Check Out This Fantastic Site!
Wed Feb 16, 2000 3:20 am
I found this great site today that allows you to plan any flight in the world. It's really easy to use and gives you a map of the route when done.
You type in your route (from/to airport) between any 2 points in the world and specify altitude, speed and aircraft range etc (If the route is beyond range it will schedule refuelling stops)
You can even specify the airports used must have ILS or a runway of a certain length, and you may use eithere high or low altitude airways
It will calculate the trip and even shows a map of the route!
Check it out;
http://www.fallingrain.com/air
Let me know what you think!
James
RE: Check Out This Fantastic Site!
Wed Feb 16, 2000 12:56 pm
I can't believe nobody likes this site!
I thought it was really good!
Check it out;
James
MD11DC10
Wed Feb 16, 2000 3:13 pm
Wow. Dont have much time to check it out but it is amazing. It shows you everything. Type in the two airport codes and thats it. It gives you a map and shows you the cities that you fly over and maintain radio contact with as well as what airspace you fly into. Everyone sheck this out!
Pilot1113
Wed Feb 16, 2000 3:24 pm
Okay... Okay... settle down Jet Setter!
I checked out the site and I'm amazed! It's totally cool!
It deserves a bookmark!
- Neil Harrison
Users browsing this forum: admanager, Bing [Bot], BoeingVista, BreninTW, ehaase, EIDAA, frmrCapCadet, Google Adsense [Bot], itisi, JAmie2k9, JerseyMike, kaitak, lhpdx, msycajun, nikeson13, nzrich, RightRudder, ssteve, tharanga, TNST3B, ty97, Yahoo [Bot] and 288 guests
