762 Vrs 763 On Long Haul
Mon May 03, 2004 5:47 am
It seems most long haul (around 4000-5000nm's) 767 flights are operated by 763's, like AA's and UA's. What airlines regularly operate 762's on long haul?
Also how do 762's fair on long haul routes economically, does their fuel consumption per seat begin to suffer?
[Edited 2004-05-02 22:49:49]
CO2BGR
RE: 762 Vrs 763 On Long Haul
Mon May 03, 2004 5:52 am
CO flies the 762 long haul. As for economics, If there are not enough passengers to fill a 763, then a 762 is your best bet.
There are too many self indulgent weiners in this town with too much bloody money" Randal Raines- Gone in 60 Seconds
COEWRNJ
Mon May 03, 2004 5:54 am
I can tell you for sure that CO uses the 762 for it's long haul flights to Europe from EWR and possibly from IAH to AMS every once and a while.
Also EL AL uses the 762 from TLV-YYZ-LAX.
STT757
Mon May 03, 2004 5:55 am
I believe the 767-200 ERs CO operates have the same if not better range than 767-300ERs, El Al was flying 767-200ERs nonstop from ORD to Tel Aviv.
FoxBravo
Mon May 03, 2004 6:19 am
CO also flies 762s from EWR and IAH to GRU. Other 762 long-haul operators include US Airways (many transatlantic routes), Malev (BUD-JFK/YYZ) and Britannia (Florida, etc.).
Theoretically a 762ER will have more range than a 763ER equipped with the same engines, since the wing is the same but the fuselage is shorter and therefore lighter. However not all 762ERs have the more powerful engines.
Common sense is not so common. -Voltaire
cayman
Mon May 03, 2004 6:39 am
AC used to, and I think still do, use 762s alongside 763s on many long haul routes---although they have more 763s now than before--many 762s across the Atlantic from YYZ and Western canada
haveric
Mon May 03, 2004 8:13 am
US Airways has 767-200ER longhaul service on:
PHL-MAD (in winter)
PHL-MUC
PHL-AMS
PHL-DUB
PHL-SNN
PHL-GLA
PIT-LGW
EddieDude
Mon May 03, 2004 11:24 am
AM has one 763ER and 4 762ER's. The 200's are used for the MEX-GRU, MEX-MAD and MEX-CDG flights and the 300 is used mainly for the MEX-SCL flight (it is occasionally used for the flights to the other destinations, but it is not common). The reason for this is that the 200's have slightly more range and, therefore, have less trouble getting to Europe with a full load of cargo and pax than the 300, especially during the summer season. Due to the fact that AM's loads to Europe are [close to] 100% during the summer and very, very good too all year long, I am sure that AM would have gotten only 763ER's if MEX were closer to the sea level since altitude would not be then a factor restricting the range of the planes; unfortunately, MEX is, at more than 7,000 ft. above the sea level, very high and therefore it is better to use the 200's to Europe to prevent potential range-related problems. AM is getting more 767ER's until it can afford to get newer and bigger planes (the 772ER is rumored); the first of those will be a 300ER, so that all flights to SCL and GRU are done with 300's and the rest will likely be 200ER's, in order to increase frequencies to Europe.
Upcoming AM MEX-LAX 73H, VA LAX-MEL 77W.
CALMSP
Mon May 03, 2004 11:41 am
does anyone know how old the 762's are that Ansett has in the desert?
Southamerica
Mon May 03, 2004 12:52 pm
And 764s to be precise.
Almost exactly the same case with Avianca. Their loads on the BOG-MAD-BOG run are usually pretty good, but the 762 has less trouble making it's way over the pond with full payload and taking off from a 8300ft high airport (that's BOG).
The other 762s on the fleet are used from BOG to EZE, SCL, LIM and once in a while to MEX.
The 763 are used normaly in the BOG-JFK-BOG route.
SOUTHAMERICA
TS-IOR
Mon May 03, 2004 7:45 pm
Air Mauritius (MK) links the island to some European points with B762.
Mon May 03, 2004 7:53 pm
For the record:
767-200
Range of basic aircraft with JT9Ds 5855km (3160nm), medium range version with CF6s 7135km (3850nm). 767-200ER - Speeds same. Range with PW4056s 12,269km (6625nm), with CF6s 12,352km (6670nm).
767-300
Higher gross weight version range with design payload and PW-4050s 7835km (4230nm), with CF6-80C2B2s 7890km (4260nm).
767-300ER - Range with design payload with PW-4060s 10,880km (5875nm), with CF6-80C2B4Fs 10,195km (5505nm).
From http://www.airliners.net/info
