, although for me it it more elegent, it looked rugged and well designed to do the job, and it had very characteristic noise that you can't miss, I can only think of few airlines that bought it, BOAC (of course ), Gulf Air, East African, Ghana Airways, British Caledonian, can't think of others. Can anyone help, other than it was specifically designed to BOAC needs???
Photo © Ken Rose
Photo © Ian Oswald (via Martin Stephen)
Photo © Snorre - VIP Vienna International Planespotters
Photo © Ken Wilkinson
Greg
RE: VC10- Early Long Ranger
Fri Apr 30, 2004 10:35 pm
It was hardly a long ranger! Designed mostly for hot and high African/Midde East routes if I'm not mistaken--not initially designed for transatlantic.
It was grossly overweight for the number of passengers. The 707 and DC-8 had far superior economics-- (even BOAC had to bite the bullet and replace them with 707's).
However, you'd be hard pressed to find a better looking first generation aircraft!
RICARDOAB
Fri Apr 30, 2004 10:50 pm
The Ilyushin Il-62, which was the Russian copycat to the VC-10 was more long-range as it flew on Aeroflot's Asian routes to Vietnam, China, and Korea etc. More recently it has been flying tran-Atlantic for Cubana.
tu114
Fri Apr 30, 2004 10:59 pm
Sadly the VC-10 was the victim of the same problem as other British planes developed around the same time (the Trident being a particular example) - a tendancy to design for the very particular requirements of the British and Commonwealth airlines. The VC-10 was optimised for long thin routes with hot and high airports with limited on the ground support. As such it was less economical for other uses than an aircraft (such as the 707) that was built with more general usage in mind.
It also didn't help that BOAC was somewhat indecisive about the specifications that they wanted. As I understand it the original proposal from Vickers was similar to the later Super VC-10. BOAC said that that was too large so the launch version was smaller. In service BOAC found that the standard VC-10 was not large enough....
Just a quick pet peeve - is there any actual evidence that the Il-62 was a copy? Probably not. It's like saying that the A320 is a copy of the 737 because they're both similar in size and layout.
northstardc4m
Fri Apr 30, 2004 11:07 pm
actually, there have been admissions by Soviet era engineers that they DID copy the VC-10's basic layout. However there the "espionage" ends, as beyond basic appearance they are very different aircraft.
Also the VC-10 was always to have bi-directional US East Coast to London range. BOAC however basically killed the VC-10 by telling potential customers they wanted "superior" (their term) Boeing 707s and that the VC-10 could not acheive its design specifications. However after the VC-10 went into service, and BOAC got 707-420s, passengers sided heavily with the VC-10 on a comfort basis, and the VC-10 could carry more pax out of shorter runways than a 707 or DC-8 (at least until the -62).
Yet another wasted opportunity...
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
tu114
Fri Apr 30, 2004 11:20 pm
The russians would have to have been some of the fastest engineers around given that the VC-10 and Il-62 both first flew in 1962....
As a matter of interest the aircraft history and data page for the VC-10 here on a.net has a useful potted history of BOAC's shenanigans ordering the aircraft.
There's also a good article here: http://encyclopedia.thefreedictionary.com/Vickers%20VC10
su184
Sat May 01, 2004 12:09 am
The VC10 was designed as a long range aircraft from the beginning having a range of more than 11,000km with 174 pax, this comparable to the B707 with 10,000km, and the DC8 with 9000km with similar loads.
There is no wonder about the copying capability of the russians in those days, the Tu-144 was a copy of the Concorde and flew before it.
As for the IL-62, they had a problem with its CG, so with certain loads it had tanks to be filled with water as ballast, on one occasion during its brief history with UAA ( now EgyptAir ), it was stuck in the gulf area in early 70's asking for 4 tons of water at a time when everything was still underdeveloped in that area.
carduelis
Sat May 01, 2004 1:04 am
Thanks for the excellent link Tu114, but being in BOAC at the time, my memory tells a slightly different story.
Whilst the Standard VC10 was intended for the hot climates, the Super specification from BA was that it should have a longer range than the 707, as mentioned above, and emphasised the ability to fly from UK to the West Coast of US.
When it was found that this range was not achievable, BA cancelled the additional Supers. BAC in retaliation reduced the number of spares needed for support downroute, so for a while the Super operated only LHRNYCLHR.
The 707s were not brought in to replace the VC10, they were there already with Rolls Royce 436s operating from around 1958 - the Comet, of course, was the first trans-atlantic jet, just beating the 707 to the post!
I worked on these 707s in the early 60s, and from late 1962, we did operate into Kano, Lagos, Karachi, Singapore, as well as Teheran, Delhi, Rangoon, Bangkok, and Hong Kong, with no trouble at all!
Later, a few more 707s BOAC were delivered, the first two from Cunard Eagle, which then merged into BOAC Cunard. Later again, some P&W engined versions arrived. These had not been allowed on the initial BA order, as the British Government at the time decided that all BOAC's 707s must have RR engines!
Anyway, my two pence . . . !
Per Ardua ad Astra! ........ Honi Soit Qui Mal y Pense!
jetjack74
Sat May 01, 2004 5:13 am
Here's a good site on the old VC10. Flew on it only once from PHL-LHR in 1976 with BA.
http://www.vc10.org/
Made from jets!
