Philaboy
Today QF107 At Ontario?
Wed May 05, 2004 11:25 pm
Ok i was just checkin out flights in and out of LAX on flytecomm and i noticed QANTAS flight 107 SYD-LAX-JFK actually said SYD-ONT and had arrived. Was the flight diverted or something? Any info? can ONT even handle a 744.
Airline Qantas
Flight Number 107
Departure City (Airport) Sydney, NSW, Australia (YSSY)
Departure Time 05/05/2004 12:00 PM
Arrival City (Airport) Ontario, CA (ONT)
Arrival Time 05/05/2004 06:57 AM
Remaining Flight Time 00:00
Aircraft Type Boeing 747-400
Current Altitude 0 feet
Current Groundspeed 0 mph
Flight Status Arrived
RE: Today QF107 At Ontario?
Wed May 05, 2004 11:41 pm
Yes. UPS flies/has flown B747 into there all the time, as well as other cargo carriers.
buckfifty
Thu May 06, 2004 12:33 am
Ontario is often used as an alternate for transpac flights, if nothing but to fulfill legal requirements. However, their proximity usually means that both ONT and LAX are hit with the same kind of weather most of the time.
Philaboy
Thu May 06, 2004 7:12 am
Ok, im still baffled!!! i just checked flytecomm again just to see what was going on and it says QF107 LAX-JFK arrived? and yet the earlier SYD-ONT arrived instead of LAX? Has flytecomm gone mad with airports in the Los Angeles metropolitan area or what?
Airline Qantas
Flight Number 107
Departure City (Airport) Los Angeles, CA (LAX)
Departure Time 05/05/2004 09:42 AM
Arrival City (Airport) New York, NY (JFK)
Arrival Time 05/05/2004 04:54 PM
Airline Qantas
Flight Number 107
Im sure there was no QF at ONT today, but who knows maybe there was. Thanks for the info AAJAX and $1.50, but I'm still confused.
UA744KSFO
Thu May 06, 2004 7:24 am
Even though LAX and ONT are not far apart from each other, this can happen on occasion due to the "June gloom" that we experience in CA (even though I know it is only May).
LAX is right on the coastline, so a marine layer often reduces the visibility to levels that don't allow for landing there. In that case, it is not uncommon for flights to be diverted to ONT which is more inland (and the marine layer usually isn't a problem). This happens especially if they are coming from far away and might have fuel issues, and therefore would rather get on the ground.
Also, the marine layer tends to only be a problem at certain times of the day, so what might have happened is that the flight from SYD got diverted to ONT until LAX cleared up, and then might have been able to get to LAX (since passengers from the MEL flight might need to board) and then leave there for JFK. I'd be willing to bet that this is what happened if the data that you are seeing is correct.
roseflyer
Thu May 06, 2004 8:06 am
I doubt that that could happen. There is a time gap of 2hours 45 minutes between arrival at ONT and departure from LAX. I doubt that they could clean and get a 747 to LAX and then to JFK in such a short period of time. It takes at least 2 hours to turn it once, let alone twice.
Probably just an error. Or maybe the JFK leg subbed for another plane that would normally sit in LAX all day. I'm probably wrong, but it could happen.
747srule
QF 107 At Ont Today?
Thu May 06, 2004 8:19 am
I saw that happen about 2 years ago. I was outside and was shocked to see a Qantas taking of from ONT.I am fortunate to see departing aircraft from my front yard.
Jesus is the way,the truth,and the life
WesternDC1010
Thu May 06, 2004 10:29 am
It must've been an error on the part of flytecomm.
LAX Airport Monitor 2.0 (http://www4.passur.com/lax.html) shows that QF 107 had arrived at LAX. It entered from the southwest around the coastline at Seal Beach at 06:43, made a slight left turn over Rossmoor at 06:44, then made another left turn near the intersections of the 105 and 710 freeways around Lynwood at 06:46 making it's final approach to LAX runway 24L. It touched down at LAX at 06:50:57.
- Ron
Western DC-10-10
Western Airlines - The Only Way To Fly
