Kennedy1
Which WN A/c Operate These Routes?
Sun Jul 18, 2004 1:22 am
I have to make a quick trip out to PHX using a voucher from WN and am trying to get on one of the newer canyon blue a/c. Can someone tell me which a/c operates these routes? STL - PHX flt. 1835,605 or 1991 then PHX - STL flt. 472, 2428 or 2711.
[Edited 2004-07-17 18:22:30]
goingboeing
RE: Which WN A/c Operate These Routes?
Sun Jul 18, 2004 2:20 am
I'm pretty sure that route uses a 737.
OPNLguy
Sun Jul 18, 2004 2:28 am
It's not as if specific aircraft numbers are assigned specific flights, and they operate those same flights every day.
Aircraft assignments are typically done 3-4 days in advance, and are subject to frequent (and often last-minute) changes as operational and maintenance scenarios change.
If you've got a specific date in mind, I'll check to see what aircraft may have been assigned, with the caveat that it's subject to change.
atrude777
I can tell you that PHX-STL flight 2206 is scheduled as a 737-500, so I wouldnt fly that route. However, iv seen 733 and 737 land at STL from PHX as 2206. So basically Its just luck of the draw. Iv flown a 737-700 with no blue colors, and iv flown a 733 w/ interior Blue Colors to/from STL, so like I said, luck of the draw.
Alex
