keesje
Airbus Mid Size/range A322, Will It Be Offered?
Thu Jul 08, 2004 6:00 am
Will Airbus push through the 220 seat A322?
It would have similar size/range as 757 but probably significant lower fuel burn like the A321 (one of things that accelerated the end of the 757) and full cockpit commonality with 320 & 330/40 family.
A 10-15 inch higher landing gear should allow for a higher BPR CFM56-5 version and the right angles during take-off and landing.
A stretch should be around 150inch/4 meters to make room for 30 extra passengers.
An enlarger wing could take care of the extra lift/fuel and a bigger landing gear. New AWIATOR technology could be included to give superior high density airport environment performance ..
If a shrink 330 is to big Airbus could go low risc with a A322 to fill the lower part of the A321-332 gab.
Potential customers : leisure carriers, trans continental´s, intra Asia / Europe carriers already flying Airbus aircraft or older B757´s/A310´s ...
Photo © Marlo Plate - IBERIAN SPOTTERS
hz747300
RE: Airbus Mid Size/range A322, Will It Be Offered?
Thu Jul 08, 2004 6:07 am
Do you mean a trans-Atlantic A321-size plane? It would be more comfortable than a 757 for passengers, as I like the A321 (flew USAir btw PHL-PHX). There would probably be a market for that as the older 757s are approaching old age.
Keep on truckin'...
solnabo
Keesje:
"Will Airbus push through the 220 seat A322"?
What you´re writing sounds great in my ears and yes, I hope so!
Mike//SE
Airbus SAS - Love them both
ConcordeBoy
Thu Jul 08, 2004 6:11 am
If the 737/7E7 combo proves to not be a successful replacement for the low & high-ends of the 757.... then perhaps there's a market for such an Airbus.
Francoflier
Thu Jul 08, 2004 6:15 am
I must admit that as a pax, I would consider that to be just too big an aircraft for one single aisle... And maybe not all that comfy for long haul flights for that matter.
That's why I just LOVE the A310, and for me there can be no replacement for it form actual A/Cs.
Now as an operator, I guess it would be rather interesting.
And after all, Airbus is now used to stretching their designs to the limit!
Thu Jul 08, 2004 6:16 am
If they got the range to between 4000NM-5000NM's, it would certainly be an excellent tool for an airline.
gigneil
Thu Jul 08, 2004 6:51 am
The question is, can the CFM56 or V2500 reach the necessary thrust?
jetBlue always wanted an A320.5, but who knows if people want A322s.
N
Thu Jul 08, 2004 6:59 am
wouldnt it be cool to see a 727 style A322.
Adv:Etops wouldnt be needed
nudelhirsch
Thu Jul 08, 2004 7:07 am
Not likely if a redesign of the wing is involved.
More stretch not likely too.
More likely a smaller 330, a -100 or so, but it would be a heavy airframe.
I do not see further stretching on the 321, as the tailstrike is (without bashing and battling now!) a known thing with the 321.
I, without now starting A<>B or something similar, see a higher change potential in a fleet strategy like Boeing used to have, with the 737 as small, 757 and 767 as medium and big medium, and 747 and later 777 as the real big ones.
Airbus on the other hand has great products like 320 and 330 to compete, but flexibility in the means of stretching or cropping is low, I would say.
Putana da Seatbeltz!
Buyantukhaa
Thu Jul 08, 2004 7:23 am
ETOPS will be less of an issue in the future, as at some point it is to be replaced with a similar system for any long-haul aircraft (think of the Air Transat A330 that ran out of fuel over the Atlantic - a four-engine plane would not have been safer).
As to the 322: fuselage plugs, higher landing gear and other engines seem to be fairly easy to implement from an engineering point of view, but what about the wings? If they can use easy plugs (unlikely) then it could work. But this series would only be a short-term stop gap in my opinion. And plenty of 757s around still...
Regarding the fuel efficiency: why not put some 7E7 engines underneath? If the 7E7 engines are really that much more economical, it might be interesting to offer existing aircraft types with the new engines, even if that would require recertification. Just a thought?
