SafetyDude
Earning AA FF Miles On Aer Lingus
Mon May 03, 2004 12:37 am
Hi all,
I will be flying DUB-JFK (flight 105) this summer on a paid coach ticket and I am wondering if I can earn AAdvantage Miles because AA's website said no, but a CS rep said yes.
Thanks.
 Smile
-Will
"She Flew For What We Stand For"
Leskova
RE: Earning AA FF Miles On Aer Lingus
Mon May 03, 2004 12:45 am
What booking class are you booked on? I think in the case of OneWorld it generally depends on the booking class - the really low ones don't earn you any miles, the middle to high ones will...
So, if you're booked in B, H, K or Y you should earn miles, if you're booked in anything lower, you probably won't - did you call AAdvantage, or was the CS rep. from reservations?
Frank
Smile - it confuses people!
SafetyDude
Mon May 03, 2004 2:05 am
I called AAdvantage, and my ticket for some reason does not mention fare class at all, which really threw me off.
 Smile
-Will
snnams
Mon May 03, 2004 2:25 am
Safetydude,
These flights are code shared with American Airlines, so as long as you are flying under an AA flight number, you are guaranteed to earn miles. If you are on an EI flight number, the following link may be useful. It shows what classes an EI FF can earn miles in, and I presume it is the same vice versa:
http://www.aerlingus.com/cgi-bin/obel01im1/Services/serv_tab_partners.jsp?BV_SessionID=@@@@0495856335.1083518576@@@@&BV_EngineID=ccckadclghmkjdkcefecfigdffgdfki.0&P_OID=-8072&Category=3
Finally, enjoy your stay over here!
Leskova
Mon May 03, 2004 4:56 am
Will, did you get an eMail confirmation or an itinerary by eMail? Usually you can find something in there - the other possibility would be, depending on what CRS your flight was booked on, you could look it up through the respective website (www.checkmytrip.com for Amadeus, www.viewtrip.com for Galileo, don't know if there is something for Sabre): these sites usually also display the actual booking class.
Otherwise, if you've got a paper ticket, the booking class is on there - just depends what type of ticket you've got... if it's a paper ticket, and if you've got a scanner, you could just scan it in and send it as jpg-file to me by eMail (you can contact me through my profile) and I'll have a look at it (if you want).
Frank
