BDRules
Shortest Flight From IAD? Also Cheapest?
Mon Jun 28, 2004 2:07 am
I am travelling to IAD in AUG with bmi from MAN and was wondering what the shortest route is from there and also whats the cheapest route most commonly.
Kind Regards
Stu
ps good to be back up and running after 1 month without computer
gigneil
RE: Shortest Flight From IAD? Also Cheapest?
Mon Jun 28, 2004 2:10 am
Um, I'm fairly sure you can fly IAD-BWI if you want. Its 39 nm.
N
jeffrey1970
Mon Jun 28, 2004 2:16 am
Gigneil,
United Express used to fly from IAD to BWI but not anymore. I would say the shortes flight from IAD might be to Harrisburgh, PA on United Express. United says that flight is only 83 miles on there website. Maybe the United Express flight to Richmond is shorter.
God bless through Jesus, Jeff
DCAYOW
Mon Jun 28, 2004 3:20 am
The shortest flights from IAD are all operated by United Express and will probably be expensive because none are on the July route system of Independence Air:
OAG schedules is the source:
Charlottesville VA (CHO) is 78 miles
Harrisburg PA (MDT) is 91 miles
Richmond VA (RIC) is 100 miles
State College PA (SCE) is 127 miles
Philadelphia PA (PHL) is 134 miles
Independence Air has really shaken up the fares, best to check flyi.com for up to date fares and dates of service introduction.
Retorne ao céu...
MoneyShot
Mon Jun 28, 2004 8:18 am
I once checked the fare from BWI to IAD and I remember it being quite expensive but then again, most short hop commuter flight are expensive if they aren't part of a connection. Although strange, it did make sense from those in the Baltimore area who were needing to make connections to UALs IAD hub.
Mon Jun 28, 2004 8:28 am
Boo yah Charlottesville. You definitely won't find a cheap fare r/t there though. Agreed with DCAYOW; look for routes where IAir competes with UA (i.e. not IAD-CHO-IAD).
FutureFO
Mon Jun 28, 2004 10:26 am
Just check www.flyi.com That will give you the cheapest routes out of IAD.
Sean from MCO
I Don't know where I am anymore
flyf15
Mon Jun 28, 2004 10:31 am
Currently the cheapest destinations from IAD are Chicago, Charleston (WV), Norfolk, and Pittsburgh. Each is currently selling for $83RT, on a good selection of airlines (depending on the destination).
ludavid777
Tue Jun 29, 2004 1:04 am
Cheapest and shortest flight would be, Norfolk, VA (ORF), or Charleston, WV (CRW) Check www.flyi.com , $39 a way.  Smile Way better service than United Express and all jet service, no prop...
UN_B732
Tue Jun 29, 2004 10:03 am
Isn't Orlando like $99 RT; niec long flight and place to be  Smile
-Mr. X
What now?
