752is
Non Rev To DAB
Sat May 29, 2004 6:15 am
I'll be going EX JFK LGA or EWR to DAB. As far as I can see it looks like my best bet would be Delta through ATL. I'll be going approx 15,16,17 of June coming back 18,19 of June. If anyone has any suggestions please let me know.
Thanks in Advance
chepos
Help With SSong Flight?
Sat May 29, 2004 6:19 am
What about Continental Express (EWR-DAB nonstop) or comair via CVG.
cHEPOS
Fly the Flag!!!!
752is
RE: Non Rev To DAB
Sat May 29, 2004 6:42 am
As far as I know CO express has only 2 flights daily out of EWR. 1 at 0800 and the other at 1700 don't feel like sitting around all day if I miss the first one. I know I'm nonreving and have done this all my life just trying to have options and not be stuck somewhere, be at an airport with options.
skyhawk
RE: Non Rev To DAB
Sat May 29, 2004 7:50 am
752is-Just a hint for you, consider if you can MLB. Not very far from DAB and the traffic is usually not as bad as there. You can still go from JFK or LGA, not positive if you'd need to go through ATL without going on the Deltanet though. Is your nonreving through Delta or will it be a % ticket?
Dalmd88
RE: Non Rev To DAB
Sat May 29, 2004 4:57 pm
I've done the ATL-DAB route a bunch on DL. Midday flights usually are full. MLB is sometimes an option but I've found it to be full many times also. GNV is usually the only Central FL airport with empty seats. Some times JAX works also. Traveling midweek should help.
