kcrwflyer
Point To Point Or Hub And Spoke?
Sat May 22, 2004 11:32 am
which is better to you, and wchch is better to the overall prosperity of the airlnes and all cities with at least a 300,000 pop. base.
elwood64151
RE: Point To Point Or Hub And Spoke?
Sat May 22, 2004 11:50 am
Each system has its own merits. It depends entirely upon how that system is utilized. A P2P airline run poorly will fail. A hub-and-spoke airline run poorly will fail.
Personally, I prefer hub-and-spoke, but I don't dismiss P2P airlines. Hub-and-spoke allows one to travel to those tiny destinations that wouldn't be served otherwise. P2P gives one the option of more direct and n/s flights.
Again, it's all dependent upon how the airline actually operates.
Those who fail to learn history are doomed to repeat it in summer school.
InnocuousFox
Sat May 22, 2004 12:37 pm
Think about your question. If you believe that it is remotely possible that it has been pondered by someone else in the past, search for it.
Dave Mark - Intrinsic Algorithm - Reducing the world to mathematical equations!
InnocuousFox
Sat May 22, 2004 12:42 pm
Just for fun, I will repost something from one of those archived threads here:
People are continuing to talk about the efficiency for the airline and yet we skip over the efficiency for the passenger. THAT is the whole reason the concept of a banked hub system came into being. The premise was that a passenger from any feeder city could fly to a hub and, within the same bank, find a connection to any other feeder city on the network.
If you have 50 feeders (+ the hub = 51 cities), you need 50 gates at the hub... 50 arrivals in a short period of time, a long enough waiting period to turn the aircraft and allow pax to connect and then 50 departures. That simple example leads to 2500 O&D pairs where the pax has a maximum of 2 legs and a reasonably short connecting time. In a PtP network of 51 cities, you aren't going to be able to tell a pax that he can get to all 50 destinations in 2 legs at all much less with a "reasonable" connecting time.
The reason that a rolling hub is able to work now is a side effect of the demand for more frequent flights. As airlines increased the number of smaller aircraft and increased the frequency of flights, they were able to begin spreading out the bank because passengers were no longer waiting for "that big airplane to ---". Instead, they were waiting for "one of the smaller airplanes to ---".
One of the reasons that people are under the impression that PtP works so well is that it is being done in a largely hub-based environment. Southwest specifically tried to connect large O&D pairs that were not served directly - thus catering to people with shorter (direct) flight times. If there were no hub systems, point to point would be a disaster to get from A to most of the Bs out there. It is simply mathematically impossible to generate the same number of O&D connections using solely point to point systems.
What is the answer? Obviously for the larger airlines that serve the most markets, they must continue to operate hub-based airlines... else no one will ever be able to get to places like Enid, OK and Pocatello, ID. Whether that be rolling hubs, RJ hubs or both, the hub and spoke system cannot go away without taking a large number of potential pax out the door with it.
tungd
Sat May 22, 2004 12:47 pm
In my opinion, medium to small markets (250k to 500k base population) are under-served by the traditional hub system. Here in Texas, if you live anywhere other than Dallas-Fort Worth or Houston, for the most part you have to connect through either DFW or IAH to go anywhere else in the U.S. (or the world). The only exception is Southwest Airlines, which is great at what they do, but the only smaller markets they serve in the state are 5+ hours drive-time from the hubs (MAF, LBB, AMA, CRP), and even then the majority of their flights are to DAL or HOU (which are many miles from the DFW and IAH hubs).
Regional jets offer a real point-to-point alternative for smaller markets, but it's doubtful that will happen anytime soon. My hometown airport, ABI, is currently served by AE and COEX/SkyWest, with 4 RJ and 5 prop round-trips daily to only DFW and IAH. The average load factor is 80-90% or more, and a recent study indicated that the top out-of-state destination is ATL; however the chances that Delta/ASA will initiate at least one RJ ATL-ABI round-trip a day are negligible for the foreseeable future.
I know this is not the best example; ABI's 300,000 base population extends 80 miles from the city center, and DFW is only a 2 1/2 hour drive from downtown. However, point-to-point service utilizing at least RJ's would definitely benefit the economies and quality-of-life of small-to-medium markets such as ABI.
InnocuousFox
Sat May 22, 2004 12:52 pm
"However, point-to-point service utilizing at least RJ's ..."
Connecting to how many points, though? I think you are needing more connections to hubs. No offense to ABI, but NO ONE is going to connect you P2P with 100+ other cities around the country. It would be impossible to fill even ONE RJ to each of the 100 cities per day.
For cities your size on down, the ONLY way you are going to be adequately served is by a hub-based network.
Coronado990
Sat May 22, 2004 1:47 pm
I have a 1962 OAG. I think most people agree that there was a pt to pt system back then. What would be interesting is if someone would throw a couple of city pairs at me, small to mid-size, and I'll post the routing and schedule from 1962. Then we can compare which system is better. Remember there are probably only one fourth the flights back then, but I have a feeling most will turn out pretty efficiently. Certainly more fun.
For example...Pocatello to Enid:
WA 5
DC-6B
PIH 7:43a
SLC 8:31a
UA 592
DC-7
SLC 9:40a
DEN 11:20a
CN 95 (Central Airlines)
DC-3
DEN 11:40a
WDG 4:48p*
* via Colorado Sprs, Pueblo, Guymon & Liberal.
