andz
LHR Short Transfer
Sat Jun 05, 2004 3:32 pm
I will be flying JNB-LHR-PRG-LHR-JNB early July, and I was wondering about transfers at LHR. As far as I know, BA European flights go out of T1, long haul from T4.
I got my ticket yesterday and the travel agent has a pretty tight schedule. If I check my baggage right through is an hour enough?
ualonghaul
RE: LHR Short Transfer
Sat Jun 05, 2004 3:49 pm
So you are taking BA through Heathrow from JNB? Or is the JNB-LHR on SAA?
Every experiance I have had at LHR transfering has not been a quick or easy one. LHR is a monster. I would think if your on BA the whole way than they may be able to get your bags over in time (they do not like keeping baggage from a person who has already departed anymore, or fly baggage on a plane that does not contain the pax).
andz
Sat Jun 05, 2004 4:08 pm
BA all the way, if it was SAA I wouldn't worry cos SAA uses T1 so no terminal change necessary. I did a transfer at LHR once before and that additional security that you go through to change terminals can be very busy that's why i was worried about the short time to transfer.
ChrisZRH
Sat Jun 05, 2004 4:27 pm
usually BA caclculates 2h transfer! how much do you got?
Christian Galliker - AirTeamImages
andz
Sat Jun 05, 2004 4:34 pm
the schedule I saw from my company's travel agent didn't allow much on the return leg, if I recall correctly the flights are:
BA857 PRG-LHR 18:55/19:55
BA57 LHR-JNB 21:00/08:50
so just over an hour. Unfortunately I can't leave Prague any earlier.
LJ
Sat Jun 05, 2004 5:27 pm
Didn't BA move the JNB flight to terminal 1?
Gman94
Sat Jun 05, 2004 5:28 pm
Andz
BA's Jo'burg flight's now depart from Terminal 1, they switched them from Terminal 4 last October. They changed this due to the high number of passengers connecting from their European flights on to the Jo'burg flight.
British Airways - The Way To Fly
soups
Sat Jun 05, 2004 5:40 pm
you will need 2 rush jnb operates now from T1 so same terminal
Next destinations, Suarabaya, beirut, paris, Accra
mikedlayer
Even if you do have to transfer, I believe it takes about 20 minutes. I think you can either walk through a connections tunnel or take a connecting bus between the terminals?
Mike
col
Sat Jun 05, 2004 6:56 pm
LHR should have a minimum transfer time of 1 1/2 to 2 hours for connecting T3/T4 to T1 in the morning. It is a disaster. Later in the day is not too bad. As you are T1 to T1, you should be ok with 1 hour.
AMS
Sat Jun 05, 2004 7:48 pm
LHR could be a nightmare, If you Transfer at LHR Always take plenty of time in between flights. However if you are booked as a {through Fare} and for some reason you miss your connecting flight, then the airline which took you to LHR is fully responsible for your missed connecting flight.
AMS
andz
Sun Jun 06, 2004 12:14 am
Okay BA T1 is news to me, that might help, thanks people.
Users browsing this forum: 7BOEING7, ARNPEK, Baidu [Spider], bluefltspecial, ChairmanRobbo, czpdx, Ducari, flydia, flyguy89, FlyingSicilian, GordonCC, jetmatt777, jsnww81, LazarosK, Majestic-12 [Bot], MaksFly, N14AZ, ordpark, rhuns, Softaero, speedbored, United1, zkncj and 6 guests
