cre
No Strobe On UA 737 At PIT
Fri May 21, 2004 9:09 am
Yesterday afternoon (May 19) I was sitting in Pittsburgh at gate C51 (I believe) in Pittsburgh waiting for my flight home on Midwest Connect. While watching planes come and go I noticed a UA flight 973 to Chicago depart from the gate next to C51.
I noticed the red strobe light (both on top and bottom) wasn't on. It pulled away and taxied out of view still with no strobe. Would this be a case of it being burned out? I can't recall ever not seeing a strobe not on while an aircraft was in service. Any thoughts?
MD11LuxuryLinr
RE: No Strobe On UA 737 At PIT
Fri May 21, 2004 9:38 am
It should definitely be on, that's for sure.. Especially if it's the red beacon light.
1. The pilots never hit the switch.
OR
2. The system is inop, even if the pilots didn't forget to switch it 'on'.
Anyone else?  Big grin
Caution wake turbulence, you are following a heavy jet.
OPNLguy
Fri May 21, 2004 9:43 am
Don't know if the flight you saw forgot to turn it on, or whether it was inop (I suspect the latter), but the aircraft can operate with both red anti-collision strobes inop in day operations. If the aircraft is also equipped with white strobelights at the wingtip/tail, the aircraft can also operate at night with the red anti-collision strobes inop.
(Assuming that their MEL is the same as ours....)
planespotting
Fri May 21, 2004 12:44 pm
you're seeing things. it probably failed "in the air en route"  Big grin
Do you like movies about gladiators?
wjv04
Fri May 21, 2004 12:52 pm
Its called a beacon, the strobe is the white light, flashing in a strobe like fashon.
Pilot probally had it on, and fliped it off when he ment to turn it on.
No big deal
September11
Fri May 21, 2004 12:56 pm
day light time or night time? if it happened during night (dark) time, it could be a serious mistake
Airliners.net of the Future
m404
Fri May 21, 2004 4:57 pm
When I turn over an aircraft to depart my gate I always watch BOTH the top and bottom red ac lights. If one is out I note it in log and if both are out I have our control contact the crew for notification. It's nearly always just an oversight but I wait until the aircraft is ready to depart the ramp area onto an active taxiway before calling. That gives them any "rolling checklist" time.
Less sarcasm and more thought equal better understanding
