ConcordeBoy
How're They Gonna Flight-test 7E7 Engines?
Fri Jun 18, 2004 10:42 am
DfwRevolution got me thinking about this...
...since these engines will be nigh-bleedless, and no other aircraft currently can utilize such a system: how will GE/RR flight-test the new 7E7 engines??
whitehatter
RE: How're They Gonna Flight-test 7E7 Engines?
Fri Jun 18, 2004 10:46 am
On a 747 testbed aircraft such as GE operate. As long as bleed air from the other engines is available it's not a problem.
Rolls will probably make their own arrangements, but in the past have used anything from the 747 prototype to a RAF VC10!
I somehow don't think the A340 testbed aircraft will be available this time....  Wink/being sarcastic
[Edited 2004-06-18 03:48:29]
Lead me not into temptation, I can find my own way there...
DfwRevolution
Fri Jun 18, 2004 10:49 am
I'd like to know how I inspired such thought, as you've stupified me as well...  Smile/happy/getting dizzy
I guess GE will just use the 747 engine testbed. That aircraft has 3 other engines off of which to divert bleed-air, and all that must be tested is the electrical output of the engine right? The single GENEX will probably juice out more voltage than the other three engines combined, but that's what the 7E7 needs.
boeingbus
Fri Jun 18, 2004 10:52 am
But I can see where he is coming from... never thought of that...
But agree it would have to be a modified 4 engine plane like a 747 that would allow all the pneumatic controls to be powered on 2 classic engines and the other 2 would be 7E7 test engines.
Airbus or Boeing - it's all good to me!
whitehatter
Fri Jun 18, 2004 10:53 am
Have you seen the pictures of the GE testbed with the GE90 fitted?
Photo © Je89 W.
That's a great picture for getting the scale of the GE90 against existing 747 engines
The testbed would generally only carry one test engine in case of a fault developing with both experimental engines. That's why a 747 testbed would have three standard units, to ensure safe operation.
[Edited 2004-06-18 03:55:59]
planemaker
Fri Jun 18, 2004 10:54 am
And don't forget that for part of the flight regime they at least still have the APU available.
Nationalism is an infantile disease. It is the measles of mankind. - A. Einstein
ConcordeBoy
Fri Jun 18, 2004 11:03 am
To add to this subject...
...I'm curious as to how Boeing will test the various associated systems (that will sustain human life sans engine-bleed) in an actual flight?
ConcordeBoy
Fri Jun 18, 2004 11:08 am
Your last reply on this thread:
http://www.airliners.net/discussions/general_aviation/read.main/1615440/
whitehatter
Fri Jun 18, 2004 11:13 am
Probably on the 7E7 prototype, with the test crew outfitted with breathing apparatus.
They could also adapt one or two of their in-house aircraft to test out certain components before the prototype is assembled. The only systems which will need to be tested are pressurisation and heating components, and they do have experience in non-bleed-air pressurisation from years ago as well.
Early 707s were not pressurised using bleed air. They had separate compressor assemblies.
DfwRevolution
Fri Jun 18, 2004 11:31 am
Lol.. I'll be damned.. anyway this is an interesting line of thought you have raised. But don't think I deserve credit for triggering it  Laugh out loud
Most likely through a combination of ground testing, testbed testing, and 7E7 certification. Boeing can test the enviornmental system on the ground, test the engine on the 747 testbed, then certify the two together on the actaul airframe.
Given the accuracy of computer simulation and that new versions of CATA allow Boeing to simulate system interaction, and with test results from both the engines and enviornmental systems in hand, Boeing should have a good idea of how the system will work far before roll-out. Then a rigerous certification regimine, Boeing should be able to prove the system.
The bleedless systems of the 7E7 will definitly be one of the most challenging aspects of 7E7 development. An analogy might be drawn between the 777 and ETOPS development and the 7E7 and bleedless development.
Well if they need breathing devices, other than just out of precaution, Boeing might have some certification issues to work out...
whitehatter
Fri Jun 18, 2004 11:34 am
Out of precaution. Boeing are notoriously conservative when it comes to testing.
Which is no bad thing, and why their products have the reputation they do.
ConcordeBoy
Fri Jun 18, 2004 11:50 am
CATIA  Big grin
Understood, but not so sure they're in the same magnitude.
I mean, ETOPS180 was being done before the 777's EIS. Bleedless technology to this degree has never been opped in pax transport before.
...perhaps when 777s start opping ETOPS240/330 will the analogy be more accurate  Big grin  Big thumbs up
whitehatter
Fri Jun 18, 2004 12:01 pm
I can't see bleedless being a major issue.
In the tradition of redundancy, there will be duplication of systems. It's just a case of providing electrical compressors and heating elements.
Hardly bleeding edge technology (ouch!)
Please feel free to shoot me for that one.... Big grin
a380900
Fri Jun 18, 2004 2:21 pm
The test engine need not be compatible with the remaining three. As Airbus points out about the Trent 900 testbed, it works with 5000 psi systems whereas the three other engines work with traditional 3000psi.
