Bronko
Does JAL Have 777-300ER's On Order?
Thu May 06, 2004 2:17 am
I took the below photo of a JAL 777-300 @ BFI a few day's ago. Usually, 777's are tested out of Everett, except for the 777-300ER's which were based out of BFI during the certification program.
The registration number has been used by the second 777-300ER airframe, but is now on this aircraft.
So my question is, does JAL have 777-300ER's on order, and can anyone confirm if the plane in the photograph is an ER or not?
Photo © Jet City Aviation Photography
Thank you for any help on this subject.
ulfinator
RE: Does JAL Have 777-300ER's On Order?
Thu May 06, 2004 2:19 am
Yes they do. They are getting the second 773ER to be delivered.
LN-MOW
Thu May 06, 2004 2:23 am
''The registration number has been used by the second 777-300ER airframe, but is now on this aircraft. '''
It's the same aircraft.
- I am LN-MOW, and I approve this message.
gigneil
Thu May 06, 2004 2:25 am
Indeed, they are the same aircraft.
N
Bronko
Thu May 06, 2004 2:29 am
Excellent, thank you all for clearing this up so quickly. I originally uploaded it as an ER, but submitted a correction after recieving email that JAL is NOT recieving any ER's.
Thanks again!
gigneil
Thu May 06, 2004 2:32 am
Another case where the engine doesn't look as big as expected due to the angle.
The GP7200 on the 343 is the first case this week.
N
B2707SST
Thu May 06, 2004 2:39 am
Bronko-
You were right the first time. JAL ordered 8 777-300ERs on March 31, 2000, which was the launch order for the type. N5016R was the second prototype and wore the Boeing 773ER colors for a while, but was recently repainted in JAL colors in preparation for delivery. You can see the raked wingtips in your photo outboard of the wingtip nav lights.
--B2707SST
Keynes is dead and we are living in his long run.
ConcordeBoy
Thu May 06, 2004 2:53 am
...or, ya could have actually read the captioning  Big grin
dynkrisolo
Thu May 06, 2004 3:24 am
You must mean the Trent 900.
gigneil
Thu May 06, 2004 3:46 am
I did, in fact, mean the Trent 900.
N
as739x
Thu May 06, 2004 3:47 am
I believe its 16 773ER's going to JAL? Anyone can correct me but that what I remember hearing.
ASSFO