Uncle SAN at your service!
tungd
Sat May 22, 2004 1:58 pm
Very true, Innocuous....
After reviewing my previous post, I was more focused on long-range hub operations, rather than true point-to-point. P2P flights between small-medium markets will probably never be feasible, and I realize that. It's just wishful thinking on my part that RJ's will someday expand non-stop options between smaller markets and hubs nationwide.
BTW, I currently live only 15 miles from IAH; so I don't even know why I'm complaining, since I can fly almost anywhere non-stop, including my hometown! LOL
InnocuousFox
Sat May 22, 2004 11:09 pm
The primary use of P2P should be to connect the spokes of high-volume city pairs, thereby bypassing the hub. If you have a large number of people going between A and B, why force them to connect? You know they are doing it anyway. However, that is still a hybrid system based mostly on the hub concept.
Logos
Sat May 22, 2004 11:33 pm
Good example, Coronado. What people who pine for the "good old days" of point to point forget is that, prior to 1978, under the CAB, airlines couldn't have "comprehensive" networks because every route was subject to route authority granted by the CAB. I remember clearly the lobbying that went on between Eastern and Delta to get authority for the Atlanta-Denver route (which was granted to Delta). Before airlines were allowed to offer joint pricing (which happened sometime in the early 70s), the cost of going from one small airport to another was astronomical, but you still generally had to change airlines as well as planes.
That's part of the reason flying was seen as such a luxury outside of places like Texas and California which were large enough to spawn intrastate carriers (PSA & Aircal for California, Southwest & Trans-Texas, later Texas International, for Texas) that avoided CAB regulation. Also, the idea of a subcontracted "express" or "commuter" line that flew for your network didn't exist other than Allegheny Commuter.
Innocuousfox has laid out pretty well the case for the hub & spoke system that has made this kind of flying affordable under deregulation. It's not going away - what's currently at stake is exactly how many survivors there'll be left doing it in a couple of years.
Dave in Orlando
Too many types flown to list
kcrwflyer
Sun May 23, 2004 12:01 am
i agree with all of you. Its all about management. I think that if an airline has the right amount of both then it can prosper. Like run maybe 70 to 100 passenger planes to places like CRW, ROA, TRI, to hubs. But on some routes like JFK-LAX, LAX-DFW, LAX-ORD, ORD-IAD, those could be point to point cities, with no connecting flights.
Good answers people .  Big thumbs up
elwood64151
Sun May 23, 2004 12:13 am
You didn't just complete Dr. Coleman's Operations Management class, did you? I gave a presentation where I said basically exactly that!
More accurately, I'd say it's "with the option of connecting or non-stop flights, depending on when the passenger wishes to travel."
InnocuousFox
Sun May 23, 2004 12:55 am
"You didn't just complete Dr. Coleman's Operations Management class, did you? I gave a presentation where I said basically exactly that!"
With the aviation reference materials I have sitting around here, I could GIVE that presentation.
Trust me, when you have to write the computer Artificial Intelligence routines to completely duplicate the thought process behind market entry/exit, route network design, load management, fleet assignment and scheduling, you learn a LOT about how it works.  Smokin cool
frugalqxnwa
Sun May 23, 2004 1:12 am
I must agree with all of you, the hub-and-spoke system is here to stay and is the better of the two systems for large airlines erving smaller cities. The one item I must throw a monkey-wrench in is the statements that smaller markets do not get as good as P2P service as other markets. Not true. BOI has a mardet of less than 500k and has a good WN presence as well as being a mini-hub for QX, and WN has a larger presence at BOI than OMA, a market twice the size.
Personally, I prefer the hub system because the passenger has many more options for a better price. Whenever I try to get a quote from WN for flying OMA-BOI, they are usually the most expensive option. NW, UA, F9, DL, and HP are far cheaper and use the hub system.
If I were to run an airline, I would use a hybrid system based primarily on the hub system. The highest yield markets would have the option of bypassing the hub while the other markets would need to connect. HP is the best example I can think of off the top of my head of such a system being set up right now.
kcrwflyer
Sun May 23, 2004 3:35 am
BOI is an exception. My local airport is CRW, the city is onlt 60,000 people but the total market it serves is 600,000 people. And we dont have any P2P.
elwood64151
Sun May 23, 2004 3:38 am
Innocuous Fox:
Wanna' get together and build an airline?
OMA also has more mainline competition than BOI.
InnocuousFox
Sun May 23, 2004 4:01 am
"Wanna' get together and build an airline?"
I need to focus on continuing to build and airline management simulation/game. I will be happy with that for now.  Smokin cool
elwood64151
Sun May 23, 2004 6:39 am
Mark,
When you're ready to invest in an airline, let me know... Believe me, you and I could work magic together!
How's MD-87s-come-717s out of MCI sound? Simulate that one in your game!
:D Cheers!
kcrwflyer
Sun May 23, 2004 6:44 am
when that games's done will anyone here get a discount, or will it not be expensive
InnocuousFox
Sun May 23, 2004 12:14 pm
"when that games's done will anyone here get a discount, or will it not be expensive"
That would largely be up to the publisher. I'm not thinking that far ahead yet.