They have the entire empty aircraft to create a setting which makes the new engine working although it is different from the rest. Not a big challenge in my view.
Vorticity
Fri Jun 18, 2004 2:42 pm
It seems for the 777 program, they tested their Trent 800 on a Boeing 747 testbed. I found the information burried at the bottom of this webpage.
http://www.bcctc.ca/britjets.html
Not sure if that was a Boeing owned testbed, or what.
Thermodynamics and english units don't mix...
C130HERCULES
Fri Jun 18, 2004 10:26 pm
That pic of the GE-115B on the 747 really gives the a/c some scale and simply dwarfs the other PW powerplants. What a blower that is.  Wow!
Vacation - ''Time wasted between two flights''
whitehatter
Sat Jun 19, 2004 1:23 am
They used the prototype 747. It had, until recently at least, stickers on the forward fuselage showing that it had been used in the Trent 800 trials
When Rolls flight tested the first RB211 engine, they used a VC10 with 2 engines removed. Unfortunately that aircraft had to be written off as the imbalance twisted the airframe out of shape!
[Edited 2004-06-18 18:26:24]
FTOHIST
Sat Jun 19, 2004 1:33 am
It'll be tested in the #2 position, just like all the other test engines (with the exception of the CF34-8 in the ferry position, of course). Look for some MAJOR mods to the existing electrical load simulation system, which may include adding some fairly large bumps to the fuselage. I'd say it will be about the most ambitious flight test program seen on that airplane, and probably its last before retirement, since it can't carry a more powerful GE90 than the -115B.
Vorticity
Sat Jun 19, 2004 2:11 am
Hmm, last I saw that plane was in 2000, it was sitting next to a parking lot of Boeing Field, got a cool picture of my car with the 747 as a backdrop. I think it had all 4 engines off. I'm not sure if it's in flying condition anymore or not.
 Big thumbs up whoops
whitehatter
Sat Jun 19, 2004 2:41 am
It'll eventually be fully restored and parked undercover. There are plans to extend the museum at Boeing Field to bring it and the 727/737/Concorde etc into a new building.
There are some pictures of the RB211 test bed and more info here
http://www.vc10.net/History/Individual/XR809.html
caetravlr
Sat Jun 19, 2004 3:18 am
Is any of the technology being used for the bleedless systems on the 7E7 available from any military experience that they may have? I know that a lot of their planned use for composites has a military background, but I was wondering about any of the new power systems they are planning? I wouldn't guess that it would, but it would be interesting to know.
A woman drove me to drink and I didn't have the decency to thank her. - W.C. Fields
CXA340
Sat Jun 19, 2004 4:41 am
Excuse my ignorance...but what exactly is the difference with the new 7E7 engines compared with other models? I realize some of the basic engineering differences Boeing has talked about, but why make the engine completely bleedless? Will this mean a different way of starting the engine? And then, to follow up on a previous post, then would this mean entirely new systems for the interior since they will not be bleeding air off of the engines? Will this plane be more electrical in nature than mechanical?
ConcordeBoy
Sat Jun 19, 2004 4:44 am
Because of the same word you're going to hear associated with the 7E7 throughout its "life"---
EFFICIENCY
whitehatter
Sat Jun 19, 2004 4:57 am
Electrical systems are more efficient than compressed air systems.
There is a weight saving as well as increased flexibility on what machinery goes where. Complex pipe and hose assemblies from the engines are eliminated.
caetravlr
Sat Jun 19, 2004 5:00 am
Based on what WhiteHatter says, then not only will the plane weigh less, but it will also be more efficient, because (if I understand this correctly), that bleed air that is sucked off the engines takes away from the actual thrust that is being used to propel the aircraft. Is that right? This would mean that the engines are more efficiently propelling the jet.
ConcordeBoy
Sat Jun 19, 2004 5:03 am
Correct, among other things
Okie
Sat Jun 19, 2004 5:04 am
General Electric will have to borrow some of those huge dynamic brake resistors they use on their train engines for load simulation if they plan to do electrical load testing on pylon in flight.
Okie
phollingsworth
Sat Jun 19, 2004 5:51 am
Well now that aircraft engines and the old transportations systems have been combined into GE transportation systems, at least they will stay in the same division within GE.
Blackbird1331
Sat Jun 19, 2004 6:07 am
What the hell was it bleeding? Throw it it on a 757 and get it done with.
Cameras shoot pictures. Guns shoot people. They have the guns.
Alessandro
Sat Jun 19, 2004 6:20 am
If they would like to be on the extra safe side they could use the AN-225
and only replace one of six engines....
Vorticity
Sat Jun 19, 2004 6:23 am
Probably can't fly the 757 on only one certified good engine.
FTOHIST
Sat Jun 19, 2004 6:36 am
Yeah, that's what the airplane is doing in HAECO right now-having "GE Transportation" painted on it instead of "GE Aircraft Engines". So, now it can also use GE Rail technologies in concert with its flight test stuff!!!!!
They'll just expand the load bank pod into a super-pod and that will take care of electrical load tests