I scratch my head, therefore I am.
sandiaman
Thu Jul 08, 2004 7:41 am
To grow the A321 and boost the range, Airbus would need to redesign the wing, making it substantially heavier. In short, it would look a lot like the 757-300.
There is a really good article outlining the reasons for the dropoff in 757 sales. Here is a relevant quote from R. Aboulafia's Requiem for a Narrowbody:
"The intriguing aspect of the 757’s demise is that this is the first Boeing jetliner program to end because of market conditions, not technological obsolescence.. . ."
Full article at:
http://www.aiaa.org/aerospace/Article.cfm?issuetocid=451
The article lists a couple of reasons:
- Emergence of rolling hubs in the U.S. market, which favor smaller aircraft (as versus pulsing hubs)
-Emergence of post-deregulation LCC carriers in Europe (Easyjet/Ryanair), which have favored smaller aircraft.
Unfortunately, an upsized A321 would face similar market conditions. That said, it would have the advantage of cockpit commonality across the A320 line. Perhaps it would be received more favorably than the 757.
whitehatter
Thu Jul 08, 2004 7:50 am
An upsized 321 wouldn't generate much interest IMHO.
The proposed 739X from Boeing hasn't exactly stirred up much enthusiasm either.
That market segment appears to be dormant, which is why the 757 has finished. Just because there is a perceived gap in the market doesn't mean that there is an actual market. If there was a demand Boeing could have updated the 757; obviously they didn't see it being worthwhile.
Lead me not into temptation, I can find my own way there...
dutchjet
Thu Jul 08, 2004 7:56 am
While the a supersized A321 sounds like a good idea, I think Airbus would have problems with a further strech of the wildly popular A320 series - first, the wing issue as discussed above and, second, the power plant issue. New and different engines would be needed to boost performance of this larger airliner and the choices currently available are limited.
The other issue: is there are market for a large single aisle type at this point in time? Airlines worldwide are using smaller airliners for short to medium haul routes and larger aircraft for long haul, where does the A322 fit into the picture? The 757 remains a great aircraft, and one of the most economical ways to move +/-200 passengers, but airlines simply dont want 200 seats....the A319 and A320 are more popular than the A321 and the 739 is not a hot seller over at Boeing. With airports again becoming more crowded, one would think that larger aircraft would make more sense, instead airlines add more frequency and adjust hub operations.
While its true that Airbus has a gap in its lineup between the A321 and A332, and has no easy solution to plug this gap, maybe its not a big deal, as airlines are not looking for airliners in that size category.
boeingbus
Thu Jul 08, 2004 8:04 am
In my opinion... as also noted in a previous post - the closing of the 757 and the lack os support for 737 X suggests that Airbus should also not look into this A322...
Instead, Airbus should flex its new found muscles and propose a new generation of aircraft to directly compete with the 7E7 - before its too late... of course, they would need more state sponsored loans and bah blah blah....
Airbus or Boeing - it's all good to me!
bohica
Thu Jul 08, 2004 10:07 am
If Airbus could add a taller landing gear and re-engineer the plane to be able to handle the PW2037 or the RR RB211-535 engines, It might make a good 757 replacement. Just my thoughts.
DfwRevolution
Thu Jul 08, 2004 10:40 am
Regarding Keesje and Gigneil's comments on the CFM engine, I don't suppose the current CFM56-5C4 would be of much use as it is still a far cry from the lowest powerplant available on the 757. Re-engining the A32X family for the RB211 or PW2000 would be a serious headache unless a cantilevered engine pylon was used... oh wait that happens to be a Boeing patent.
10-15 inches of landing gear for a larger engine would be a necessity. The CFM website touts that 36k of sustained thrust has been achieved by the CFM56-5, but does the A322 have the market to justify a new engine derivative? And a lack of market is the reason the 757 line is closing in the first place,
As of now, the 7E7 engines are incompatible with just about every airplane in current service. Refer to the many "bleedless engine" discussions in Tech/Ops
To the real question.. I hope the answer is a resounding NO
Airbus has just completed a major aircraft development (the A345 and A346) which are now seriously threatened by the 777LR family. This drama isn't over, the A346HGW and Boeing's counter have yet to debut. Airbus is still working on the A380, which itself has had its share of headaches. I'm sure Airbus will heave a sigh of relief when it takes to the skies, but it too will require follow-up.... maybe an oversized wing wasn't a good idea. Now we come to the 7E7, an aircraft which has (arguably) already dug into A330 sales. Then there is the issue of both the A320 and A330/340 reaching the golden years in the next decade.
