MAH4546
AA To End Service To Belo Horizonte, Brazil
Tue Aug 03, 2004 9:43 am
Sadly, Belo Horizonte will lose their only trans-continental carrier this fall, as American Airlines is pulling out on 30 September. They operated a daily 777-200ER service from Sao Paulo, that connected to their MIA/DFW/JFK flights.
The destination has been served since the mid/late-90s from both GRU and GIG at different times. The service cancelation is surprising, because it has usually been a healthy performer for AA because of cargo traffic (which is why it used a 777). Passenger loads were usually decent, although yield was never great. One of the main reasons AA is ending the service (other than the fact it is no longer making money) is that AA wants to eventually put an end to LatAm tag on services (for example, they are starting MIA-MVD non-stops in December and MIA-ASU is not far off), and the US/Brazil air treaty, which is very strict, won't allow AA to fly MIA-CNF without acquiring hard to get US-Brazil slots. In the future, if the US-Brazil air treaty is laxed, I could definitley imagine AA entering more Brazilian markets with 757s.
This is only the fourth LatAm destination (excluding Mexico) AA has dropped since starting service to the region. The others were Porto Alegre, Brazil (served in mid-1990s as tag-on flight from GRU; weak yield), Cuzco, Peru (served in 1998 as tag-on flight from LIM; they had problems with the local facilities), and Barranquilla, Colombia (a destination acquired from Eastern but dropped in April 2002 because the Colombian Aviation Authority would only allow AA to serve three Colombian cities, so they switched BAQ for MDE; AA would return in a heartbeat if they could).
It is one of three cities leaving the AA network this fall, joining Duluth, Minnesota and Lincoln, Nebraska.
a.
NYCAAer
RE: AA To End Service To Belo Horizonte, Brazil
Tue Aug 03, 2004 11:11 am
Oh, well. That's the way the cookie crumbles. The flight crews will be thrilled to only have to fly a 3 and a 1/2 day trip to GRU, instead of a 5-day with a turnaround to CNF on the 3rd day.
EddieDude
Tue Aug 03, 2004 11:16 am
Do you think either JJ or RG would be interested in flying non-stop from CNF to the States? In other words, is there a market for that route?
Upcoming AM MEX-LAX 73H, VA LAX-MEL 77W.
scottysair
Tue Aug 03, 2004 11:18 am
It is use with one-stop in GRU for bound to DFW. I looked it up with their timetables with AA.
MAH4546
Tue Aug 03, 2004 12:26 pm
Yes, there is a market for the route. The yield is not that strong, but JJ/RG could pull it of 2-3x a week. Cargo yields alone make up for lack of passenger yields, CNF is a huge cargo market. RG has begun re-opening up long-hauls from secondary markets after cutting them all (except AB) (FRA / FRF / EDDF), Germany">FRA-GIG) about a two years ago, so there is potential.
a.
EddieDude
Tue Aug 03, 2004 12:34 pm
Let's see then which of the two decides to launch the route (hopefully it will happen). I guess JJ would likely route such a flight to MIA (or perhaps to DFW as a result of its codeshare with AA)... I don't know where RG would send such a flight to, but it would have to be a place where Star Alliance has a hub, don't you think?
MAH4546
Tue Aug 03, 2004 12:53 pm
Either or, they would send it to Miami, not Dallas or another hub. Miami has the O&D, the business ties, and the cargo traffic. It is really the only way a CNF-US flight would be profitable.
I would think Varig would operate the route. They have operated MIA-FOR/MAO/REC/BEL/SSA before the withdrawl of non-GRU long-haul flying canceled those routes, and MIA-GIG. Things are a little better now (still not great) and MIA-GIG is back. If they get into better financial shape in the future, others will return too.
TAM is now operating MIA-SSA, though it is partly subsidized by Salvador-area hotels.
a.
scottysair
Tue Aug 03, 2004 12:59 pm
Is that will still use with their flight on JJ service to SSA, correct? How is load was doing? Can you anyone to find out with those information about JJ is service from MIA-SSA nonstop?
latinaviation
Wed Aug 04, 2004 3:53 am
Actually, Mark, I would disagree with you. AA dropped BQE before they picked up MDE. AA dropped BQE when they were retiring their 727-200 fleet. At the time, AV was operating the route with a 757 and the market was only ~150 pax day. MDE was decided long after BQE was dropped and, iirc, the frequencies were different.
Sadly, not long after AA pulled out of BQE their station manager, a long-time employee of AA and EA, passed away as well.
MAH4546
Wed Aug 04, 2004 5:05 am
BAQ was dropped as a result of MDE. While there was a small stretch of time between the two (BAQ dropped 7 April 2002; MDE started 15 June 2002), BAQ was dropped because the CAA did not allow AA to serve both BAQ and MDE. AA perfered MDE...it is a bigger O&D market and has a lot more business traffic, as opposed to the VFR traffic that is dominate in BAQ. BAQ was going to be switched to a 738 before it was dropped. The delay between dropping the two destinations had to do with various issues...including aircraft scheduling (April-May is a slower travel period, which allows AA to put more aircraft into maintence), and the fact that June is a busier traffic month (and a better time to launch new routes). AA usually drops routes in September and April.
a.
plaaneboy
Wed Aug 04, 2004 5:18 am
Actually, latinaviation is correct. BAQ had been struggling for sometime before they pulled the plug on the route. With the local BAQMIA market so small and AV operating a 757 on the route, AA was getting squeezed on the route. It's highly unlikely that AA will return to BAQ anytime soon, with or without the approval of the Colombian government. It was simple economics that caused AA to pull out of BAQ.
MaverickM11
Wed Aug 04, 2004 5:20 am
Speaking of ending tags, is there any way to fly LPB-MIA nonstop? It's not really a tag but more of a roundabout with VVI.
