BA
Great Circle Mapper
Sun Jul 04, 2004 11:12 pm
I'm sure many of you know the Great Circle Mapper website:
http://gc.kls2.com
I was wondering if this excellent program takes into account the fact that the Earth is an oblate spheroid? Or does it consider the Earth to be a perfect sphere?
Just wondering to get an idea about its accuracy.
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
scottysair
RE: Great Circle Mapper
Sun Jul 04, 2004 11:13 pm
BA,
This is very good website of the Great Circle Mapper. I am sure you can do it for yourself. Sometimes, when I am use with their website on The Gret Circle Mapper.
VirginFlyer
Thu Jul 08, 2004 8:54 am
BA - perhaps it would be worth email the site's owner and asking - his email address is given on the bottom of the page...
V/F
It is not for him to pride himself who loveth his own country, but rather for him who loveth the whole world. The earth is but one country, and mankind its citizens.
Celebrating the Bicentenary of the Birth of Bahá'u'lláh, 21-22 October 2017
ly7e7
Thu Jul 08, 2004 4:47 pm
Although that is a great software I really doubt that that is the case. In order to take in account the Geoid (i.e. using a certain datum for the calculations) there is a need for a professional GIS infrastructure. If such was used I guesss we all would be paying for the GCM.
Still , a very good application, I use it a lot.
Regards.
2 things are endless: ignorance and space
timz
Fri Jul 09, 2004 7:29 am
As he explains, the Mapper uses the Clarke 1866 spheroid, which isn't the right one nowadays, but it seems to give distances correct within a small fraction of a kilometer. If he used a sphere the calculated distances would occasionally be off by 10 km or more.
Arcano
Fri Jul 09, 2004 11:06 am
Look how it draws the route SCL-SYD:
If it considered the Earth as a perfect sphere, why going down instead of suggesting a stright line across the pacific?
The software recognize thant the best route is going down, so it realizes the Earth is not a sphere!
in order: 721,146,732,763,722,343,733,320,772,319,752,321,88,83,744,332,100,738, 333, 318, 77W, 78, 773, 380, 73G, 788, 789, 346
BA
Fri Jul 09, 2004 6:11 pm
Thanks for all the replies.
A straight line across the Pacific would be the shortest distance if the Earth were perfectly flat.
However, since the Earth is a sphere, you cannot truly get an accurate drawing unless you draw it on a 3D model of the Earth. However, to simulate the sphere of the Earth, we draw the line curved, following the true path.
Take an orange, draw a line across it somewhere. Peel the orange carefully, and lay the peel flat and you will see that your line appears flat, taking a southernly or northernly course.
My suggestion also is you take a globe, and use a string and connect two points and experiment around with different routings, you will see what the shortest route is.
timz
Sat Jul 10, 2004 3:07 am
Take this example: use the Mapper to get the distance from ANC to LED; it says 6587 km. If they were using a sphere, that would imply a radius of 6394 km, based on the lat-lons they give. But if you try HNL-RAR, they give a distance of 4708 km, which implies a radius of 6338 km. So they're not using a sphere.
toltommy
Sat Jul 10, 2004 4:53 am
"I was wondering if this excellent program takes into account the fact that the Earth is an oblate spheroid?"
I'm pretty sure it did, but the name "Great Oblate Spheriod Mapper" just didn't have the same sex appeal. Darn those marketing people!  Nuts
A300/A310/A319/A320/A321/A332/A333/707/712/727/732/733/734/735/738/739/752/753/762/763/764/772/789/DC8/DC9-10/30/40/50/MD81/83/87/88/90/L1011-/250/500/CRJ200/440/700/900/EMB135/140/145/170/175/190/328Jet/F70/SF3/BE1/J31
