BILLAMT
Colgan 1900 Accident Article
Mon Jun 14, 2004 9:44 am
http://www.capecodonline.com/cctimes/fatalcolgan9.htm
_______
Now thats two 1900's in two years where MX failed to visually check flight control movement after MX. I just don't understand.
thunder9
RE: Colgan 1900 Accident Article
Tue Jun 15, 2004 1:01 am
BillAMT --
What is the second accident that you refer to?
-J
"Keep thy airspeed up, less the earth come from below and smite thee." - William Kershner
UN_B732
Tue Jun 15, 2004 1:22 am
Perhaps Mesa Beech 1900?
But I thought that was weight & balance in addition to control.
-Mr. X
What now?
Cubsrule
Tue Jun 15, 2004 1:52 am
The general consensus on the Air Midweest 1900 accident in CLT in January, 2003 is that the aircraft was slightly overloaded but that this would not have been a problem if the flight controls had been properly rigged.
BILLAMT
Tue Jun 15, 2004 6:32 am
The Air Midwest beech ( Mesa ) is the other. Yes weight and balance was an issue, but it would have been a flyable aircraft had the elevator been rigged correctly. Read the NTSB report regarding the accident. The MX crew at the WV repair facility openly admitted to skipping steps and not performing a visual check of the elevator. I've been a mechanic for many years, I just don't understand how you could not perform a functional check on someting so critical. Thats like installing a new engine and not even bothering to start it to make sure it works. I'm just baffeled.