Sorry Airbus, but your resources are not that infinite. Ration your RD dollars, keep design teams efficiently moving from one project to another, don't worry about catering to every demand of every airline (cough cough SQ), and don't start frivolous developments. There is little market for aircraft the size of a 757, that is why the 757 is leaving.. it still has many excellent merits, but zero demand. An Airbus copy would have the same fate I suspect.
DFW
keesje
Fri Jul 09, 2004 5:37 am
That´s not a disadvantage, airlines tend to be more impressed by low fuel cost then steep climb angles ..
Are you really sure this is a Boeing patent ?  Big grin
If it sells like the 321/757 during the last 15 yrs, yes. Some of the 757/762/310´s will have to be replaced & 7E7-3 might be to big & expensive for many ..
I thought the -600 is flying for more then 3 yrs now, about the serious thread of the 777LR family, lets not talk about the 772LR sales ...
ANA deal was too politically loaded (like JAL..) ANZ is a small order, the two (I forgot their names, excuse me) leisure carriers probably opportunistic, how much did they pay ? ...
Sorry Airbus, but ... keep design teams efficiently moving from one project to another, don't worry about catering ....
Well, now that won´t be a problem in the south of France  Big thumbs up
solnabo
Fri Jul 09, 2004 5:58 am
 Big thumbs up Way to go Keesje  Big thumbs up
Mike/SE
DfwRevolution
Fri Jul 09, 2004 6:14 am
Tell that to SQ  Big grin
The last thing Airbus needs is an underpowered aircraft that leads to performance penalties like the A321-100.
99% ... if anyone is able to confirm I'll be open to reconsidering"
12 months ago, these orders, however small, would have been shoe-ins for the A330. No longer. In many respects, the First Choice/Blue Panorama (or Panorama Blue?) is more important than the ANA order: it shows the 7E7 could be on its way to acceptance from charter/LCC airlines.
One way or another, does anyone think Boeing would have won these three new customers with the 767? Absolutly not, and therefore, 62 potential A330 orders are now Boeing's.
Yes it has been flying for three years, but a better than expected 777-300ER has led to a A346HGW. This aircraft is not expected until 2007 and the 773ER still has growth potential, so like I said, the drama between the 773ER and A346 is not over.
Further, the 773ER is winning customers faster than the A346, blostered by the 7E7. Remember that AirNZ deal included 773ER options, and SQ is widely reported to be in the process of signing the 7E7. Only time will tell in this transaction.
Give me good 'ol texan BBQ ribs any day  Big grin
Rather irrelevant, as the A345 hasn't exactly set the world on fire either...
gigneil
Fri Jul 09, 2004 12:11 pm
36,000 pounds of thrust is sufficient to offer an A322 with 220 seats, assuming they don't really want to add a ton more range.
N
Hamlet69
Fri Jul 09, 2004 1:52 pm
"Are you really sure this is a Boeing patent ?"
Yes, it is.
Hamlet69
All gave some. Some gave all.
azmd80
Sat Jul 10, 2004 2:25 am
A321 is a good A/C with a good success, but I'm not sure that 322 will be a such success.
The 321 is used mainly on short trunk route, with the pourpouse of obtaining more pax without increasing frequencies, or by charter operator.
I think that the main carriers are going to offer higher frequencies to fit better the market, in fact 321 aircraft seems to be used only on route such CDG-LHR or MXP FCO, etc.. Also BA seems to prefer chanching is 757 with smaller A/C.
The carther carriers aren't so happy with their 321 due to the range that doesn't allow medium route.
321 is considered a bit underpowered so i don't know if it coud be increase performance without main structural innovation.
if develloped, 322 will be a niche aircraft, so it couldn't be a great success. It worth the devoppement cost only if it will nor require maior structural changings.