E pur si muove -Galileo
MAH4546
Wed Aug 04, 2004 5:27 am
No, there isn't. An aircraft cannot fly LPB-MIA non-stop due to La Paz' altitude and runway length. If AA were to increase Bolivia service, it would be with another triangle MIA-VVI-LPB-MIA routing (or just MIA-VVI-MIA).
a.
scottysair
Wed Aug 04, 2004 5:30 am
Exactly, Mark and this is one of direct of their service from MIA to Columbia flights and this is one of need more service to BAQ or something else with these city. It is largest Columbia market and it will there is something about more new flights anytime soon. It's not really have a new tag more new things.
ConcordeBoy
Wed Aug 04, 2004 5:33 am
CNF-GRU ain't much of a transcon, wouldn't ya say?  Laugh out loud
That, and JJ/RG fly the route as well as others... not just AA.
AlitaliaORD
Wed Aug 04, 2004 1:24 pm
wait, dosnt CO fly to Belo Horizonte?
Joy To The World, All The Boys and Girls, Joy to the Fishes in the Deep Blue Sea, Joy to You and Me
MAH4546
Wed Aug 04, 2004 1:32 pm
No, they did until around 2001 or so. United also used to fly to Belo Horizonte, though, unlike AA and CO, they flew there non-stop, three times a week from MIA in the mid-90s. It was supported by cargo revenue.
a.
Pbb152
Wed Aug 04, 2004 1:40 pm
CO dropped their Belo Horizonte tag about four years ago. I believe the service only lasted for a year or so.
Pete
latinaviation
Wed Aug 04, 2004 8:27 pm
It was operated with a 767-200ER and when it first started was more like 5x/week or daily. UA then dropped the non-stop and added a second flight to GRU, also with the 767-200ER, that continued to CNF.
JJMNGR
Wed Aug 04, 2004 8:46 pm
I totally disagree with some information given above that there is market in CNF to operate to US. If market is so good, why AA is leaving?
The reality is much different. CNF is a white elephant, with a very poor operation. AA positioned their aircraft in CNF for a lower rate than if kept aircraft in GRU. Of course with some pax on board and some cargo with a lower airport rate to position aircraft, should be attractive for some reason. But making money is another issue.
The loads of cargo may be good but rates applicable are not enough to save the leg nor pax loads.
There is no interest in TAM start to operate this route.
Regarding to TAM´s SSA operation, loads are very good not only southbound but northbound too and cargo is superb. TAM is making studies to implement a weekly cargo flight between MIA and SSA.
MAH4546
Wed Aug 04, 2004 9:20 pm
Because AA has no US-Brazil slots available to attempt to fly the flight non-stop as they would like to. The flight had made AA plenty of money until recently.
a.
JJMNGR
Wed Aug 04, 2004 11:07 pm
What is your source about making money? Of course a flight starting in CNF with a stop in GRU will make money. But the leg CNF itself sucks. There is no market in CNF to justify an international flight there.
I am here in Brazil and know this mrkt very weel to tell you all it is not a good market to justify an intl operation.
MAH4546
Thu Aug 05, 2004 12:20 am
They are good sources, trust me. They made money at CNF until about the last 12 months. That's why CNF had survived all of AA's network cut backs in the past. AA wanted to make it a non-stop from MIA, but the strict bilateral, combined with aircraft scheduling, didn't make it possible. MVD is going non-stop in December, and ASU is tentatively set to go non-stop in June. They don't want to do many tag-ons anymore.
Yes there is. There is a huge cargo market. That is what has justified AA, CO, and UA in the past. There are enough passengers to fill a plane too, though they are low-yielding and don't fill premium cabins (F/C on AA's CNF flight usually left with 5 seats occupied, and that was on a good day). Sadly, the cargo market has dropped off lately, which is forcing AA to leave. They didn't operate a 777 to CNF for the hell of it, when they could have to a more profitable destination like ASU. They operated a 777 because of the cargo demand.
a.
EnoreFilho
Thu Aug 05, 2004 12:49 am
Let's say that AA cancelled its flights to CNF because economical reasons, as JJMNGR said. The State of Minas Gerais used to be a great immigration source to USA, and with the difficulties to have an american visa, the number of passengers is very low actually, even for tourism (let's go to Europe!!!! Smokin cool)
Member of the all mighty Canudos Air Force!!!!
JJMNGR
Thu Aug 05, 2004 5:53 am
It is incredible!!! People very far away from here wants to know about Brazilian market more than us, who lives here and work in the airline industry.
Let´s talk about cargo??? Good this is my stand on the sunshine...
AA is very well known in the cargo industry, for bad rates practise. Even when the market is full of cargo, AA insists in sell cargo for lower rates. They sell CNF to MIA for average USD1,00...the average cargo they handle in CNF is 02 lower deck positions plus 02 LD3, what means something about 7 tons. ONLY USD7.000,00 (average) from CNF to MIA. What is the cargo contribuition of the CNF leg till final destination considering this poor cargo yeld?
Come on!!!. Brazilian airport rates are exorbitant as it is a monopole, cargo and air tkts are being sold by AA for nothing and they are making money? No way buddy. No way.
US carriers are desperate for money and it is an urgt need to get out of the crisis, as so as many other carriers in the world. It is totally nonsense; if they are making money, they were not supposed to leave CNF...but fact is that they are leaving.
I can´t imagine that a company is going to close a station if they are making money. Nowadays, make money and cease operations? Only if they are crazy. As some insists AA is making money, automatically are calling them as nuts...giving up this very profitable route!!!
MAH4546
Thu Aug 05, 2004 11:57 am
JJMNGR, did you not read my post before going all nuts?
And...
Simply put, the money at CNF isn't flowing like it used to, and AA is dropping it.
a.
