3green
Is The A380 Powerful?
Mon May 31, 2004 7:57 pm
Hello, was just wondering if anybody knows how the takeoff , climb power, etc of the A380 compares to other large aircraft, like the 747s, 777s, etc?
I have read it will have somewhere around 32000lb of thrust, which sounds like a lot, but i imagine it will be propelling a lot of weight, especially when fully loaded, in hot weather, and so on. Can anybody tell me how well it will compare? Thankyou.
Jkw777
RE: Is The A380 Powerful?
Mon May 31, 2004 8:12 pm
Hopefully the A380 should be equally powered as like most aircraft.
I imagine that the Trent 900's will have more than 32,000 lbs of thrust.
Justin  Big thumbs up
jkw6210@btopenworld.com or +447751242989
scottysair
Mon May 31, 2004 11:08 pm
I will think about powerful with A380.
ConcordeBoy
Mon May 31, 2004 11:39 pm
The A388 will have nowhere near the 757's power/weight ratio, but it's not exactly A340-like either  Big grin
PW100
Mon May 31, 2004 11:49 pm
Goto http://www.airbus.com/product/a380_planning.asp which will allow you to RMCSFA all A380 data, from aircraft desription to interior arrangements, from airplane performance to pavement data.
Engines will be a choice of RR Trent 900 or GP7000 rated at around 70,000 lbs each. So a total of 280,000 lbs of thrust.
Goto http://www.rolls-royce.com/civil_aerospace/downloads/airlines/trent_900.pdf for RR Trent 900 fact sheet.
I would assume that take-off thrust to MTOW ratio for the A380 will be comparable to the 744. The 777 will have much better power to weight ratio, as would have all twin engined airliners.
PW100
PS.
LMCSFA = Left Mouse Click, Save File As
