andz
744 - What Are These?
Fri May 14, 2004 2:59 am
What are the two black things on the fuselage just behind the pitots?
Photo © Fanie Kleynhans
RE: 744 - What Are These?
Fri May 14, 2004 3:02 am
If you mean those jagged hook like things, they are sensors. If you mean the black things behind the cockpit, they are windows.
N777UA
Fri May 14, 2004 3:03 am
I assume you are talking about the black things under the first window group...those are the pitot tubes. They measure the airspeed of the airplane.
henpol747
Very funny Roberta, I thing they must be sensors of some kind
Vive la France! ¡Viva México!
LHRman
Fri May 14, 2004 3:04 am
Rob- You can be sarcastic sometimes! They are indeed sensors and I can't actually see anything else behind the pilots so this must be what you mean!
Thanks Dave  Big thumbs up
Always after the picture you can't get..
andz
Fri May 14, 2004 3:06 am
7 windows from the front, lower deck, one black thing directly under it and one further down. Not the pitots, I know what a pitot is and what it does.
Edited to remove sarky comment.....
[Edited 2004-05-13 20:08:42]
Toni_
Fri May 14, 2004 3:13 am
Hi Andz
Its that little "flag" called the angle of attack indicator and static probe
LHRman
Fri May 14, 2004 3:15 am
Have no idea, sorry dude, probably some sort of dent? or marking?!
I really couldn't say.
andz
Fri May 14, 2004 3:18 am
Wish I could edit the pic and draw a circle round what I'm referring to, usually the angle of attack indicator is on the port side. Thanks for the input anyway, I have this pic as my desktop and wonder what they are every time I switch on!
henpol747
Fri May 14, 2004 3:21 am
Maybe tech/ops would be an option to be sure!!
Henpol747
Fri May 14, 2004 3:22 am
I reckon they are air pressure sensors
InnocuousFox
Those are the engines!
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
Toni_
Fri May 14, 2004 3:25 am
This photo shows it clear
Photo © Daleen Brits
They're on both sides of the aircraft. Just like the pitot static tubes.
Theres one for the pilot and one for the F/O :p
[Edited 2004-05-13 20:31:52]
A388
Hi Andz,
Maybe you should post this thread in the technical/operations section of this forum. There you will definately get your answer. It's a good question though, I'm curious myself  Wink/being sarcastic
A388
av757
Fri May 14, 2004 4:35 am
On the photo loaded up above in reply 12, the probes are in the following order top to bottom on the right side of the aircraft:
  1. Right angle of attack sensor vane
  2. First officers pitot static probe
  3. Auxiliary pitot static probe
  4. Total air temperature probe
Regards:
AV757
Moolies
Fri May 14, 2004 4:47 am
AV757 is dead right, they are static "tubes" the pitot sticks out and faces the front of the aircraft, you cant measure wind speed on a plane when the pitot doesnt face the direction that the plane is flying in.
Leskova
Fri May 14, 2004 4:53 am
Moolies - close, but not quite...
Andz was referring to numbers one and four from AV757's list, so not the pitots but the sensor vane and the temperature probe.
Frank
Smile - it confuses people!
